This thread is privately moderated by Ron van Sommeren, who may elect to delete unwanted replies.
Old Mar 27, 2011, 09:35 AM
Ken Myers is offline
Find More Posts by Ken Myers
Ken Myers's Avatar
Commerce Township, MI
Joined Aug 2001
Ascent 450 Brushless PNP by E-flite
http://www.horizonhobby.com/Products...700#quickSpecs
Max. wt. 19 oz.
Wing area: 330 sq.in.
CWL 5.48 oz./cu.ft. CWL Level 3 – low end
Extra 260 3D 480 ARF by E-flite
http://www.horizonhobby.com/Products...475#quickSpecs
Max. wt. 29 oz.
Wing Area: 375 sq.in.
CWL 6.90 oz./cu.ft. CWL Level 3 – high end
Typical 3D airframes have a lot more in common with powered gliders than they do with prop powered planes that ‘fly on the wing.’
35% Extra 260 ARF (2 Boxes) by Hangar 9
http://www.horizonhobby.com/Products...000#quickSpecs
Max. wt. 30 lb. (480 oz.)
Wing Area: 2003 sq.ft.
CWL 9.25 oz./cu.ft. CWL Level 4 – high end
CWL Excel worksheet at
http://homepage.mac.com/kmyersefo/M1...cnewtheory.xls
Level 1 CWL up to 3 oz./cu.ft.
Level 2 CWL 3 oz./cu.ft. to 5 oz./cu.ft.
Level 3 CWL 5 oz./cu.ft. to 7 oz./cu.ft.
Level 4 CWL 7 oz./cu.ft. to 10 oz./cu.ft.
Level 5 CWL 10 oz./cu.ft. to 13 oz./cu.ft.
Level 6 CWL 13 oz./cu.ft. to 17 oz./cu.ft.
Level 7 CWL 17+ oz./cu.ft.
The spreadsheet clearly illustrates, with 100s of recorded real life examples, which ‘types’ of planes are found in which Levels.
Ken Myers is offline Find More Posts by Ken Myers
Old Mar 31, 2011, 10:20 PM
apucjames is offline
Find More Posts by apucjames
Joined Mar 2009
What size prop do I need to use on an Eflite Power 90 running on 6s, 5000mha to obtain 1,100 Watts? Example 16x10 APC Electric. Called Horizon and they have nothing. Thanks for any help I can get to save buying $10 props and trying to find the right one.
apucjames is offline Find More Posts by apucjames
Old Apr 01, 2011, 02:54 PM
snoopy_schulz is offline
Find More Posts by snoopy_schulz
snoopy_schulz's Avatar
Germany, lake of constance
Joined Oct 2010
Hi apucjames
You need a 18x8 APC E prop.
Best regards
Micha
snoopy_schulz is offline Find More Posts by snoopy_schulz
Old Jun 27, 2011, 03:20 AM
Fourdan is offline
Find More Posts by Fourdan
Fourdan's Avatar
Antony (France)
Joined Sep 2003
Originally Posted by snoopy_schulz View Post
Hi apucjames
Best regards
Micha
Hi Micha
When I try to visit the website snoopy-schulz.square7.ch
my security software is warning "this website is dangerous"
What is your opinion about that ?
Louis
Fourdan is offline Find More Posts by Fourdan
Old Jul 08, 2011, 01:31 AM
Joined Oct 2010
Originally Posted by Fourdan View Post
Hi Micha
Louis
Hi Louis
There is no danger. I use a java script for the calculation, so your security software may issues a warning due to the java script. My drive calculator is only running with the windows internet explorer. With firefox it is not running.
I have tried anything, but it dont works. Maybe something in my java script is not ok for other explorer?
Best regards
Micha
Old Jul 08, 2011, 07:15 AM
Joined Oct 2010
Java Script of my drive calculator
Hi
Here is my java script. Maybe someone has an idea why it is not running with
firefox.
Best regards
Micha
Code:
<!-- Begin
var list=0
var KennWerte=new Array();
var ke=0; var iL=0; var Rm=0;
var ke1=0; var iL1=0; var Rm1=0; var etag=0; var u=0;
var etag1=0; var ueb1=0; var nZ=0;
var Raccu=0; var Rg=0;
var KennWerteP=new Array();
var n100=0; var H=0; var D=0;
var KennWerteA=new Array();
var u_accu=0; var Ri=0;
function getRadios(what){
 if(what.sel.checked) list=1.0
 else list=0.0
function DoCalc(form) {
motor=form.m_type.options[form.m_type.selectedIndex].value;
KennWerte=motor.split("/");
ke1=KennWerte[0]*1; iL1=KennWerte[1]*1; Rm1=KennWerte[2]*1;
ueb1=KennWerte[3]*1 ;etag1=KennWerte[4]*1;Kflug=KennWerte[5]*1;
nZ=eval(form.nZ.value);
propeller=form.p_type.options[form.p_type.selectedIndex].valuep;
KennWerteP=propeller.split("/");
n100=KennWerteP[0]*1;
H=KennWerteP[1]*1;
D=KennWerteP[2]*1;
//document.write("Kp : " + Kp )
Akku=form.accu_type.options[form.accu_type.selectedIndex].value_accu;
KennWerteA=Akku.split("/");
u_accu=KennWerteA[0]*1;
Ri=KennWerteA[1]*1;
// war Akku ausgewählt ?
if (u_accu == 0)
   {alert("Please choose a accu!")}
// is gearbox defined ?
if (etag1 != 0)
  {etag = etag1}
else
  {etag=eval(form.etag.value)}
if (ueb1 != 0)
   {ueb = ueb1}
else
  {ueb=eval(form.ueb.value)}
// is motor defined ?
if (ke1 != 0)
  {ke = ke1}
else
  {ke = eval(form.ke.value)}
if (Rm1 != 0)
  {Rm = Rm1}
else
  {Rm = eval(form.Rm.value)}
if (iL1 != 0)
  {iL = iL1}
else
  {iL = eval(form.iL.value)}
// check whether Gear, Motor and Prop changes have been made
if (ueb == 0)
   {alert("Enter gear ratio: '1' for direct drive")}
if (etag == 0)
   {alert("Enter gear efficiency: '1' for direct drive")}
if (ke == 0)
   {alert("Enter rpm/V!")}
if (iL == 0)
   {alert("Enter No load current !")}
if (Rm == 0)
   {alert("Enter internal resistance!")}
if (n100 == 0)
   {alert("Enter Prop!")}
// update displayed characteristics
form.ke.value=ke;form.iL.value=iL; form.Rm.value=Rm;
form.etag.value=etag; form.ueb.value=ueb;
// Start of the caculation
var Raccu=nZ*Ri;
var Rg=Rm+Raccu+0.01;
var U=nZ*u_accu;
var Ke=1/ke;     // V/rpm
var Ishort=U/Rg; // blocking current
// Prop speed
var Kp=100
var ueb=1/ueb
var RPMa=(Math.sqrt(Ke*Math.pow(n100,3)*U*(4*Ishort*Kp*Math.pow(Rg,3)*Math.pow(ueb,3)*(Ishort-iL)+Math.pow(Ke,3)*Math.pow(n100,3)*U))- Math.pow(Ke,2)*Math.pow(n100,3)*U)/(2*Ishort*Kp*Math.pow(Rg,2)*Math.pow(ueb,3)/Math.pow(etag,0.333))
// efficiency and shaft power
var Pw=Math.pow(RPMa*ueb/n100,3)*100; // shaft power
var Im=(Ishort-Ke*RPMa/Rg)///Motor current
var Uk=U-(Raccu+0.01)*Im // terminal voltage ot the motor
//var etam=(1-Im/(Uk/Rm))*(1-iL/Im); // Max efficiency motor
var etam=Pw/Uk/Im; // efficiency Motor incl. gearbox
var etamg =Pw/U/Im; // totall efficiency
var Pv=Rm*Im*Im // Pv of motor coil
var nm=RPMa; // Motor speed
var Vp=H*(2.54/100)*ueb*RPMa/60 // prop pitch speed
var HD = H/D
var J =0.2421 * Math.pow(HD,3) + 0.439 * HD + 0.1546
var Vf = J * ueb * RPMa * D * 0.0254 / 60
var Dm = D * 2.54 / 100
var F = 0.785 * Math.pow(Dm,2)
var S1=0.55*Pw;
var S2=Math.pow(S1,2)
var S3=(2 * 1.24 * F * S2)
var S = Math.pow(S3,0.333)/9.91
var nop = U*ke*0.66
//var eta_prop = (-13.984 * Math.pow(J,2) + 43.59 * J + 48.1189)/100
if (RPMa < nop)
   {alert("Motor is overloaded!\nUse Motor with lower Kv, or prop with less diameter or less pitch.")}
form.nw.value=Math.ceil(RPMa*ueb)
form.nm.value=Math.ceil(nm)
form.etam.value=Math.round(etam*100)/100
form.etamg.value=Math.round(etamg*100)/100
form.Pv.value=Math.ceil(Pv)
form.Im.value=Math.round(Im*100)/100
form.Pw.value=Math.ceil(Pw)
form.Uk.value=Math.round(Uk*100)/100
form.Vp.value=Math.round(Vp*100)/100
form.Vf.value=Math.round(Vf*100)/100
form.S.value=Math.round(S*10)/10
// End -->
Old Jul 08, 2011, 04:03 PM
Victory Pete is offline
Find More Posts by Victory Pete
Rhode Island USA
Joined Aug 2010
This thread has my head spinning, is there a basic formula to determine Prop size, Motor size, ESC rating and battery size for a specific plane.
VP
Victory Pete is offline Find More Posts by Victory Pete
Reply With Quote  (Disabled)
Old Jul 08, 2011, 04:30 PM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
VP
Do you have the airplane? Try entering the info on it here:
http://flbeagle.rchomepage.com/softw..._imperial.html
There are different ways to approach or do it. If you have a plane and know the prop that is about right for it, you can work it from there but you also have to make some decisions too.
How long do you want to fly?
Do you want to fly a fast and maneuver aggressively?
Do you want to just cruise the pattern and fly touch and goes?
Jack
jackerbes is offline Find More Posts by jackerbes
Old Jul 09, 2011, 02:11 AM
jgalexander is offline
Find More Posts by jgalexander
Flying Full Size & Fun Size :)
jgalexander's Avatar
United States, CA, Calabasas
Joined Apr 2010
VP
Pete, the only way I've been able to determine all of the above is through trial and error. I use this calculator from Castle Creations - it makes sense to me, and has data preloaded for lots of common motors/ESCs (or you can choose 'custom' and input your own data).
Best,
Josh
http://www.castlecreations.com/suppo...alculator.html
jgalexander is offline Find More Posts by jgalexander
Old Jul 09, 2011, 12:54 PM
Joined Oct 2010
Hi Victory Pete
There is no basic formula to determine Prop size, Motor size, ESC rating and battery size for a specific plane.
In the attachment I have an easy procedure to calculate the inputs needed for some e-flight calculators,
but it is only a rough estimate. The aim is to calculate the basic requirements for a good motor and prop selection.
Best regards
Micha
Old Jul 09, 2011, 12:57 PM
Rhode Island USA
Joined Aug 2010
Thanks for the help guys!
VP
Old Jul 12, 2011, 08:53 PM
lazy-b is offline
Find More Posts by lazy-b
Manila, Philippines
Joined Jul 2004
Guys, I have notice that most of the Flight Calculator is designed for Airplane only.
I have use the Flight Calculator created by Castle Creation on my Helicopter, its very accurate in predicting the Flight time.
I've been experimenting with different Battery Configuration from 6S,7S,8S,10S....by entering the Weight of Helicopter, Motor, Speed Controller, Rotor Diameter, Gear Ratio, it can compute the Flight Time, efficency of motor and even give you graphical display.
lazy-b is offline Find More Posts by lazy-b
Old Jul 13, 2011, 04:57 AM
Fourdan is offline
Fourdan's Avatar
Antony (France)
Joined Sep 2003
Hi
The accuracy is limited by the accuracy of manufacturers regarding the motors
Rm (milliohm)
Kv (rpm/V)
Io or iron losses (generally Io for only one voltage, in fact Io is depending of rpm)
In Scorpion Calc, Dualsky Calc, Motrolfly Calc I have tested 95% or 100% of motors on my bench. Motor data are coming from testings.
Same for Dr Kiwi tables and results.
But anyway CC emotorcalc is very well done and useful for a "ball park prediction"
Louis
Old Jul 13, 2011, 09:54 AM
Joined Oct 2010
@ Fourdan
Today I have compared my own drive calculator with the Scorpion_Calc V3.43.
There is only a slight differenence between both calculators.
Best regards
Micha
Old Jul 21, 2011, 12:15 PM
eJets is offline
Find More Posts by eJets
electric power,what else!
eJets's Avatar
Joined Dec 2005
Statistical Spread
@Furdan
your bench testing must not necessarily generate better results than the munufacturer data as the manufacturing process it self leads to a statistical spread - to take this spread into account and smoothen the manufacturing spread you should have tested at least 5 to 10 motors of the same type - did you?
the mean figuers of the manufacturer resulting from tests over more than one motor of the same type - this is how the quality testing of the mufacturing process is done....
The Iron Loss is only indirect related to the RPM - It is related to the magnetic Cycles and these depends not only on the RPM but also on the numer of magnetic pols.
Further more the CC eCalc does extrapolate the Iron Loss (Io) from the mesured mag. cycles (@ Io Voltage) to the effectiv mag. Cycles (at operational Voltage) by using an adequat mathematic model.
nevertheless your Calc is also well done.....
cheers eJet
eJets is offline Find More Posts by eJets
Discussion e-flight calculators (compilation), internal link Ron van Sommeren Electric Plane Talk 0 Dec 05, 2006 08:25 AM
