This thread is privately moderated by Ron van Sommeren, who may elect to delete unwanted replies.
Old Mar 30, 2010, 03:56 AM
eJets is offline
Find More Posts by eJets
electric power,what else!
eJets's Avatar
Joined Dec 2005
@rotagen
it is not a matter of expensive or cheap motors - it's a matter of motor data availability, and this availability is the general problem of cheap motors....
feel free sending PM with motor data (Kv, Internal Resistance Ri, Idle Current Io, Power or Current Limit, Housing length and weight) of cheap motors.
Cheers eJets
http://www.s4a.ch/eflight/motorcalc_e.htm
http://www.s4a.ch/eflight/fancalc_e.htm
eJets is offline Find More Posts by eJets
Old May 09, 2010, 09:16 AM
MikeW9 is offline
Find More Posts by MikeW9
Joined Jan 2009
Brushless Motor Guide
I've been getting a lot of questions at my flying club after doing a dual powered combat Gremlin, mostly out on the field, about what size motor, battery, and ESC choices. so I wrote an article in our March DVRC newsletter to help explain in simple terms the basics of electric flight.
Then I followed up with a circular calculator for field use in our most recent May newsletter and a download if anyone else is interested.
http://www.dvrc.org/index.htm
MikeW9 is offline Find More Posts by MikeW9
Old May 09, 2010, 01:16 PM
Kokopeli is offline
Find More Posts by Kokopeli
Curiouser and curiouser
Kokopeli's Avatar
Rochester, NY, USA
Joined Oct 2005
Mike - downloaded the circular slide rule - printed and assembled.
There are probably way more uses intended in your design than those I can figure out myself.
I was looking on your club web site for the instructions for the slide rule and didn't find it.
I would guess that you did write up something for your club members - maybe in one of the newsletters?
Could you point me to it, if it exists.
Walt Bankes
Kokopeli is offline Find More Posts by Kokopeli
Old May 09, 2010, 05:31 PM
MikeW9 is offline
Joined Jan 2009
Walt Bankes
Walt;
The instructions are buried in the latest newsletter:
http://www.dvrc.org/newsletters/2010/0510/0510.pdf
Old May 10, 2010, 07:10 AM
GregG is offline
Find More Posts by GregG
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
Hey Mike, fancy meeting you here!
I've been a member of DVRC since 1993 and always flew electric power. Back in the early days I was considered a bit of an oddity for my E-power. It seems that I didn't get any respect until the planes that I was flying began to out speed the wet powered models. That was at our old field and the atmosphere around the club has taken a complete change since then, all for the betterment of the club.
Anyway, what 'm trying to say is it's really refreshing to see your work done to try and educate our members (and others) on electric power. Great job on your articles and publishing the E-power wheel. I hope that it takes off and gets a few more interested. Thanks for sharing and keep up the good work Mike!
Greg Gallegos
GregG is offline Find More Posts by GregG
Old May 10, 2010, 09:38 AM
MikeW9 is offline
Joined Jan 2009
Greg;
how do you get this posted on the front page so people will see it?
Old May 10, 2010, 10:30 AM
GregG is offline
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
To get it posted on the front page of this thread you'll have to ask the thread starter, Ron van Sommeren, if he will edit the 1st post to include your jewel of a calc.
If it was my work I'd do that AND start my own thread on this. The simple math required for this couldn't be made more simple. It really is great work you've done and worthy of it's own thread.
Old May 21, 2010, 10:57 AM
Ron van Sommeren is offline
Find More Posts by Ron van Sommeren
homo ludens modellisticus
Ron van Sommeren's Avatar
Netherlands, GE, Nijmegen
Joined Feb 2001
Mike, have you started your own thread? If so, I will add that discussion to my first post as well.
Prettig weekend Ron
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old May 27, 2010, 11:41 AM
MikeW9 is offline
Joined Jan 2009
Prettig weekend Ron
Ron;
don't know how to; don't know if I should...
I just thought I'd share my work with others.
Have you looked at the articles and the wheel to see if it's useful to others?
Old May 27, 2010, 11:23 PM
GregG is offline
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
Originally Posted by MikeW9 View Post
Ron;
Mike by all means start a new thread. Your wheel is super easy to use and will help many. Please do start a thread.
To start a thread simply push the button.
Old Jun 20, 2010, 03:44 PM
RoyLB is offline
Find More Posts by RoyLB
Joined Jan 2009
How about Martyn McKinney's spreadsheet, propeller23.xls
It can be found here:
http://www.rcgroups.com/forums/showp...postcount=1675
- Roy
RoyLB is offline Find More Posts by RoyLB
Old Jul 09, 2010, 02:18 PM
rimshotcopter is offline
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
This is excellent, thank you for doing such a great job.
rimshotcopter is offline Find More Posts by rimshotcopter
Old Jul 17, 2010, 07:22 AM
geeby22 is offline
Find More Posts by geeby22
Brittany Slopping
geeby22's Avatar
France
Joined Dec 2007
Moteur_calc
Hello,
Moteur_calc is a javascript calc to define the electric propulsion for a plane.
You have just to enter : flying weight, wing area, flying type and cells number.
On line (no download needed), you have all propulsion elements.
Please go to my blog (sorry, only in french ) :
Modelisme by geeby22
and clic on : "Calcul d'une propulsion électrique"
Sorry for my poor english language !
Geeby
geeby22 is offline Find More Posts by geeby22
Old Jul 17, 2010, 10:00 AM
3D-Dabbler is offline
Find More Posts by 3D-Dabbler
Just "hanging" Around
3D-Dabbler's Avatar
Richmond, VA
Joined Oct 2009
Originally Posted by geeby22 View Post
Hello,
Geeby
Thanks Geeby! I just tried out the calculator and it seems to be giving me odd results. The recommended power setup is way Under Powered.
This was for a 70" 3D HobbyShop Slick. Here is what I entered. 3D flight, 4 kg, 61.3 sq. dm and 8S.
The results were 1350 W. That is way to low for 3D 1800 Watts to 2200 Watts is what I expected.
Battery capacity was fine but discharge rate was off. It recommended a minimum of 15C where I don't think I would fly with anything less than 20C on that setup.
Propeller was also off. It recommended 15.8 x 7.8. That will not move the plane. The smallest prop for 3D for a plane this size would be an 18x10.
3D-Dabbler is offline Find More Posts by 3D-Dabbler
Old Jul 18, 2010, 05:28 AM
Fourdan is offline
Find More Posts by Fourdan
Fourdan's Avatar
Antony (France)
Joined Sep 2003
Hello,
Geeby
Bonjour Geeby
Tres bien ton calculateur ... simple ... pratique
Sur le blog il y a des téléchargements.
Scorpion Calc last version = 3.37
Regards
Louis
Fourdan is offline Find More Posts by Fourdan
Discussion e-flight calculators (compilation), internal link Ron van Sommeren Electric Plane Talk 0 Dec 05, 2006 08:25 AM
