Old Apr 20, 2011, 11:28 PM
Luvmyhelis is offline
Find More Posts by Luvmyhelis
Professional heli wrecker
Luvmyhelis's Avatar
United States, WA, Spokane
Joined Oct 2010
Nice innovation. And yes you can put your futaba rx in and use it. And I am successfully running a trex250 canopy on one of mine.
Luvmyhelis is offline Find More Posts by Luvmyhelis
Old Apr 21, 2011, 01:34 PM
leethetreeguy is offline
Find More Posts by leethetreeguy
Fly em if ya got em.
leethetreeguy's Avatar
Winder Ga
Joined Sep 2008
You guys are innovative and creative. I Love it!!! Good stuff indeed. Lee
leethetreeguy is offline Find More Posts by leethetreeguy
Old Apr 25, 2011, 07:08 PM
OTTOFLYS is offline
Find More Posts by OTTOFLYS
Grand Rapids MI.
Joined Feb 2011
[QUOTE=erdnuckel2;18024224]did you put the blades from the pictures on the rivesud grips ?? (that would beyond doubt identify the grips as the culprit).
QUOTE]
Alright I had some time this weekend to do some switching and swapping and its definantly not the grips, its the blades. It seems as though they have no spine to em. LOL i put Xtreme hard 55*, Reg Xtreme blades and rcvd blades on the purple grips and they all flew great. With that I put the black no-name blades on a real light weight cx chasis that I quick put together for this test...and the still fly like with a ton of flex and very little lift . Live and learn!!!
In the mean time I threw this beauty togather.
cx3 canopy, align 450 skids + aluminium tube, esky 900mah battery tucks under the nose nicely and helps balance this tail heavy thing out, also I did remount the 3in1 to the proper orientation because the gyro wanted to keep making it nose over...once again, Live&Learn
OTTOFLYS is offline Find More Posts by OTTOFLYS
Old Apr 25, 2011, 11:34 PM
Luvmyhelis's Avatar
Joined Oct 2010
I Love it!!!
Old Apr 28, 2011, 10:35 PM
PCURRY is offline
Find More Posts by PCURRY
Joined Apr 2011
Removing fly bar holder on CX2
I have asked this question many times with different answers. Can I take the blue anodized fly bar holder and the black piece below it to install the lower Xtreme carbon blade grip. Do I really need to remove the collor at the bottom of the Heli and remove the inner/outer tone and slip the lower grip through the bottom of the shaft. You would think you could install it from the fly bar end. But how to remove the holder. I too the set screw out with no luck
PCURRY is offline Find More Posts by PCURRY
Old Apr 28, 2011, 10:50 PM
erdnuckel2 is offline
Find More Posts by erdnuckel2
erdnuckel2's Avatar
Joined Mar 2009
I would have to take a look at that again to be really sure, but doing this on my CX3 I think I did it how you suggest from the top (however, removing the upper rotor head [I think that is what you refer to as "flybar holder"] seems to have been a lot easier in my case. Normally to all I experienced, if the setscrew is out, the head should move. If it doesnt, my first suspicion would be that they used threadlocker that got in between the shaft and the head ... in which case (very carefully) heating the part should help [by slowly "re-liquifying" the threadlocker .... seems like heat (if it is applied really carefully) often helps with problems on these birds)
In any case, I will check on it at the next opportunity (ie next time I am at my workplace) and post my findings ...
Old Apr 29, 2011, 12:47 AM
Luvmyhelis's Avatar
Joined Oct 2010
You have a classic case of too much threadlock that has now seized the head on the shaft. One way to get rid of it is to heat the head up and re soften the compound. You can use a lighter on the shaft until the head gets fairly soft and it will pretty much fall off. Or use the stove top or even the oven to get it done.
Or just grip the shaft with vice grips using a cloth to keep the shaft from scarring and the same on the head and work them both loose. My problem with this is oftentimes you bend the shaft or irreparably scar it during the process.
Old Apr 29, 2011, 08:13 PM
Tim2Go is offline
Find More Posts by Tim2Go
Hobby Enthusiast
New Mexico
Joined Jan 2011
You sure can. I have no problems installing the carbon lower blade grips from the top. Although, those blade grips are sure problematic as they flex like hell. Find yourself a good set of aluminums for the lowers since they will experience the highest torque on the ball when giving it forward/reverse throttle. Shoot, just get a full set of 'em. The top carbon grips bind at low angles anyways.
-Tim
Tim2Go is offline Find More Posts by Tim2Go
Old Apr 29, 2011, 08:17 PM
Tim2Go is offline
Hobby Enthusiast
New Mexico
Joined Jan 2011
Oh and for the set screw, get yourself a set of good set screws (100 for $5 on McMaster) to have in your toolbox if you're playing with these things a lot. They aren't designed for torquing down and loosening too many times without the hex wallowing out. Plus, I guarantee you'll loose one someday and be upset you can't fly because of a tiny screw. Usually, the local hardware stores don't carry them that small. Next thing you know you're ordering them anyways .
Old Apr 30, 2011, 08:42 PM
OTTOFLYS is offline
Grand Rapids MI.
Joined Feb 2011
do you have a link to this "Mcmaster" ???
and what size are they? 2mm?
Old Apr 30, 2011, 09:08 PM
erdnuckel2's Avatar
Joined Mar 2009
http://www.mcmaster.com/#metric-set-screws/=c3wnj3
Old May 05, 2011, 10:14 AM
k4pacific is offline
Find More Posts by k4pacific
AMA 988154
k4pacific's Avatar
United States, NJ, Somerset
Joined Jan 2009
CX2 Tail Twitch
Hi all. I have a new CX2 which has been trimmed out pretty well. All stock except for the Boomtown #4 tail assembly, flexible skids and motor heatsink. It has a slight tail twitch in hover and I cannot seem to eliminate it. Any suggestions?
k4pacific is offline Find More Posts by k4pacific
Old May 05, 2011, 10:45 AM
Chap1012 is online now
Find More Posts by Chap1012
Epilepsy Awareness
Chap1012's Avatar
United States, MA, Malden
Joined Mar 2008
You didn't say what you tried to eliminate the twitch. Did you try turning the gain down a tad. Do this in very, very small increments. About the thickness of the screwdriver you are using. Hope this helps. Good luck.
Mike.
Chap1012 is online now Find More Posts by Chap1012
Old May 05, 2011, 11:39 AM
AMA 988154
k4pacific's Avatar
Joined Jan 2009
I readjusted the gain as you suggsted in the smallest of increments until the gain was maxed out. The slight twitching is now reduced to perhaps 3/32" either way. Should I expect better than this? I've haven't had any crashes, and I have checked the shafts, flybar and balance of the blades and all are good.
Sam
Old May 07, 2011, 09:43 AM
OTTOFLYS is offline
Grand Rapids MI.
Joined Feb 2011
Sam
That is pretty darn good as far as a twitch goes, but in my experience with the model 4 boom you need to slide the horizontal fin forward so that there is less tention on the rubber O-ring...
I like to have it farther back just for looks but they fly well like this one. after the rubber stretches some you can slide the fin aft more...play with it and let us know what you find
Discussion to buy or not to buy the blade cx2 airhead225 Coaxial Helicopters 36 Jul 09, 2009 11:01 PM
Discussion Blade CX2 Tx's - Can they be adapted to fly indoor/park flyers Sirion Electric Plane Talk 11 Apr 19, 2009 07:52 PM
Question How to program my dx7 to fly blade cx2? topforce Coaxial Helicopters 4 Sep 23, 2007 09:13 AM
Discussion How do I use my ICE to charge my batterys for blade CX2??? webejpn01 Electric Heli Talk 2 Jan 26, 2007 01:02 PM
Discussion How to learn to fly inverted with the Blade CP? Crazyrcer Micro Helis 4 Apr 05, 2006 12:59 PM
