Old Aug 21, 2011, 12:33 AM
alpinesandtoys is offline
Find More Posts by alpinesandtoys
alpinesandtoys's Avatar
Joined May 2011
So there's supposed to be a spacer there pushing it down?
alpinesandtoys is offline Find More Posts by alpinesandtoys
Old Aug 21, 2011, 01:38 AM
Luvmyhelis is offline
Find More Posts by Luvmyhelis
Professional heli wrecker
Luvmyhelis's Avatar
United States, WA, Spokane
Joined Oct 2010
no there is supposed to be more space between them so the swash doesn't bind against the hub. In essence if the swash touches the hub you will loose full movement of the swash and loose its ability to guide the heli in anything more than a mild hover, pretty much what you are describing. Here is a very old pic but you should get the drift.
Luvmyhelis is offline Find More Posts by Luvmyhelis
Old Aug 21, 2011, 08:04 AM
flyeraroo is offline
Find More Posts by flyeraroo
"whirlydude"
flyeraroo's Avatar
United States
Joined Sep 2008
Originally Posted by alpinesandtoys View Post
Hey guys, been trying to find the answer to my question without much luck. My brother gave me his CX2 to mess around with and I've been trying to fly it outside. Seems like there's VERY little control on this thing for left/right/forward back movement. It'll spin around pretty well (left stick) but there's just not a lot of control with the right stick. I've tried moving the control rods to the farthest end of the servo arms and still not much luck. I think he put some after market parts on it, can you tell by the photos if something was not setup right? Thanks for the help.
Here is a link to some pictures of what I did to prevent the lower end of the lower rotor hub from binding on the top of the swashplate. Use a dremel and trim off around a 1/8" so you have clearance between the two. When I flew outdoors I had the pushrods in the third hole from center of the servo horn. It's all I needed, and indoors I still fly with the pushrod in the second hole. The further out one goes the more chance of binding.
http://www.rcgroups.com/forums/showt...07057&page=308 (post #4609)
flyeraroo is offline Find More Posts by flyeraroo
Old Aug 29, 2011, 01:01 AM
kodak_jack is offline
Find More Posts by kodak_jack
kodak_jack's Avatar
Hilton (Rochester), NY
Joined Mar 2008
bump
kodak_jack is offline Find More Posts by kodak_jack
Old Aug 30, 2011, 02:03 PM
Barak1001 is offline
Find More Posts by Barak1001
Resident Skeptican
Barak1001's Avatar
USA, AL, Hanceville
Joined May 2008
Three things I can recommend:
1. Get rid of the current boom with the aluminum mount and get a Boomtown model 4 boom. Your current boom is going to limit your forward authority by moving your center of gravity further rearward.
2. Get yourself a shorter flybar. The flybar at stock length limits cyclic authority dramatically. If you can't find one already modified shorter you can buy a Dynam Vortex flybar and use the adjustable weights off it with your flybar. Optimal flybar length is between 4.25" and 4.5". Part number VTX-002 will fit your CX2, part number VTX3-002 WILL NOT. The weights will work off of the newer flybar, but the center hub won't fit, so you'll have to use the new weights on your stock flybar.
3. Get yourself an extended shaft. Once you shorten you flybar your chances of blade strike are going to dramatically increase. You'll need an extended shaft at least 2 cm longer than stock.
Barak1001 is offline Find More Posts by Barak1001
Old Aug 30, 2011, 10:54 PM
kodak_jack's Avatar
Joined Mar 2008
A note on item #2, the Dynam flybar. I have one of those and BP HObbies doesn't carry them anymore, nor does HeliDirect. It also comes with a fixed flybar link.
Old Aug 31, 2011, 03:44 AM
Resident Skeptican
Barak1001's Avatar
USA, AL, Hanceville
Joined May 2008
The fixed link isn't an issue. You just transfer the linkage from your original flybar to the new one.
As far as being sold you can still find them, just have to google a bit.
Old Aug 31, 2011, 08:13 AM
OTTOFLYS is offline
Find More Posts by OTTOFLYS
Grand Rapids MI.
Joined Feb 2011
Is just the picture or is the swash awefully tight to the lower hub aswell? possibly limiting movement or even binding slightly
OTTOFLYS is offline Find More Posts by OTTOFLYS
Old Aug 31, 2011, 08:30 AM
Resident Skeptican
Barak1001's Avatar
USA, AL, Hanceville
Joined May 2008
http://www.ebay.com/sch/i.html?_from...6&_nkw=vtx-002
One person is selling 5 flybars for $10 shipped.
Old Aug 31, 2011, 09:04 AM
kodak_jack's Avatar
Joined Mar 2008
Scroll up to 6258.
Old Aug 31, 2011, 09:44 AM
Chap1012 is online now
Find More Posts by Chap1012
Epilepsy Awareness
Chap1012's Avatar
United States, MA, Malden
Joined Mar 2008
There is a cool tool at the top of every page. It's called "Thread Tools." Click that and scroll down to "Show Attachments in This Thread." You will see countless pictures of the swash. Not to mention some other "very" interesting pictures
Mike.
Chap1012 is online now Find More Posts by Chap1012
Old Sep 08, 2011, 02:39 PM
OTTOFLYS is offline
Grand Rapids MI.
Joined Feb 2011
Wow excuse me from being human and making an honest mistake...I did find a really COOL thing Chap in the thread tools....UNsubscribe. Have fun playing with your kid toys
Old Sep 09, 2011, 10:48 AM
Epilepsy Awareness
Chap1012's Avatar
Joined Mar 2008
WHOA...OTTO, hold on a moment I was just trying to be helpful so you could find other pics that other members submitted so it would help you find the problem. BTW, yes, the lower rotor being too close to the swash will bind the swash as Kodak Jack pointed out when he told you to scroll up to post#6258. I assumed you were looking for more evidence (IE: pics).
Not even seasoned members know about the tools at the top of every page. Sorry if you feel I rubbed you the wrong way but, I'm sure you interpreted my post "completely" the wrong way.
Mike.
Old Sep 09, 2011, 12:37 PM
robgau is offline
Find More Posts by robgau
Pineville, LA
Joined Dec 2006
Mike,
It's sad some people are so easily offended. I appreciate the tip. I've been on RCGroups for over a year and did not realize that option was there. Hopefully Ottoflys will discover a kinder heart one day. Life's too short.
Rob
robgau is offline Find More Posts by robgau
Old Sep 09, 2011, 12:55 PM
Luvmyhelis's Avatar
Joined Oct 2010
Thanks Mike, I am even more of an oldtimer than that and I just for the first time srcolled through that section. I had no idea!
Randy
Discussion to buy or not to buy the blade cx2 airhead225 Coaxial Helicopters 36 Jul 09, 2009 11:01 PM
Discussion Blade CX2 Tx's - Can they be adapted to fly indoor/park flyers Sirion Electric Plane Talk 11 Apr 19, 2009 07:52 PM
Question How to program my dx7 to fly blade cx2? topforce Coaxial Helicopters 4 Sep 23, 2007 09:13 AM
Discussion How do I use my ICE to charge my batterys for blade CX2??? webejpn01 Electric Heli Talk 2 Jan 26, 2007 01:02 PM
Discussion How to learn to fly inverted with the Blade CP? Crazyrcer Micro Helis 4 Apr 05, 2006 12:59 PM
