Old Jul 24, 2001, 06:38 PM
E-Man is offline
Find More Posts by E-Man
Florida
Joined Jun 2001
Battery Internal Resistance
Can someone tell me how to get a rough measurement of battery internal resistance.
The Rint of most of my batteries seem to me to be much higher than advertised. Voltage loss seems excessive.
E-Man
E-Man is offline Find More Posts by E-Man
Old Jul 24, 2001, 09:09 PM
Quacker is offline
Find More Posts by Quacker
ClearView rocks Phoenix& Dubai
Quacker's Avatar
United States, CO, Longmont
Joined Jul 2001
You may be interested to learn that Sanyo and Panasonic both rate the battery impedance by a measurement made at 1000Hz AC. Annoyingly, if you measure it at DC (where it counts), it will be higher than the spec sheet. The impedance is also lowest when the battery is charged. You'll need a DC voltmeter and a resistor that draws somewhere in the neighborhood of your load in actual use. (Sorry, you did not state the nature of the battery or the load, so I can't help you here). To get a feel for the impedance, charge the battery then set it aside for a few hours or even a day to allow the voltage to settle. Measure and record the voltage with no load. Then, measure the voltage of the battery with the resistor across it. divide the loaded voltage by the value of the resistor (in ohms). This yields the current. Record this value. Still with me? Now subtract the loaded voltage from the unloaded voltage. This is the voltage difference (or delta) from unloaded to loaded. Divide this value by the current that you previously computed and voila! This is the impedance. Some my argue that the value is best computed from testing at two different load levels and not from unloaded to loaded. They would be correct in this argument, but this simplified method will get you close enough.
Regards...
Quacker is offline Find More Posts by Quacker
Old Jul 24, 2001, 10:06 PM
E-Man is offline
Florida
Joined Jun 2001
Thanks Quacker,
I'm using a R/S curve tracer for voltage readings, a Astro WattMeter for current, and either 2 or 4 12v 50W bulbs for a load. This gives me about 7 or 14 amps which I can cut in or out.
I calculated R using your method but for an old 8-pack of 1400SCR's it starts with a resistance of about 9mohms but increases to 35 or 40 as the pack is discharged. The current stays relatively constant as the voltage drops, making the R change radically.
I guess ist's best to just use 'em and not worry about the details too much.
Thanks again
E-Man
Circuit to measure battery internal resistance Leftyretro DIY Electronics 58 Nov 03, 2010 09:02 AM
Measuring internal resistance? JBowling Batteries and Chargers 3 Oct 09, 2002 11:20 AM
Qual Comm internal resistance Rob Hair Parkflyers 1 Feb 21, 2002 10:57 PM
internal resistance of 2/3aaa nimh? singlespeed7 Parkflyers 0 Nov 05, 2001 05:03 PM
