Old Dec 04, 2006, 12:21 AM
billpa is offline
Find More Posts by billpa
billpa's Avatar
Joined Nov 2003
Brushless RPM Sensor/Tach from Eagle Tree Systems, LLC
Brushless Motor RPM Sensor from Eagle Tree Systems, LLC
Eagle Tree Systems is pleased to announce our innovative new Brushless Electric Motor RPM Sensor/Tachometer. Our Brushless RPM sensor makes it extremely easy to measure RPM with any of our Eagle Tree data systems.
To measure RPM on your brushless electric Plane, Heli, Car or Boat, just tap one wire from our tiny new sensor into one motor lead, enter motor parameters in our software, and you are ready to go!
The Brushless RPM Sensor is compatible with our MicroPower, PowerPanel, Seagull and Data Recorder products, and will be shipping to our dealers and customers on approximately December 14, 2006 (just in time for Christmas)! Preorder yours today!
See your Dealer, visit our site at http://www.eagletreesystems.com or email sales@eagletreesystems.com for more information.
Note: Using the Brushless RPM Sensor with our Seagull and Data Recorder products requires firmware level 4.XX or higher, which has been shipping since approximately August, 2005. Click here for Upgrade Info (PDF).
billpa is offline Find More Posts by billpa
Site Sponsor
Old Dec 04, 2006, 12:23 AM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
Cool product.
I notice there are two leads , motor 1 and motor 2.
Can you measure two motors with this, or do you need to hook up to two phases?
Pat Mackenzie
pmackenzie is offline Find More Posts by pmackenzie
Old Dec 04, 2006, 01:31 AM
Larry3215 is offline
Find More Posts by Larry3215
Permanently Banned
Larry3215's Avatar
Gig Harbor, Washington, United States
Joined Sep 2003
Cool idea!
Good question Pat!
Larry
Larry3215 is offline Find More Posts by Larry3215
Old Dec 04, 2006, 03:15 AM
green66 is online now
Find More Posts by green66
United States, CA, Covina
Joined Dec 2001
....just tap one wire from our tiny new sensor into one motor lead....
Can the sensor wire just be soldered or clipped to a spot of bare motor lead anywhere along the lead?
Could the sensor have any load/timing/phasing effect on the ESC, or otherwise affect system performance?
....enter motor parameters in our software....
What are those parameters?
Will the accuracy of measured rpm's be affected by the accuracy of the input values?
green66 is online now Find More Posts by green66
Old Dec 04, 2006, 09:27 PM
billpa is offline
billpa's Avatar
Joined Nov 2003
Hi All,
Thanks for the feedback.
Pat, for the large majority of motors, Motor 1 lead only need be attached. For some motor designs, both leads will be needed.
Green66, yes you can just solder or clip the sensor lead to the motor lead, anywhere along the lead. No, the sensor should have no affect on the ESC whatsoever. Of course, we recommend a ground check before flying after installing any new electronics.
The motor parameters are simply the # of motor poles (available from your motor mfg), and the gear ratio (normally 1.0 for planes). If one or both of these parameters is unknown, the simplest way to determine them is to run a test with a handheld tach, noting the max RPM. Then download logger data, calculate the % error, then adjust the input factor read the correct value.
Regards,
Bill, for Eagle Tree Systems, LLC
Site Sponsor
Old Dec 04, 2006, 09:42 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
A few known Tach numbers or ones which work for me.
HiMax 2815 (14) Same as the number of magnets
Mega 16/7/6 (6)
Mamba Max 5700 (2) according to CC All of the Mamba motors (1/18th and 1/10th) are 2 pole slotless designs.
FYI I used servo leads (pigtails) on the ESC to Motor lead(s) and matching pigtail on the ET Tach expansion board so that it is very simple to move from on application to another.
Charles
Old Dec 04, 2006, 10:32 PM
mjdoz is offline
Find More Posts by mjdoz
Australia, QLD, Bongaree
Joined Nov 2003
Bill,
went to place an order and noticed shipping to Australia was more than the cost of the sensor. Any idea when the local Australian suppliers will have stock?
Michael
mjdoz is offline Find More Posts by mjdoz
Old Dec 04, 2006, 10:53 PM
Bthree is offline
Find More Posts by Bthree
NW Victoria Australia
Joined Sep 2003
Who sells Eagletree in Aus ?
ExtremeRC but who else ?
Bthree is offline Find More Posts by Bthree
Old Dec 05, 2006, 12:46 AM
mjdoz is offline
Joined Nov 2003
Wattsup as well.
also fast electrics http://www.fastelectrics.com/eagletree.asp
Not sure if anybody else. Try Google with "Australia only" selected
Michael
Last edited by mjdoz; Dec 06, 2006 at 12:57 AM. Reason: Added another Aussie Source
Old Dec 06, 2006, 10:50 PM
xorbe is offline
Find More Posts by xorbe
so i rewired it...
xorbe's Avatar
Mountain View CA USA
Joined Jun 2006
How can I get this new RPM sensor sooner than later?
edit: Well I did the pre-order via ETS website...
xorbe is offline Find More Posts by xorbe
Old Dec 14, 2006, 02:20 PM
xorbe is offline
so i rewired it...
xorbe's Avatar
Joined Jun 2006
Ding ding! Today is the 14th!
Old Dec 18, 2006, 02:55 PM
billpa is offline
billpa's Avatar
Joined Nov 2003
Hi All,
We have been the unfortunate recipients of this:
http://www.komotv.com/news/4935976.html
We now have power back on, and are using cellphones for internet access.
The mail has started to run again, and we are supposed to receive the brushless expanders from the factory today, which means shipping starting tomorrow.
Sorry for the delay!
Regards,
Site Sponsor
Old Dec 28, 2006, 03:26 AM
xorbe is offline
so i rewired it...
xorbe's Avatar
Joined Jun 2006
I have RPMs on my charts now!
Just one lead needed for JGF 500T 12-pole outrunner.
update: seems like my CC60 never goes all the way to 0 RPMs... stuck at ~4K minimum -- is this due to the active brake function? No big deal, because I'm interested in max RPMs at speed really.
Old Dec 28, 2006, 04:50 PM
billpa is offline
billpa's Avatar
Joined Nov 2003
Hi Xorbe,
Great news!! Yes, I suspect the active brake is sending pulses to the motor to keep it still. Is it possible to briefly turn off the brake, to see if the pulses stop? We can do some things in firmware to detect/eliminate that if need be.
Regards,
Site Sponsor
Discussion Brushless RPM Sensor/Tach from Eagle Tree Systems, LLC billpa Eagle Tree Systems 57 Apr 24, 2009 11:19 AM
Discussion Google Earth™ GPS Support from Eagle Tree Systems, LLC billpa Slope 0 Nov 26, 2006 02:40 PM
New Product Jet ECU Real-time Data from Eagle Tree Systems, LLC Dave Lauck Product Announcements 0 Mar 24, 2006 12:48 PM
MicroPower E-Logger from Eagle Tree Systems, LLC Dave Lauck Product Announcements 0 Dec 19, 2005 04:15 PM
Multiple RPM Sensor Support from Eagle Tree Systems, LLC Dave Lauck Product Announcements 1 Nov 09, 2005 01:39 AM
