The Pentax, Nikon and Canon cameras and the Aiptek MPVR that I've tested with take the picture right away when triggered using IR. Only the Olympus seems to add a 3 second delay.
http://www.hexpertsystems.com/prism MX |
To hardwire the system:
1) Buy a radio controlled relay switch from DimensionEngineering (http://www.dimensionengineering.com/PicoSwitch.htm) 2) Cut 2 lengths of wire and connect the end of each one to the relay switch 3) Solder the other end of both wires to the shutter switch on the camera circuit board 4) Plug-in the relay switch to the gear or aux channel on your receiver Now all you need to do is flick the gear (or aux) switch on your transmitter to take the picture. The Aiptek camera is cheap and easy to modify for this. |
Adelaide, South Australia & Melbourne Victoria
Joined Jun 2004
Hi Dennis, I posted this hardwire mod some time back,
http://www.rcgroups.com/forums/showt...01#post2306525 If the link doesn't work, just search for 'Samsung 401'. I hope it helps you. Many shops here have an 'unconditional money back if not happy' policy. Buy a camera you like and pull it apart to try the hardwire mod. If it doesn't work, return the camera (but put it back together first!) Andy |
