Old Jul 19, 2012, 08:43 PM
whitehawk is online now
Find More Posts by whitehawk
Timmmaaaahhh!!!
whitehawk's Avatar
United States, IN, Dyer
Joined Mar 2008
Fitting the new xtreme blade grips...no instructions but I think that I figured out how to install the upper grip. The lower grip is a puzzler. Does the lower grip mount upside down?
whitehawk is online now Find More Posts by whitehawk
Old Jul 19, 2012, 10:53 PM
Timmmaaaahhh!!!
whitehawk's Avatar
Joined Mar 2008
I think that I have the grips installed correctly now,Geez good thing I'm an engineer lol
Old Jul 20, 2012, 06:48 AM
kodak_jack is offline
Find More Posts by kodak_jack
kodak_jack's Avatar
Hilton (Rochester), NY
Joined Mar 2008
The part you're doing with the grips is mechanical. If you're electrical, don't touch any tools!!!
We've gone through this a very short time ago, but here goes:
The flanged bushings go over the rotor head pins with the flange toward the inside.
The bottom half of the grip is put in place and the U-shaped pieces go over the bushings and are secured by tiny screws. This makes the lower half stay in place while also capturing the bushings. Do not over-tighten the screws so they don't strip, but tighten them enough that they are secure. A touch of LocTite or even a dab of clear finger nail polish might be nice so they don't back out (nail polish just on the head of the screws, not on the threads).
The top half of the grip is now held to the bottom as well as securing the blades by socket head cap screws that require a 1.5MM Allen wrench.
You should have new links that connect the lower blade grip to the swash plate. The X goes to the outside.
kodak_jack is offline Find More Posts by kodak_jack
Old Jul 20, 2012, 11:42 AM
Timmmaaaahhh!!!
whitehawk's Avatar
Joined Mar 2008
The lower grips did not include any new links...I'm using the original links. What do you mean "The X goes to the outside."
Old Jul 20, 2012, 12:51 PM
Chap1012 is offline
Find More Posts by Chap1012
Epilepsy Awareness
Chap1012's Avatar
United States, MA, Malden
Joined Mar 2008
I believe what Jack means is that the link has a mark (X) that indicates that, that is how the link goes on (facing out). Also, put the "X" so it is on the top for good measure. It will not go on with the "X" facing inward. Look at the link very carefully. On some helis the link goes on only one way. On other helis it will go on either way....like the V4. Did I just say "V4" again
Mike.
Chap1012 is offline Find More Posts by Chap1012
Old Jul 21, 2012, 12:36 AM
Luvmyhelis is offline
Find More Posts by Luvmyhelis
Professional heli wrecker
Luvmyhelis's Avatar
United States, WA, Spokane
Joined Oct 2010
Luvmyhelis is offline Find More Posts by Luvmyhelis
Old Jul 21, 2012, 12:47 AM
JDFiend is offline
Find More Posts by JDFiend
JDFiend's Avatar
Denver, CO
Joined Mar 2009
Reading this thread got me interested in flying my CX2 again. This is still one of my favorite parkflyers. You can actually get some pretty good speed with these helis on a calm day with the right mods.
JDFiend is offline Find More Posts by JDFiend
Old Jul 21, 2012, 05:42 AM
Timmmaaaahhh!!!
whitehawk's Avatar
Joined Mar 2008
Originally Posted by Luvmyhelis View Post
I did not get any new links in my lower blade grip package...am I missing them or do you buy these separately?
Old Jul 21, 2012, 07:03 AM
kodak_jack's Avatar
Joined Mar 2008
I didn't get the links with my new lower grips either - originally. Then, they (Miracle Mart) realized their mistake and sent them separately. They OWE you those links and may be able to rectify the situation by sending you a rebuild kit/ spare parts kit (BCX301-P) that has links in it. You cannot use the stock links as they are too short. Get them off NOW so they don't ruin the grip.
Old Jul 21, 2012, 07:06 AM
kodak_jack's Avatar
Joined Mar 2008
What in the world is going on between the upper bearing cup and the upper rotor head? Is that something that was available at the time or did you make that? It looks like a custom made inner and outer shaft.
Old Jul 21, 2012, 07:13 AM
kodak_jack's Avatar
Joined Mar 2008
Xtreme Boom Bracket
I forgot to post a picture of my boom mounted to an Xtreme boom bracket. There is a nub sticking out the back of the bracket that I originally had an aluminum tube sticking off of. I had a little boo boo and cut that nub off flush. I then removed the two rear-most screws and drilled it out to accept a 5MM CF boom. Luv has done the same thing. You can then add fins if you want. No need for a zillion dollar boom set. Sorry if the picture is a little fuzzy, but you get my drift.
Old Jul 21, 2012, 06:17 PM
Luvmyhelis's Avatar
Joined Oct 2010
Yes, I did the same thing quite a few years ago and never looked back. All my coaxial builds with Cx frames use this now. This is the very first one I did. Super cheap.
Extreme hub. $3
4.5 or 5mm CF rod. $3
HK CF 250 stabs. $4
Although my first one used current 450 CF stabs I had laying around.
Here is an easy step by step with 4.5mm cf tube, no drilling required. Ca glue and a dremel to cut the CF tubing. Now I epoxy the halves and use smaller stabs. No boom supports are needed as this thing is rigid. Tough, and light. Also I use shrink wrap now under the CF stabs to anchor the screws and eliminate the stabs from vibrating. I also now use different canopy's and skids. The only tricky part is to remember that on CF frames to add a small spacer on the battery tray stud the rear lower boom support goes over to make both sides even. You can clamp the halves together a dozen different ways. Even using rubber bands.
They actually froze my thread over at HF when I did this build. The mod thought it was too aggressive. It was the first brushless mod ever seen over there.
Old Jul 22, 2012, 03:35 AM
JDFiend is offline
JDFiend's Avatar
Denver, CO
Joined Mar 2009
Jack,
My extended shaft has an actual piece of black plastic attached to the shaft. I ordered it online about 4 years ago, so I can't remember where the heck I got it.
Old Jul 22, 2012, 06:22 AM
kodak_jack's Avatar
Joined Mar 2008
That sounds like a HeliTek extended shaft. I've never had one and they're out of business now.
Old Jul 22, 2012, 09:07 AM
Chap1012 is offline
Epilepsy Awareness
Chap1012's Avatar
Joined Mar 2008
I think Leethetreeguy will make you some. You'll have to ask him..
Discussion to buy or not to buy the blade cx2 airhead225 Coaxial Helicopters 36 Jul 09, 2009 11:01 PM
Discussion Blade CX2 Tx's - Can they be adapted to fly indoor/park flyers Sirion Electric Plane Talk 11 Apr 19, 2009 07:52 PM
Question How to program my dx7 to fly blade cx2? topforce Coaxial Helicopters 4 Sep 23, 2007 09:13 AM
Discussion How do I use my ICE to charge my batterys for blade CX2??? webejpn01 Electric Heli Talk 2 Jan 26, 2007 01:02 PM
Discussion How to learn to fly inverted with the Blade CP? Crazyrcer Micro Helis 4 Apr 05, 2006 12:59 PM
