Yeah, I am stoked about trying some upgrade parts. I took my first maiden flight in the living room tonight. I was a bit worried, but after a little shaky lift off, I was hovering around the small room with no problems. It was extremely challenging. It is a larger area than my garage, but furniture, LCD TV, and just more stuff to run into. Your crash caused more damage than my big one. Although I put a hole in the nose of the front canopy also. BTW, UTAH rocks, I love that state. Was knocked over last year when I visited it for the first time. Bryce, Zion, Capitol Reef, Lake Powell and Arches Park... WOW. Plan on renting a house boat for a week this year at Lake Powell. I rarely use my aileron. I don't find situations where I need it really. I like having it though! nice to scoot away from a wall. I am sure it would change the dynamics of my flights if I learned to use it properly. I am sure things will be different once I step up to a FP or CP. I haven't really researched the next step as of yet. I need to, would like to get the radio for it so I can hook it up to my Phoenix flight sim. The 4 Channel doesn't cut it really. But yes, I also see myself moving to a more difficult Heli when the weather warms. I want something I can fly in a little more wind than the BCX2. I guess the CP would be the right choice since it will force me to learn to really fly a Heli. Oh, and with all my repairs, I am well on my way to joining an RC pitt crew ![]() Diggs |
Diggs |
DN Charger again
I have had a few questions about my DN charger and how it works. All I can say is that I bought another one tonight. That about says it all. I bought this combo
DN Charger with A/C Adapter Tonight I charged 2 of the Mega Power packs in one hour hooked up in the configuration I posted earlier. It works like a champ. My stock pack is still charging on the stock charger and will likely take an hour more for it to complete. I have 4 of DN 10C 900MAH on the way as well. The Megas are out of stock and I went ahead and got another set from Jun since he has helped me so much with batteries and chargers. I just need to know if I can modify the Vortex to run on BCX2 packs. I certainly hope so since I will have several and shouldn't need to buy more for the other heli. I am sure they are interchangeable, but the holder will probably need to be changed. Sorry to keep posting multiple posts at the same time, but only have so much time at night to make replies and such. If anyone has questions about that charger let me know. There is a good thread about it here as well. Diggs |
Hey guys,
Not to get off topic with the other questions but I've got a little situation on my hands here... I work at a the LHS, and have torn apart/trimmed/rebuilt/flown CP,CP pro's, Cx, and Cx2's more times than ANYBODY should have to, haha. BUT... A customer brought his in the other day adter he rebuilt his own after a crash, and it now has a HUUUGGEEE toilet bowl effect. I've never seen anything THIS BAD before, it's not even controllable!!! But im hoping that some of you heli wizards can help me out here. What can I do to fix it??? Thanks in advance, Vic. |
Hey Vic, You might check that the bearings for the inner shaft and outer shaft to see if they have froze up or check to make sure the shafts are spin "freely". If one of the shafts is bound, it would cause one set of blades to spin slower then the other.
Cant promise that it's the problem, but might be a start. |
Joined Jan 2007
Hi Diggs.. This is great. I need new batteries, and a charger that can do 2 batteries at the same time, now that's even better! When you say "Tonight I charged 2 of the Mega Power packs in one hour hooked up in the configuration I posted earlier." .. do you mean this post I cut and pasted below? * Do all the batteries charge on the DN charger without any special adapters?(i.e. stock eFlight, Mega Power, etc) * Do I need to buy anything else besides the charger and the power supply? Correct me if I'm wrong, but the only benefit of using the DN (or Commonsense) charger is the speed at which the batteries are charged (and of course the abiltity to charge 2 at the same time). --- Your Post with instructions to use the DN --- 1. you will use the 2s and 4s charging port. 2. if you want to charge 2 CX packs from us, you need to use reverse adapter. our CX pack has one. 3. as you can see on the picture, one of the battery used a 2s-4s adapter. that adapter is just to convert a 2s connect to a 4s connect, so it can be plugged into the 4s port. but actually, you don't have to use this adapter, you can just plug the 2s connector into the 4s port by forcing it. it will be OK. 4. when plug into the 4s port, always align to the right, since the 2s port will use the 1st and 2nd charging channel. and when you plug another 2s pack in to 4s port, you need to use the 3rd and 4th channel, that's why you have to align to the right. 5. my suggestion is, plug one 2s pack into the 4s port first, if you can see the voltage reading on cell 3 and cell4 on the LCD, then plug the other 2s pack into the 2s port. 6. once you've seen the 4 voltage readings on the LCD, that means you connected them correctly. now you can start using it |
I tried going to SSS' web site. There is no mention of a MAC version. I went to Yahoo Groups -- I'm not familiar with how that works. But saw some recent threads of those trying (and not having too much luck) with a MAC version. Can't seem to find where I can download this. Any help sure would be appreciated! Thanks... Robert |
Joined Jan 2007
Tip of center shaft that holds flybar broken from crash / torque
Hi everyone,
I had a really subtle crash, and must have clipped the flybar on my CX2. As a result the torque sheered the very tip of the shaft (the 'Stabilizer Flybar Hub/Holder' - #006 from the Exploded View Parts Listing) off that holds the flybar on. I glued it back on with super glue, and the choper flies just as it did before the crash... But... What do I have to order to replace this part? Just the part mentioned above (#006) or the the whole rotor head and inner shaft (part #007) + part #006? Thanks in advance, Mike. |
Joined Jan 2007
Flight simulation for Blade CX2
Hello everyone,
As a follow up to my last post regarding the requirements to hook the CX2's LP5DSM TX up to my PC for use with FMS, it's actually very simple! No need to buy a fancy USB cable. Maybe it's better (I already ordered it, so I'll let you know once it arrived), but it's A LOT MORE EXPENSIVE!! Simply use a standard 1/8 Stereo Male / Male Mini Plug patch cord/cable. Plug it into the trainer port. Download SmartPropoPlus and install it (it comes with VERY good instructions that are easy to follow). Calibrate the joystick in FMS according the instructions that come with SmartPropoPlus. The only thing that may throw you off is for the most part, a MONO cable is referenced (for other types of controllers.. JR?) You Must use a Stereo cable with the LP5DSM. I found it VERY easy to set this up, especially with the instructions that come with SmartPropPlus. Unfortunately for Peregrine Falcon, SmartPropoPlus only works on PC. Maybe your father can use this setup (at least until his USB cable arrives) Best regards, Mike. |
Joined Jan 2007
Flying on less than a full charge
Hello everyone... Yes, me again. Sorry!
There have been a few times now that I just want to show someone my heli, but the Battery is not completely Charged. Does it damage the battery to use it on less than a full charge? And... I don't mean using it after 10 minutes of charging.. I mean using after 1.5 hours on the charger, but the charger hasn't indicated a full charge. If I were to use the Heli for a few minutes, and put the battery back on the charger, is this bad? I don't know much about LiPo batteries.... I suppose I should just reasearh LiPo's on the web.. maybe I'll do that too. Thanks! Mike. |
Yes that is the same post. The photo at the bottom shows how to connect batteries. I am using Mega Power and the stock E-flite batteries now. To use them I must use the polarity inverter adapters that came included with the charger. I connect the 4s inverter to the 4s port, and then plug in a battery, it shows up in in the LCD screen, I then plug another inverter into the 2s port and plug the battery and the voltages show, So all 4 cells are displayed. I set the charge to 1C or .8 and click start. In just about one hour both batteries are charged. So you need to buy NOTHING other than the charger and a power supply to charge a pair of batteries simultaneously. Hope that helps, Diggs |
| Thread Tools | |
| Discussion to buy or not to buy the blade cx2 | airhead225 | Coaxial Helicopters | 36 | Jul 09, 2009 11:01 PM |
| Discussion Blade CX2 Tx's - Can they be adapted to fly indoor/park flyers | Sirion | Electric Plane Talk | 11 | Apr 19, 2009 07:52 PM |
| Question How to program my dx7 to fly blade cx2? | topforce | Coaxial Helicopters | 4 | Sep 23, 2007 09:13 AM |
| Discussion How do I use my ICE to charge my batterys for blade CX2??? | webejpn01 | Electric Heli Talk | 2 | Jan 26, 2007 01:02 PM |
| Discussion How to learn to fly inverted with the Blade CP? | Crazyrcer | Micro Helis | 4 | Apr 05, 2006 12:59 PM |
