Old Jul 19, 2011, 09:30 AM
robgau is offline
Find More Posts by robgau
Pineville, LA
Joined Dec 2006
Didn't notice if it was still initiated. I've never had one drop out of the sky before. Tried it yesterday and it flew but has a bent outer shaft.
robgau is offline Find More Posts by robgau
Old Jul 19, 2011, 09:40 AM
Chap1012 is online now
Find More Posts by Chap1012
Epilepsy Awareness
Chap1012's Avatar
United States, MA, Malden
Joined Mar 2008
It may be worth to take a closer look at the power source where the battery plugs in. Something seems to be cutting in and out. I know on the Eflight mcX those small battery plugs fail all the time making the heli do some weird stuff. Which it will without constant or little power.
Mike.
Chap1012 is online now Find More Posts by Chap1012
Old Jul 19, 2011, 09:51 AM
robgau is offline
Pineville, LA
Joined Dec 2006
Thanks Mike.
The connection where the battery leads go into the 4n1 is covered with a white rubbery glue. I'll probably just try to fly it at low altitudes for a while and if it happens again, pay closer attention to the lights on the heli if comes down again.
Rob
Old Jul 19, 2011, 09:54 AM
flyeraroo is offline
Find More Posts by flyeraroo
"whirlydude"
flyeraroo's Avatar
United States
Joined Sep 2008
Both motors shut down. It dropped like a rock.
Sounds like a loose connection somewhere!
flyeraroo is offline Find More Posts by flyeraroo
Old Jul 19, 2011, 10:02 AM
Epilepsy Awareness
Chap1012's Avatar
Joined Mar 2008
My feeling exactly....
Old Jul 20, 2011, 03:20 AM
kodak_jack is offline
Find More Posts by kodak_jack
kodak_jack's Avatar
Hilton (Rochester), NY
Joined Mar 2008
I was certain that we were in the Lama 4 thread. CX2's don't have problems like this!!
kodak_jack is offline Find More Posts by kodak_jack
Old Jul 20, 2011, 09:29 AM
Epilepsy Awareness
Chap1012's Avatar
Joined Mar 2008
So you tell me ALL the time Jack...looks like the tables have been turned
Mike.
Old Jul 20, 2011, 04:28 PM
"whirlydude"
flyeraroo's Avatar
United States
Joined Sep 2008
With the hot temps and humid conditions that's hitting us, it sure is nice to have the CX2's to fly around in the basement. Where it is nice and cooooool!
Old Jul 20, 2011, 11:51 PM
Luvmyhelis is offline
Find More Posts by Luvmyhelis
Professional heli wrecker
Luvmyhelis's Avatar
United States, WA, Spokane
Joined Oct 2010
Hot temps?
Shoot, I live up in Washington. And it has been nothing but rain and weird cold weather.
Send some of that heat up my way!
Just an update on my Cx fleet. OlliW sent out my boardless memms gyros yesterday so I should be posting up the updates on my vtail brushless herd fairly soon.
Luvmyhelis is offline Find More Posts by Luvmyhelis
Old Jul 21, 2011, 03:17 AM
kodak_jack's Avatar
Joined Mar 2008
Originally Posted by Luvmyhelis View Post
Hot temps?
They're calling for the possibility of 100F today!!!!!!!!! Do you want the large or extra large shipment?
Old Jul 21, 2011, 09:59 AM
bulesz is offline
Find More Posts by bulesz
bulesz's Avatar
Hungary EU
Joined May 2007
Hey Guys,
I have tried the CX2 with a DX6i but much worse than with the LP5DSM... is there any trick with the settings, and how can I turn on the gyro?? (the choppa is losing control and yawing to left...)
Many thanks,
Bulesz
bulesz is offline Find More Posts by bulesz
Old Jul 21, 2011, 12:44 PM
Luvmyhelis's Avatar
Joined Oct 2010
Hey bulesz! Just thinking about you last week and wondering how things were.
On the DX6i you are able to adjust and toggle in between the gyro hh and rate modes in the 3in1 by the channel 5 slot in your RX (6100e).
I am happy the DX6i is working with one of your 3in1s since they were basically incompatible in quite a few cases. I think I only had one or two of them that worked. For some reason the signal from the Dx6i would not run the throttle correctly.
But, back to this problem. Your 3in1 has a yellow single wire with a 3pin female connector on the end of it. This is your ch5 gain wire. Hopefully you have the instruction manual for your DX6i as the gain settings on the Spektrum Tx are confusing. (page 115) Basically anything under 50 goes into normal and anything over toggles into HH on your left toggle switch that says flap/gyro.
Old Jul 22, 2011, 05:38 AM
bulesz is offline
bulesz's Avatar
Hungary EU
Joined May 2007
Hey LMH,
Im still fighting with the gyro settings..
Im in ACRO mode, and it seems to not using the gyro at all...or very weak...
Do you have a recommended settings on the 3-1 which would be a good starting point in ACRO mode?
or what to do in Heli mode?
Many thanks!
B.
Old Jul 22, 2011, 03:16 PM
Luvmyhelis's Avatar
Joined Oct 2010
Originally Posted by bulesz View Post
Hey LMH,
Many thanks!
B.
It actually differs from one build to the next. Leave it in heli mode though.
It is based on so many parameters that it is hard to find one setting that seems to work for everyone. I had to tinker with every one of mine to set the gyro. And none were the same.
Old Jul 22, 2011, 04:36 PM
"whirlydude"
flyeraroo's Avatar
United States
Joined Sep 2008
Hey LMH,
Many thanks!
B.
What I have read, everyone that has tried to setup the dx6i with the internal gyro in a 4 in1 and 3 in1 unit has complained about tail wag and twitching. When they went back to the stock LP5DSM transmitter the cx2 flew perfect. Here is a thread, which you may want to read through it all, but a couple of guys had success mounting an external gyro using their dx6i in heli mode. (post #57) If your going to use an external gyro, turn the gain off (or lowest setting) on the 3 in 1 unit.
http://www.rcgroups.com/forums/showt...for+cx2&page=4
Here is another:
http://www.e-fliterc.com/Articles/Ar...ArticleID=1802
Discussion to buy or not to buy the blade cx2 airhead225 Coaxial Helicopters 36 Jul 09, 2009 11:01 PM
Discussion Blade CX2 Tx's - Can they be adapted to fly indoor/park flyers Sirion Electric Plane Talk 11 Apr 19, 2009 07:52 PM
Question How to program my dx7 to fly blade cx2? topforce Coaxial Helicopters 4 Sep 23, 2007 09:13 AM
Discussion How do I use my ICE to charge my batterys for blade CX2??? webejpn01 Electric Heli Talk 2 Jan 26, 2007 01:02 PM
Discussion How to learn to fly inverted with the Blade CP? Crazyrcer Micro Helis 4 Apr 05, 2006 12:59 PM
