I've not modded my throttle yet. But I probably will (in about 10 minutes from now..
![]() ). I had planned to pick up a CX v1 72mhz 4in1 so that I could fly it from one of my evo radios. I don't have anything against DX, but I sure like those evos... Anyway.. I've put that on hold until I can find a 4in1 that is of quality. I hear of so many problem from the CX v1 4in1s, and today, I read the article about them flying away.. ![]() So.. If anyone knows of a good 4in1 that would fit the bill.. please let me know!! I might go to separates instead, but if I do that, it will be a while, as I've got a few other projects I got to get done first... --------------------- My vortex motors were tighter then the stock CX2 motors, but by no means overly tight. They certainly have more cog then the stockers as well, but again, they would easily spin when given a test. I cant comment on the loudness of them. I didn't think they were any quieter then the stock ones, but my head's packed full of snot from a horrible head cold, so everything sounds like it's under water... The motors I got head stickers wrapped around them, so I pealed the stickers off and stuck my CX heat sink on them. The lipo took back in about 700 mahs, so the pack was pretty much drained after the flight. I didn't time it as I flew as the first few minutes were spent re-trimming it. I know I had at least 8 mins cause I was waiting for the sopranos to come on (started on A&E tonight.. ). I did the trims at about 7:45 and took to the air at 7:50. Chased the pets a bit and landed back on the desk at 7:57. I'm counting one minute for the trims, but I know I had more...Tomorrow I will know more. I'll give it the gusto and see how long I can keep it going. -------------------- The flybar I picked up from BP was a metal flybar with weights at the end of it. I didn't see a carbon on.. Nice touch of bling.. but after hitting the coffee table a few times tonight, I don't know that a carbon one would work for me. Maybe in a few weeks.... Might try to find one when I put the tail boom and a new canopy on it. |
Thanks! Diggs |
Hmm, all the flybars I have seen on the vortex were CF. But I might add one of the shorter metal ones when I pick up the outer shaft. I want to try this bird out and see how she compares to the CX2. Any of you guys get Stersmans tail boom in yet? Diggs |
My BCX2 Mods
I am a newbie having purchased a BCX2 just after Chritsmas. I have been reading the posts here at RC Groups and have learned a lot. Thanks to all of you that post this great imformation.
The mods I have made so far are: 1) Reversed the metal clip on the Tx throttle control to eliminate the clicks 2) Moved the servo pushrods out 1 hole on the servos 3) Installed the inner shaft w/aluminum head 4) Installed the aluminum bearing holder w/bearing 5) Installed the main motor heat sink 6) Cut a flap in the canopy for additional motor cooling (see below) For the additional motor cooling I cut along both sides of the upper windshield on the canopy and then across the curved top of the upper windshield. I folded this section down. The edge of this flap fits neatly under the heat sink directing the rotor wash directly onto the heat sink and motors. I can not measure the temperature but before the mod the motors were very hot to touch after flying through 1 battery. With the cooling mods, after flying for 1 battery the heat sink and motors are warm to touch. A drastic difference IMHO. I have tried to attach a picture below showing this mod. After several crashes and many main rotor blades and a main rotor hub I started using the online lessons from Radd's School of Rotory Flight at http://www.dream-models.com/eco/flying-index.html. I got the thread from a post here at RC Groups. That has helped a lot. I have the aluminum main rotor hub and the aluminum swashplate on backorder. Hopefully they will arrive soon. The 2 Mega Power batteries I ordered from HeliDirect.com are to arrive today. I have adjusted the servo pushrods and the 2 pots on the 4-in-1 and with the trim controls set at center on the Tx my BCX2 hovers rock solid. I have had no problems as some posts have stated with my BCX2. It worked perfect right out of the box. Well, actually it crashed a lot but that might have been influenced by my lack of piloting skills. I am having fun and looking forward to piloting more advanced heli's in the future. klondikes |
Shortening lower blades
Good morning to all!
I finally had the chance to trim the lower blades to make them both shorter after a previous crash shortened one of them and a blade clash toar off the other. Both lower blades are now trimmed shorter than their original length. Here's the specs: Upper blades: 6.125" base-to-tip (original length) Lower blades: 5.5" base-to-new-tip (trimmed) #1) I used a good blade as a pattern to draw the curved tip onto the lower baldes that had been torn. #2) Use a sanding block with 80-100 grit paper - go slow. If the edges are jagged like mine were, I sanded from different directions until the edges were smooth. Take your time so you don't make a crack in the blade worse by catching it and ripping it more. #3) After that, I finished off using a medium grit sanding sponge. That's just the wood working in me I guess! I put everything back together. I had to trim the pots again -- I'm guessing due to the different torque/load on the motors because of the smaller blades. Flight was smooth, no blade clash! But please remember, I only had a chance to fly in my living room, so I did the best I could from going quickly forwad to backward to forward again, trying to get the blades to hit. I'll know better when I can take the heli outside or fly in a larger indoor arena. Someone had asked earlier, I only moved the elevator trim out one hole -- I left the airleron alone. So reducing the size of the lower blades may be a viable alternative -- and a simple solution -- to blade clash . There was no way I experimented with an exact length to shorten. The final size was due to how much I had to take off before the tip was void of any tears. So you may not have to trim it to 5.5". But for now, it seems to work!--------------------------------------------------------------------- Battery question: By the way, can any one tell me if you need to make any modifications to fit the common sense battery? I saw on a thread where the manufacturer posted detailed instructions on their web site as to the steps necessary to get a good fit. But that included trimming the canapy, cutting the battery holder and using either tie wraps or velcro. I'm hoping I don't need to do any of that. And, what about the mega packs I keep hearing about, can you just take out the spacers and electric tape them back to fit? --------------------------------------------------------------------- Hey Numbskull: Can't wait to hear your results after you try the new Vortex's at work! --------------------------------------------------------------------- Welcome to Kondike! --------------------------------------------------------------------- Have a great day all! Robert |
| Thread Tools | |
| Discussion to buy or not to buy the blade cx2 | airhead225 | Coaxial Helicopters | 36 | Jul 09, 2009 11:01 PM |
| Discussion Blade CX2 Tx's - Can they be adapted to fly indoor/park flyers | Sirion | Electric Plane Talk | 11 | Apr 19, 2009 07:52 PM |
| Question How to program my dx7 to fly blade cx2? | topforce | Coaxial Helicopters | 4 | Sep 23, 2007 09:13 AM |
| Discussion How do I use my ICE to charge my batterys for blade CX2??? | webejpn01 | Electric Heli Talk | 2 | Jan 26, 2007 01:02 PM |
| Discussion How to learn to fly inverted with the Blade CP? | Crazyrcer | Micro Helis | 4 | Apr 05, 2006 12:59 PM |
