Joined Jan 2007
Has anyone tried simply removing the flybar weights, but keeping the length the same? Maybe someone out there who remembers their physics classes can calculate the moment of inertia with the weights both in place and removed. You can equate removing the weights as the same as shortening the bar (with the weights) by "x" amount.
HELP!! Please
My CX keeps yawing left. I've trimmed the pot,I have removed the 4in1 from case, the upper blades spin faster than the lower (should be yawing to the right). everything seems good no cracks or broken parts, the blades are balanced, there isn't any binding, I've lubed the bearings. I don't know what to do. Thankfully I don't have a sledge hammer nearby or it would be paper thin by now! Does anyone know what could be causing it. |
Reducing BLAD CLASH by shortening lower blades
Hi all!
I finally had the opportunity to fly my CX2 outside with the shortened lower blades. They were originally 6.125" long, they are now 5.5" long. I didn't have any blad clash at all! Now, I'm not sure what a 'reversed piro, head-up-tail-down with a difficulty level of 9.99' exactly is -- hopefully, Diggs will send us some video -- but I tried full foward then a quick back without clash! There definitely seems to be greater response and faster forward/backward motion. I have not changed the airleron pin holes (yet). Then all the mishaps started to occur. The first broke a lower blade so I tried trimming it to 5.75" long -- I used a stationery belt/disc sander. The disc makes quick work of the blade. Tried the new lower baldes, heard a couple of clicks when the blades clashed. Did I stop to shorten them? Of course not Like an idiot, kept flying until BANG Why don't we ever learn? Well I beat the heck out of blades and the heli came crashing down. So, 5.75" appears too long, I'm sticking with 5.5" for the lower blades and leave the uppers alone.--------------------------------------------------------------------- Blade Balancing: I'm sorry to repeat this, but for those that don't know, make sure your blades are balanced! I had to replace one of my upper blades (Saturday was not a good flight day for me). When I started up the blades, the heli vibrated worse than it ever did - with just the upper blades spinning. I took off the flybar, straightened it out. Still vibrated. Took out the inner shaft, checked it. Still vibrated. Took off the flybar and the inner shaft again. Still vibrated. Then I decided to check the balance of the upper blades. I read somewhere to take to mugs and place them next to each other. Place the two blades together and let them straddle the mugs on each ball joint. The one blade swung way down! Then I noticed there are numbers on the base of each blade -- one was a "2" and the other a "3"! The two was much heavier. In the new bag of 4 blades, two had "2" and the other "3". After I paired them up, hours of frustration trying to eliviate shaking were gone! --------------------------------------------------------------------- Batteries My Common Sense batteries came in. They don't fit very well and I'm not about to cut up the CX2 fuselage! For now, I wrapped a pair of rubber bands around the 'short wings', under the body and cradled the battery there. It's a quick fix and doesn't appear to change the flight characteristics. And, it was real easy switching the pins on the connector. --------------------------------------------------------------------- Well, hope all this helps someone. You folks have helped me a lot, I'd like to try and contribute what I can. Have a great evening! Robert |
Diggs |
Then, when the other lower blade got clipped in a blade clash after I moved my servo up one hole, I ended up taking them both down to 5.5". That length was purely by accident (no pun intended ) Quote:
• DN Power 10C 900mAh 7.4v 2S - For Blade CX ($19.95) -- does this fit perfectly or not? -- this is rated 10C but some folks swear they are more like 15C • Mega Packs - they come in 10C and 15C -- some say it fits without taking out the foam between the two batteries -- isn't there a reason for that foam? Like to keep the two batteries separated and cooler? • Common Sense - that's what I just got -- they don't seem to fit -- they are 10C (I'm pretty sure) -- they are cheap! Hey, gotta go. I'm at the office working late (Okay, not really working, reading through all the threads) and it's getting late... Talk at you all later! Robert |
Adjusting Servo Linkages
I posted what I belive is a good description on adjusting servo linkages at http://www.rcgroups.com/forums/showp...04&postcount=8. I have seen many posts asking about this and this should describe the procedure very well with a picture for all that are trying to tune their BCX/2 to hover well. I have my BCX2 tuned in and can hover with no hands for at least 10-15 seconds with zero or very minor drift after fine tuning with the trims on the Tx.
klondikes |
True RC 900mah 12mm x 25mm x 67mm 40 grams $20 plus $1 shipping for any amount. http://home.comcast.net/~truerc/read...eady_packs.htm Thanks; Rod |
| Thread Tools | |
| Discussion to buy or not to buy the blade cx2 | airhead225 | Coaxial Helicopters | 36 | Jul 09, 2009 11:01 PM |
| Discussion Blade CX2 Tx's - Can they be adapted to fly indoor/park flyers | Sirion | Electric Plane Talk | 11 | Apr 19, 2009 07:52 PM |
| Question How to program my dx7 to fly blade cx2? | topforce | Coaxial Helicopters | 4 | Sep 23, 2007 09:13 AM |
| Discussion How do I use my ICE to charge my batterys for blade CX2??? | webejpn01 | Electric Heli Talk | 2 | Jan 26, 2007 01:02 PM |
| Discussion How to learn to fly inverted with the Blade CP? | Crazyrcer | Micro Helis | 4 | Apr 05, 2006 12:59 PM |
