Go Back   RC Groups > Aircraft - Electric - Airplanes > Foamies (Scratchbuilt)
Old Dec 04, 2006, 05:39 PM   #1
Build 2 Bounce!
Bronze Member
Infineon EPP Bipe - Free Plans, Build Guide and Video
A couple of months ago Dave Royds (MrFlash) designed and built a full fuse EPP biplane for indoor pattern/3D flying based on a smaller mono he’d designed earlier. On its first outing it attracted the attention of the UK modelling press due to its clean lines and great flying characteristics. An all EPP construction and low wing loading made for a very slow flying model which was more durable than an equivalent depron airframe.
Having seen photos and video of the biplane, I decided I had to build one! Flash kindly sent me detailed photos of his model along with drawings of the fuse, wing and tail profiles. Over the past months Flash has tweaked the design slightly to improve performance, and with numerous PM’s and ideas passed forwards and backwards regarding the build process I have drawn plans for the model and tried to document the build process as best I can.
Both models (amazingly) came out with identical C.O.G’s, and AUW’s within a few grams of each other.
Specs :
Wingspan : 32”
Length : 34”
AUW : 8.3oz (including 2S400 lipo @ 25g)
Setup:
Motor : AXI 2204/54 Goldline
Prop : GWS 9050 HD
Servos : 1x HS-55 (ailerons) 2x Bluebird 306 (rudder/elevator)
Rx : Jeti REX4 MPD (35Mhz for UK use)
Esc : Castle Creations TB9
Plans :
Full Sheet A0 Plans here (568kb)
19 Page Tiled A4 Plans here (437kb)
19 Page Tiled 8.5"x11" (Letter) Plans here (502kb)
Videos :
MrFlash indoor video here :
http://www.rcgroups.com/forums/showa...mentid=1108973
Firetrappe indoor video here :
http://www.rcgroups.com/forums/showa...mentid=1093689
Simulator Downloads:
Infineon for Aerofly / Aerofly Pro Deluxe
Infineon (beta) for FMS
Mini Infineon
Specs:
Wingspan : 26”
Length : 27”
AUW : 7oz (including 3S 300 lipo @ 32g)
Setup:
Motor : Komodo 257 17T
Prop : GWS 8040 HD
Servos : 1x Blue Bird 306 (ailerons) 2x Blue Arrow 4.3 (rudder/elevator)
Rx : MZK Penta 3g (35Mhz for UK use)
Plans :
Full Sheet A1 Plans here (126kb)
16 Page Tiled A4 Plans here (629kb)
16 Page Tiled 8.5"x11" (Letter) Plans here (674kb)
Video :
Firetrappe outdoor video here :
http://www.rcgroups.com/forums/showa...mentid=1165087
i3D (New outdoor 3D version)
Plans :
Full Sheet A1 Plans here (445kb)
25 Page Tiled 8.5"x11" (Letter) Plans here (403kb)
Build Guide In PDF format (thanks to RdJay) : http://www.rcgroups.com/forums/showa...mentid=1468779
Infi Photo Gallery (thanks to DaOldGuy) : http://www.rcgroups.com/forums/showthread.php?t=947767
Infineon Owners Club Map : http://maps.google.co.uk/maps/ms?hl=...mid=1226524445
(Please add your location to the map if you build one).
  • Name: bipe-mono.jpg
Description: Flash’s Infineon with smaller mono in the background   Flash’s Infineon with smaller mono in the background 48.9 KB · Views: 7123
  • Name: infineon.jpg
  • Name: mini2finis.jpg
  • Name: afpd3.jpg
Description: Infineon Simulator Model Infineon Simulator Model 53.0 KB · Views: 3830
  • Name: i3D-1.jpg
Description: i3D (Outdoor 3D Infineon) i3D (Outdoor 3D Infineon) 59.9 KB · Views: 6732
Last edited by firetrappe; Nov 14, 2008 at 05:01 PM. Reason: Gallery and Owners Club Map added
firetrappe is online now Find More Posts by firetrappe   Reply With Quote
Old Dec 04, 2006, 05:40 PM   #2
Build 2 Bounce!
Bronze Member
Step 1 – Printing and Cutting Parts
If using the tiled plans then tape the sheets carefully together making sure that they line up perfectly. Once I had the plan assembled I cut the plan down into smaller areas (ie. Wing, tailplane, fus etc) and used double-sided tape to temporarily stick them to the EPP sheets so that they didn’t move while I cut parts out. Most of the cuts can be made using a straightedge (ruler) and the more accurate the cuts are to 90°, the easier it will be to build nice and straight.
For parts that needed producing in multiples (ie. Wings, fuselage sides and formers) I was able to remove the paper from the cut parts, leaving the double-sided tape attached to the paper, and then re-use the templates again.
Once all the parts are cut I recommend doing a ‘test fit’ as seen below to make sure that all the pieces fit in their respective slots. Any slots that need enlarging are better done now rather than when covered in glue!
Notes:
The plans are drawn assuming 9mm EPP is used for the centre cabane, although 2 pieces of 5 or 6mm could be used instead. I cut the servo holes at this point however, plans are drawn assuming a Hitec HS-55 is used for ailerons and 2x Blue Bird 306’s are used for rudder/elevator.
  • Name: parts.jpg
  • Name: test fit.jpg
Old Dec 04, 2006, 05:42 PM   #3
Build 2 Bounce!
Bronze Member
Step 2 – Bevel Hinge Areas and Fit Carbon Fibre
Next, the trailing edges of the wings, horizontal and vertical stabs need the bevels cut/sanded to 45°. I used a steel rule and the edge of my cutting mat as guides and cut the bevels using a sharp blade. While I was in ‘bevel mode’ I also cut the bevels on the rudder, elevator and ailerons.
The carbon fibre can now be glued to the areas shown in the photo below. 0.5mm x 3mm strip was used for all areas except the centre cabane. I applied contact adhesive to the foam and the cf, allowed it to go tacky and then stuck the two together. The cf was taped to the wing to hold it in place while drying. The cabane used a 2mm CF rod which I sharpened to a point on one end and then pushed through the foam (rotating the rod at the same time) to embed it. The point was left exposed by about 2mm to aid alignment of the upper wing during final assembly.
Slots were cut in the outer struts and reinforced with 0.5mm x 3mm CF strips.
Note :
The photo shows the CF rod exposed on the bottom of the cabane. This needs to be cut off flush before gluing in place. Also, the cf on the leading edges is in 3 pieces, the main centre section and two additional pieces for the tips.
  • Name: carbon.jpg
Description: CF strips and rod glued in place CF strips and rod glued in place 39.7 KB · Views: 7245
Old Dec 04, 2006, 05:43 PM   #4
Build 2 Bounce!
Bronze Member
Step 3 – Glue in Centre Crutch and Firewall
The two firewall pieces were next glued together. Once dry, the top and bottom of the firewall were bevelled using the top and bottom spacers to work out the angles. The firewall was glued to the fus side with approximately 3° of down and right thrust built in. The centre crutch was then trimmed to match the angle of the firewall and glued in position from the firewall until it begins to taper.
Once dry, the nose was supported and the rear end of the crutch was glued into place as shown below.
  • Name: centre crutch top.jpg
Description: Centre crutch and firewall glued at front - top view Centre crutch and firewall glued at front - top view 35.7 KB · Views: 5436
  • Name: centre crutch bottom.jpg
Description: Centre crutch and firewall glued at front - bottom view Centre crutch and firewall glued at front - bottom view 85.5 KB · Views: 4529
  • Name: centre crutch back.jpg
Description: Centre crutch glued to rear with nose supported Centre crutch glued to rear with nose supported 86.7 KB · Views: 4869
Old Dec 04, 2006, 05:45 PM   #5
Build 2 Bounce!
Bronze Member
Step 4 – Glue in Top Front Spacer, Formers, Cabane and Servo Tray
The top of the fus and upper former can now be glued in, taking care to make sure everything stays nice and straight. Make sure to put some glue around the sides of the cabane cutout, I nearly forgot! This also helps the top of the fus keep its shape while drying.
Once dry, the nose can be supported again and the rear former and servo tray can be fitted. Both the tray and the former were trimmed to size (using the centre crutch as a guide) before gluing. You may want to position the servo tray further forward if you are using heavier servos to keep the weight forwards. The further forward the servos are however, the harder they will be to access once the wings are fitted.
  • Name: fus top cabane.jpg
Description: Top front spacer, upper former and cabane fitted Top front spacer, upper former and cabane fitted 78.1 KB · Views: 5044
  • Name: fus former tray.jpg
Description: Servo tray and rear former fitted Servo tray and rear former fitted 81.1 KB · Views: 5849
Old Dec 04, 2006, 05:46 PM   #6
Build 2 Bounce!
Bronze Member
Step 5 – Make and Fit Motor Mount and Install Radio Gear
I made a motor mount from a piece of fibreglass printed circuit board (lightweight ply would be a good alternative). Before glueing to the firewall I drilled holes for the motor shaft, wires and mounting screws. Matching holes for the shaft and wires were made in the EPP firewall.
To avoid using servo extension leads I mounted the gear as shown in the photos below. The rx was fixed to the centre crutch using velcro (the velcro in contact with the EPP was sprayed with 3M 77 to ensure it had a strong bond). This allows me to change the xtal in the rx without too much trouble.
I prefer using a velcro strap to secure my lipo’s, so I added pieces of strapping tape to both sides of the centre crutch (to avoid the foam tearing on heavy impacts!) and cut slots so that I could loop a strap over the cf. I sandwiched the esc wires between a piece of spare EPP to keep them out of the way and provide a solid base for the lipo to lie on. This also keeps the weight of the lipo as close to the thrust line as possible.
The servos were glued into the tray and then the lipo was connected to make sure they were centred (and everything worked). While I still had good access to the inside of the fus I routed a Du-Bro micro pushrod ‘snake’ through the rear former and fus. Doing this now allowed me to keep the angle of the pushrod as shallow as possible to prevent any unnecessary strain on the servo.
  • Name: motor and mount.jpg
Description: Motor mount cut from fibreglass PCB board Motor mount cut from fibreglass PCB board 47.2 KB · Views: 4284
  • Name: motor mount fitted.jpg
Description: Motor mount glued to firewall and motor installed Motor mount glued to firewall and motor installed 87.3 KB · Views: 5426
  • Name: gear install front.jpg
Description: Radio layout and lipo strap fitted Radio layout and lipo strap fitted 50.4 KB · Views: 8321
  • Name: gear install.jpg
Description: Elevator pushrod installed Elevator pushrod installed 37.1 KB · Views: 6693
Old Dec 04, 2006, 05:51 PM   #7
Build 2 Bounce!
Bronze Member
Step 6 – Attach the Other Fuselage Side and Hinge Surfaces
The second fuselage side can now be glued in place. I found it best to work from the back of the fus to make sure the horizontal stab slots lined up and work my way to the front.
While the glue dried I used Blenderm tape to hinge the ailerons, elevator and rudder using the ‘standard’ shockie method. Prior to hinging the ailerons I cut the holes for the aileron control rods to make sure the holes in the connected ailerons would be in line with each other. (see step 12 for more details)
  • Name: fus side 2.jpg
Description: Second fuselage side fitted Second fuselage side fitted 70.7 KB · Views: 5115
  • Name: bottom tail hinges.jpg
Description: Bottom of elevator and rudder hinges Bottom of elevator and rudder hinges 57.2 KB · Views: 4645
  • Name: top tail hinges.jpg
Description: Top of elevator and rudder hinges Top of elevator and rudder hinges 52.6 KB · Views: 3899
  • Name: wing hinges.jpg
Description: Ailerons hinged with control rod cutouts Ailerons hinged with control rod cutouts 72.5 KB · Views: 4584
Old Dec 04, 2006, 05:52 PM   #8
Build 2 Bounce!
Bronze Member
Step 7 – Join Top of Fuselage and Attach Tail
The top of the fuselage can now be completed. I started by gluing the edges of the canopy and the edges of the top of the fuselage that needed joining. Once the glue was tacky I fitted the canopy piece starting from the front and worked my way back to the tail ensuring that the fuselage stayed straight. I then pinned the top of the fus in several places to hold everything in place while the glue dried.
Once dry, the horizontal stab/elevator and vertical stab/rudder can be glued in place. Test fit and trim/sand the slot and top of the fuselage if necessary to help keep things square. Again, pin as required while the glue dries.
  • Name: fus side tail.jpg
  • Name: fus top tail.jpg
Old Dec 04, 2006, 05:54 PM   #9
Build 2 Bounce!
Bronze Member
Step 8 – Install Rudder Pushrod and Attach Lower Wing
The fuselage was now placed upside-down, and I installed the pushrod for the rudder. This can run parallel with the bottom of the fuselage, passing through the rear former and out through the fuselage side, again preventing undue strain on the servo.
At this point the second fus lower former was trimmed and glued into the fuselage in front of the rx. A hole is needed in this former to allow the wires from the esc and aileron servo to pass through to the rx.
I then glued the lower wing re-enforcing plate to the lower wing, making sure that it was at 90° to the hinge line and that the servo holes in both parts lined up. Once dry, the wing was glued to the fuselage.
  • Name: rudder pushrod.jpg
Description: Rudder pushrod installed Rudder pushrod installed 45.2 KB · Views: 5669
  • Name: lower wing re-enforcement.jpg
Description: Lower wing re-enforcing plate fitted      Lower wing re-enforcing plate fitted 75.5 KB · Views: 4271
  • Name: lower wing fitted.jpg
Old Dec 04, 2006, 05:55 PM   #10
Build 2 Bounce!
Bronze Member
Step 9 – Attach Control Horns, Outer Struts and Upper Wing
I used Du-bro micro horns and light ply for the control horns (matching the control rods). The ply had a small hole drilled in it to allow the barb of the horn to pass through and pierce the foam. The horns and ply were glued together using epoxy and positioned inline with the previously installed pushrods. I added a blob of glue to the tip of the barb on the opposite side of the control surface to further secure the horns.
The aileron horns were positioned on a slight angle so that they were lined up with the aileron servo. It is a good idea to fit the aileron servo at this point and connect it to the rx while you have easier access. I did not glue the servo in at this point however, so that it could be removed and placed inside the lipo bay, allowing the fuselage to sit flat for fitting the upper wing.
Next the outer struts were glued into the slots on the lower wing. The upper wing was then slotted onto the struts and glued in place using the carbon protruding from the cabane to help hold the wing in position.
  • Name: tail control horns.jpg
Description: Rudder and elevator horns installed Rudder and elevator horns installed 89.5 KB · Views: 5373
  • Name: aileron control horns.jpg
Description: Aileron horns installed Aileron horns installed 79.8 KB · Views: 4411
  • Name: struts and upper wing.jpg
Description: Struts and upper wing fitted Struts and upper wing fitted 82.2 KB · Views: 4834
Old Dec 04, 2006, 05:57 PM   #11
Build 2 Bounce!
Bronze Member
Step 10 – Landing Gear Construction
The landing gear was made by sandwiching 2x 2mm diameter carbon rods between the two remaining formers. I made grooves in the formers using a soldering iron and then glued in the carbon. The two formers were then glued together and left to dry with a weight compressing the two halves.
The axles were made from piano wire bent to shape as shown below. This allows the spats to be glued to the axle to add that finishing touch. The axles were then glued with epoxy and bound with to the cf rods. Notice the notch cut in the top of the formers to allow the esc wires to pass through.
  • Name: lg formers.jpg
Description: Front formers with grooves Front formers with grooves 53.0 KB · Views: 3583
  • Name: lg carbon.jpg
Description: 2mm cf rod glued to formers 2mm cf rod glued to formers 67.2 KB · Views: 3998
  • Name: lg axles.jpg
Description: Axles bound to carbon undercarriage Axles bound to carbon undercarriage 60.9 KB · Views: 4612
  • Name: lg complete.jpg
Description: Landing gear complete Landing gear complete 62.3 KB · Views: 4442
Old Dec 04, 2006, 06:00 PM   #12
Build 2 Bounce!
Bronze Member
Step 11 – Complete the Bottom of the Fuselage
I next connected the pushrods and routed the aerial wire through the rear former and out the rear of the fuselage just above the tail skid. If you are confident that you will not need access to the rear servos or rx, then the bottom of the fuselage can now be glued in.
I opted to add an access hatch below the servos. I added some extra pieces of 3mm EPP to the sides of the fuselage and cut the bottom rear spacer to create a hatch similar to the lipo bay hatch at the front.
The bottom rear spacer was then glued in place. The hatch was secured with strapping tape at the narrowest point and velcro was used at the other end to hold the hatch closed.
The landing gear and front spacer were then glued in place. Note, I bevelled the front spacer to make the front of the nose square. The lipo bay re-enforced sides were then trimmed to fit and glued in.
The lipo bay hatch was attached using 2” wide strapping tape running from the front of the front spacer to the leading edge of the lower wing. The tape was trimmed to fit around the LG struts and velcro was stuck to the overhanging tape and between the LG struts to hold the hatch closed. Lastly, the aileron servo was glued in position and the control rods connected. I used a pushrod kit identical to the set used for the rudder and elevator. The outer tubing was cut to size and slid over the thin wire rods to reduce flexing.
  • Name: aerial routing.jpg
Description: Aerial routed to rear of fuselage. Control rods connected to servos Aerial routed to rear of fuselage. Control rods connected to servos 47.3 KB · Views: 4988
  • Name: fus bottom rear.jpg
Description: Control rods connected, aerial secured and bottom glued in position Control rods connected, aerial secured and bottom glued in position 45.9 KB · Views: 4167
  • Name: nose bottom complete.jpg
Description: Landing gear, front spacer and lipo bay sides installed Landing gear, front spacer and lipo bay sides installed 45.7 KB · Views: 5274
  • Name: hatches open.jpg
  • Name: hatches closed.jpg
Old Dec 04, 2006, 06:02 PM   #13
Build 2 Bounce!
Bronze Member
Step 12 – Fitting Aileron Control Linkages and Wing Braces
The upper and lower ailerons were linked using 1.5mm diameter cf rods. To secure each end of the rods you need 4x 1” lengths of rigid plastic tube with an inside diameter of 1.5mm. I found that the ink tubes from ballpoint pens were perfect! I made a hole near the end of each tube using a pin and then used the offcuts from the Du-Bro pushrods to pin each tube into the four holes in the ailerons. The four pins were glued into the ailerons, taking care not to get any glue around the tubes so that they could easily pivot on the pins. The carbon rods were then cut to fit (leaving them slightly short so that they could be adjusted in the tubes). Once I was happy that each pair of ailerons were level with the wings I glued the carbon into the tubes.
The wing braces were made from 2mm diameter cf rods. I used a length of pushrod wire I had left over from the ailerons and inserted it through the lower wing at about 45° just behind the aileron servo. The thin wire was pushed through the foam towards the outer strut. This was done a couple of times until I got the correct angle so that the wire lined up with the point where the outer strut joined the upper wing. Because very thin wire (pushrod) was used, only tiny pinholes were left where the wire had pierced the foam. The tiny holes and tunnels that the wire made were enough to be able to guide the cf rod on the correct angle first time. The photos below give you an idea of where the cf rods exited through the sides of the fuselage to create the perfect angle. The first brace was glued in place and then the same procedure was carried out for the opposite brace.
  • Name: aileron bottom.jpg
Description: Bottom aileron control linkage Bottom aileron control linkage 74.7 KB · Views: 5335
  • Name: aileron top.jpg
Description: Top aileron control linkage Top aileron control linkage 65.0 KB · Views: 4186
  • Name: bottom.jpg
Description: Wing braces – upper view Wing braces – upper view 42.6 KB · Views: 5346
  • Name: struts side view.jpg
Description: Wing braces – lower view Wing braces – lower view 97.6 KB · Views: 4845
Old Dec 04, 2006, 06:03 PM   #14
Build 2 Bounce!
Bronze Member
Step 13 – Airbrakes and Decals
Many of the latest indoor pattern and freestyle planes use fixed airbrakes. These are used to slow the ‘downline’ speed of the model so that it is easier to perform manoeuvres keeping a constant speed. Flash has experimented with various brake ideas on the Infineon, the most effective being 40mm wide strips of 5mm EPP attached to the rear of the outer struts. I bevelled the top and bottom edges of the brakes so that they followed the curve of the outer struts and fitted flush against both wings. If intending to fly the model outdoors then it is probably better to leave the brakes off initially, they add drag and reduce the forward speed of the model significantly if flown in breezy conditions.
I designed the decals in the photo below to add a bit of character to the model without adding too much weight. The decals were inkjet printed onto 5 sheets of 11”x17” waterslide transfer paper and then attached to the model using 3M77 adhesive. For detailed instructions see my mini ‘how-to’ thread here :
http://www.rcgroups.com/forums/showthread.php?t=582939
As the majority of people don't have A3 printers I have produced pdf's for the Infineon and Mini Infineon suitable for Letter sized transfer paper. These are in a tiled format and I recommend you print them on normal paper first to check they fit your model. Once you have confirmed that they are the correct size then print them onto transfer paper one page at a time to avoid paper jams. The pdf's can also be opened in Photoshop and the colours can be changed by adjusting the hue of each page.
Infineon Blue Decals - Letter Tiled (27Mb)
Mini Infineon Purple Decals - Letter Tiled (17Mb)
Well, that’s about it…
Thanks for reading, and if you have any questions regarding the design or build then MrFlash and myself will do the best we can to answer them.
Happy Building,
Si.
  • Name: brakes.jpg
Description: Waterslide decals added Waterslide decals added 50.0 KB · Views: 5391
Old Dec 05, 2006, 02:52 AM   #15
Flashmeister Aviation Inc
Bronze Member
MrFlash's Avatar
Superb job as ever Firetrappe !!
hopefully get a decent video done soon with a proper pilot to show it at its full potential.
feel free to post any questions fellas
MrFlash is offline Find More Posts by MrFlash   Reply With Quote
Build Log Sumo 3D - Free Plans, Build Guide and Video firetrappe Foamies (Scratchbuilt) 1333 Today 06:00 AM
Build Log “BigNasty” Full fuse, full wing. Free Plans and Build Guide. WaterDog Foamies (Scratchbuilt) 782 Feb 07, 2010 12:22 AM
Build Log Fly the “NASTY”! Free Plans, Build Guide, and Videos WaterDog Foamies (Scratchbuilt) 1426 Feb 03, 2010 05:40 AM
Build Log "STS" Seaplane/Airplane Free Plans, Build Guide and Videos! WaterDog Foamies (Scratchbuilt) 694 Jan 25, 2010 02:45 PM
"BIGNASTY" Full fuse, full wing. Free plans, Build Guide. WaterDog 3D Flying 0 Aug 16, 2005 11:31 PM
Congratulations SimpleM!
