Old Jul 23, 2001, 10:03 PM
e-sailpilot86 is offline
Find More Posts by e-sailpilot86
e-sailpilot86's Avatar
Joined Jun 2001
I need help with some 50 mAh packs. for MHLG
I'm planning on using a 50 mAh 4-cell pack in a MHLG. I need to know how long they can run while using only 2 servos. I am using a Feather Rx, two HS-50 servos. If my charger has too fast of a charge rate that the cells can't handle, could I just stick a resistor between the charger and battery pack to reduce the speed of the curent, and still use it on peak detect?
e-sailpilot86 is offline Find More Posts by e-sailpilot86
Old Jul 23, 2001, 10:56 PM
Lenny970 is offline
Find More Posts by Lenny970
Lenny970's Avatar
Greeley, Colorado, USA
Joined Feb 2000
You should get about 30-40 minutes of flight time, depending on many things (how much you move the sticks around, how free the linkages are, etc. I use 110 mah cells in my 4 servo HLG's and they're good for at least 40 minutes. I always set a timer for 30 minutes and then recharge.
Good luck,
Lenny
Lenny970 is offline Find More Posts by Lenny970
Old Jul 24, 2001, 08:20 AM
Megowcoupe is offline
Find More Posts by Megowcoupe
Balsa Flies Better!
Stamford, CT
Joined Oct 2000
If you like the airplane, you may want to consider getting a dedicated charger like the Sirius Charge 100 or the 200. It's a good little charger, and quite robust, plus you can use it out in the field running off a RS car pack. You could also consider 120 mAH NiMH cells if you don't fly in cold weather.
Sam Brauer
Norwalk, CT
Megowcoupe is offline Find More Posts by Megowcoupe
Old Jul 24, 2001, 02:20 PM
g00bd0g is offline
Find More Posts by g00bd0g
g00bd0g's Avatar
USA, CA, Watsonville
Joined Jul 2001
go with li-ion or taidiran, they have very small and light batteries for low current applications.
g00bd0g is offline Find More Posts by g00bd0g
Discussion Need help with my 3s2p 8000 packs. DerGoetz Electric Plane Talk 3 Jul 24, 2006 09:24 PM
Discussion new to the hobby and need help with some things javelin2 Fuel Plane Talk 11 Jun 06, 2006 07:45 PM
need help with prop/engine/battery combos for an estarter GOK Electric Plane Talk 3 Aug 20, 2005 08:42 AM
I need help with some club funfly events mdennis Fuel Plane Talk 2 Feb 20, 2004 09:46 AM
Need help with some basic newbie problems.. Ozzy Parkflyers 7 Oct 27, 2002 02:53 PM
