This thread is privately moderated by Ron van Sommeren, who may elect to delete unwanted replies.
Old Jul 19, 2010, 07:27 AM
geeby22 is offline
Find More Posts by geeby22
Brittany Slopping
geeby22's Avatar
France
Joined Dec 2007
Bonjour Louis,
Je vais mettre à jour mes téléchargements de tes programmes de simulation dans les jours à venir (j'ai mes 3 petits fils à la maison ).
Ils fonctionnent merveilleusement bien et je les recommande à tous.
Geeby
geeby22 is offline Find More Posts by geeby22
Old Jul 19, 2010, 07:30 AM
geeby22 is offline
Brittany Slopping
geeby22's Avatar
France
Joined Dec 2007
Originally Posted by 3D-Dabbler View Post
Thanks Geeby! I just tried out the calculator and it seems to be giving me odd results. The recommended power setup is way Under Powered.
This was for a 70" 3D HobbyShop Slick. Here is what I entered. 3D flight, 4 kg, 61.3 sq. dm and 8S.
The results were 1350 W. That is way to low for 3D 1800 Watts to 2200 Watts is what I expected.
Battery capacity was fine but discharge rate was off. It recommended a minimum of 15C where I don't think I would fly with anything less than 20C on that setup.
Propeller was also off. It recommended 15.8 x 7.8. That will not move the plane. The smallest prop for 3D for a plane this size would be an 18x10.
Thanks 3D Dabbler,
My purpose was for middle plane. I will take into account your remarks for extrem 3D fly... with Abott formula the traction is too low ,)
However, the motor power is a "marketing" value, and I prefer use the weight.
For the discharge rate, it's the min value, and for reliability and durability, you take advantage to increase this value...
In any case, I will increase the power for 3D fly...
For the propeller, the pitch depends of motor kv...
Geeby
Old Aug 23, 2010, 07:22 PM
bob93447 is offline
Find More Posts by bob93447
United States, CA, South Lake Tahoe
Joined Sep 2006
Propellor Stall Thrust
I recently ran into the term "Propellor Stall Thrust" when using the calculator program on the Castle Creations web site. It's the first time I have seen the term and I was wondering if anyone could define it for me.
Regardless of the definition, the results presented are interesting. The program predicts a stall thrust which is typically much lower than the static thrust. It provides a warning for certain high pitch props that it is likely that the static thrust will not be reached; the prop is in a stalled state at the initial stage of takeoff. For something like an APC 12x12, the stall thrust can be as little as 40% of the static thrust prediction. For me it makes a tremendous difference in my motor/battery selections for the airplanes that I am flying.
Bob
bob93447 is offline Find More Posts by bob93447
Old Aug 24, 2010, 02:31 AM
eJets is offline
Find More Posts by eJets
electric power,what else!
eJets's Avatar
Joined Dec 2005
Hi Bob,
your propeller runs into the prop stall when Pitch : Diameter > 0.66 (you have 12:12 = 1!). with high pitch propellers the air looses contact to the propeller blade. this result in significant less thrust (you can even hear that as the propeller gets suddenly louder.)
in this case you will not reach the static thrust (and calculated current) on a static measurement - you rech only the Stall Thrust figure.
high pitched propeller makes only sence for speed models (like pylon). If you want to use this setup in a none speed model just stay below 0.66 pitch-diameter-ratio. so, the question now is what type of plane you want to fly....?
kind regards
eJet
eJets is offline Find More Posts by eJets
Old Aug 24, 2010, 11:23 AM
bob93447 is offline
Joined Sep 2006
ejet,
Thanks for the concise explanation. I started in electrics with the large, 71", Seawind. With a limited prop diameter, 13", and a motor with an upper limit on number of cells, I was trying to get thrust with prop pitch. Flying the Seawind off snow was not a problem, but getting it off the water, at high altitude has been a problem. Recently I switched to a higher kv motor with a higher cell count and a lower pitch prop with much better results. This is the first time I had seen the terminology and I am trying to correlate my emperical data with what I calculate.
Thanks again,
Bob
Old Sep 27, 2010, 05:47 PM
mRqS is offline
Find More Posts by mRqS
mRqS's Avatar
Venray, The Netherlands
Joined Oct 2003
Ron,
can you, please, contact me via priv message?
Thanks!
mRqS is offline Find More Posts by mRqS
Old Oct 04, 2010, 04:31 AM
bmblb is offline
Find More Posts by bmblb
Joined Oct 2007
Prop Size
Hello All,
I have a 1400Kv motor with a 18 A ESC and 11.1 Volt 1350 mAh battery. My plane weighs about 650 gms and I use a 6x4 prop. Even after a flight of about 5-6 minutes the motor and battery are cool.
Although a bit sluggish, the overall performance is satisfactory. I now plan to build another plane but atleast 150g lighter.
Can I use a 5x5 prop, now that the plane would be lighter ? Intention is to have a longer flight with a more efficient plane.
b
bmblb is offline Find More Posts by bmblb
Old Nov 09, 2010, 10:33 AM
Fourdan is offline
Find More Posts by Fourdan
Fourdan's Avatar
Antony (France)
Joined Sep 2003
About Web o Calc and CWL
Hi
It seems I cannot reply in the WOC thread (too old)
http://www.rcgroups.com/forums/showthread.php?t=930018
So if Flieslikeabeagle (John) is listening :
Data in metric
Weight 700g
Span 1370mm
Wing area 24 dm2
WOC leads to CWL = 4.4 g/dm3
I find CWL = 700 / (24^1.5) = 5.95 g/dm3
WL = 29.2 g/dm2 is correct
Regards
Louis
Fourdan is offline Find More Posts by Fourdan
Old Nov 09, 2010, 11:14 AM
habitforming is offline
Find More Posts by habitforming
ΜΟΛΩΝ ΛΑΒΕ
habitforming's Avatar
USA, KY, Hebron
Joined Dec 2005
Originally Posted by Fourdan View Post
Hi
Data in metric
Weight 700g
Span 1370mm
Wing area 24 dm2
Regards
Louis
You should be able to reply, you just have to hit the check box at the bottom of the page that says you acknowledge the thread is really old and you do want to respond
habitforming is offline Find More Posts by habitforming
Old Nov 13, 2010, 03:31 PM
flieslikeabeagle is offline
Find More Posts by flieslikeabeagle
Got shenpa?
flieslikeabeagle's Avatar
Los Angeles
Joined May 2004
Hi
Data in metric
Weight 700g
Span 1370mm
Wing area 24 dm2
Regards
Louis
Hi Louis, as it happens, I did log in today, so I found your post. Thank you for bringing up what you found, I appreciate your letting me know if you find an issue with WebOCalc.
However, in this particular case, what you found is not a mistake. There is in fact more than one way to calculate cubic wing loading, and some are better than others. I used a better way in WebOCalc.
Let me explain what I mean. Imagine two RC models, a powered glider and a scale Extra 260, both with the same total weight and same wing area. The glider will have far more wing span, with its long narrow wings, while the Extra has stubby broad wings typical for highly aerobatic aircraft. From practical experience, we know that these two models fly quite differently - the glider will feel much lighter and floatier than the Extra.
But if you calculate the wing loading or traditional cubic wing loading for both models, you get the same answer. In other words, the CWL says the glider and Extra will fly similarly - but in the real world, they do not. The CWL fails to do its job - it's supposed to predict how the model will fly, but it fails to do this accurately.
So, the traditional way of calculating the CWL is not very good. It's better than plain old wing loading, but it's still not very good. We can do better!
Here's what's going on. The goal of CWL is to allow for the fact that the airflow around the wing is three-dimensional, so that changes in wing span and wing chord also affect the airflow above and below the wing. Therefore, we need a formula that transforms the wing dimensions (dimensions of length squared) into a volume (dimensions of length cubed).
The simplest CWL formula is to simply raise the area to the power 1.5:
Code:
Effective volume = wing area^1.5
                       = wing area x square root of wing area
Therefore
CWL = model weight/effective volume
       = weight/(wing area^1.5)
This is probably the formula you used when you calculated cubic wing loading, as it is the most commonly used one. Unfortunately, it is not a very good formula!
Here's why: if you look at calculations or observations of the actual 3D airflow around a real wing, you'll find that changes in wing span cause a big change in the amount of airflow over the wing. The influence of the wing on airflow extends upwards above it to about half the wing span, so a wing with a 40 foot span substantially affects the airflow a good 20 feet above its center point. Also, increasing the span reduces the effect of wing tip losses, and this also produces a significant increase in lift - we all know that gliders have long, skinny, high aspect-ratio wings because they are more efficient at producing lift with less drag.
However, changes in wing chord do not have as big an effect on a wings efficiency. They do not affect the airflow around the wing and aerodynamic losses in the same way as increases in wing span. They do not help with the wing tip losses either. Adding more wing area by increasing the chord does not benefit the wing as much as adding area by increasing the span.
Now, the wing area is simply average span x average chord, but as we've just discovered, the two things (span and chord) are NOT equal when it comes to their effect on lift.
Therefore, a better formula for cubic wing loading would take this difference between span and chord into account. The wing span should be weighted more heavily than the wing chord when calculating the effective volume I referred to in the first paragraph.
We need an algebraic quantity with the dimensions of length cubed, but with wing span given more weight than wing chord. The simplest answer is to use (wing span x wing span x wing chord) - because the span appears twice in the formula, changes in span affect the product more than changes in chord, which is exactly what we want.
Using this, here's how we arrive at a better CWL formula:
Code:
Effective volume = wing span x wing span x wing chord
Therefore,
Cubic Wing Loading = model weight/(wing span x wing span x wing chord)
This is the formula used internally in WOC. I find it does a much better job of predicting the flight characteristics of the model than the more commonly used "dumb" CWL formula. If you put the wing dimensions of a glider and an Extra 260 with the same total wing area and same flying weight into WebOCalc, the program will tell you that the glider will fly "lighter" than the Extra, which is what you see in real life.
At this point, WebOCalc has been successfully used to predict, with reasonable accuracy, the performance for everything from sub-ounce indoor models to giant 20 lb and 30 lb models, everything from vintage biplanes to powered gliders to scale commercial jets. I myself have been surprised at how well the program handles this very wide range of airframe sizes and types, given how extremely simple the program is at heart. Using the more accurate calculation for CWL described above was a significant factor in getting the program to work as well as it does.
Incidentally, Ken Myers contacted me about this same issue a year or two ago, and he and I had almost this same email conversation.
By the way, I also found an error in the lift calculation used in a large number of RC calculators popular here in the USA. Everyone knows the basic formula for wing lift (L = 1/2 * Cl * rho * V^2 * S). Years ago someone plugged in Cl=1.0 and rearranged the formula to calculate V, the stall speed. So far so good.
But something went wrong numerically in converting that answer to miles per hour, given wing loading in ounces per square feet - I've forgotten the details now, but I remember finding the wrong formula all over the Internet, and that same wrong formula is also incorporated into a number of RC calculator programs I tried.
I found the error because I started out working out the formulae for WebOCalc in SI units (I didn't grow up in the USA). I worked out the formula for stall speed using the density of sea-level air at room temperature, and when I converted my answer to miles per hour, it didn't match the other calculators I compared it with. The stall speed I calculated is higher, for the same wing loading.
I went over my math several times and tried several sanity checks (wing loading of one newton per square metre, for instance), and eventually convinced myself that the mistake wasn't mine, but was in the formula used in so many other calc programs. So keep your eye open for inaccurate stall speed numbers floating around out there!
-Flieslikeabeagle
flieslikeabeagle is offline Find More Posts by flieslikeabeagle
Last edited by flieslikeabeagle; Nov 13, 2010 at 07:57 PM. Reason: Fixed some typos
Old Nov 13, 2010, 04:11 PM
Fourdan is offline
Fourdan's Avatar
Antony (France)
Joined Sep 2003
Hi John
Yes I was using the formula from Ken Myers's paper
Yours is another one
I am not a specialist of CWL
Louis
Old Dec 19, 2010, 06:25 PM
Melnic is offline
Find More Posts by Melnic
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
Everytime I think I know a bit about electric motors, I find another thread like this to read
I've been using the adamone calc but now I gotta read through this LOL
Melnic is offline Find More Posts by Melnic
Old Feb 07, 2011, 08:42 PM
Truglodite is offline
Find More Posts by Truglodite
Registered Aircraft Offender
Truglodite's Avatar
Carmichael, CA
Joined Feb 2007
I updated my spreadsheets recently... credits to the 'DCalc crew' for the constants.
Kev
Truglodite is offline Find More Posts by Truglodite
Old Mar 26, 2011, 03:28 PM
wdretired is offline
Find More Posts by wdretired
United States, AL, Madison
Joined Nov 2007
I'm trying to convert a Slinger 380 brushed motor over to a brushless motor and I'm about as lost as you can get. I know the prop, esc, and motor have to match up but there are so many that I'm having a hard time trying to figure out a good combination. What combination (esc, battery, motor, and prop) could I install that would get me in the air? wdretired. ..
wdretired is offline Find More Posts by wdretired
Old Mar 27, 2011, 07:29 AM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
Mention the prop size, the battery you were using before, and the amount of power you were using (volts x amps = watts) if you know any of that. All of that goes to getting a Kv that will work with the prop and a motor of a weight that will have enough power.
Jack
jackerbes is offline Find More Posts by jackerbes
Discussion e-flight calculators (compilation), internal link Ron van Sommeren Electric Plane Talk 0 Dec 05, 2006 08:25 AM
