Old Dec 03, 2006, 08:24 PM
N8fromVA is offline
Find More Posts by N8fromVA
Joined Nov 2005
Tandem wing design
Last week I posted this in the "Foam Design" thread and didn't have any takers.
This is probably a silly question, but I thought I'd pitch it to you anyway. I have two Easy Star wings: Would it be possible to use the second wing as a tail by putting a very large elevator on it and a built-up vertical stab and rudder? I've seen an Easy Star bipe on here before but never one like I've described. If it would work, it would be one way to alleviate the high wing-loading problem.
This evening I found this plane: http://www.rctoys.com/rc-toys-and-pa...NES-TANGO.html
I would like to try something like this, but have no clue how balancing would work (among other things). Ever seen anything like it on here being used for AP?
N8fromVA is offline Find More Posts by N8fromVA
Old Dec 03, 2006, 09:10 PM
skymind is offline
Find More Posts by skymind
Colorado
Joined Jan 2005
Hi N8,
I'm a member of a full-scale canard aircraft forum. You'll have lots of 'fun' trying to get it to fly properly. Getting to AP success would be fdone much sooner with a traditional configuration: tractor prop, wing, tail, camera underneath. If you like you can reduce wingloading with an old clark airfoil.
If you're bent on that configuration, find a place where somebody might have one.
Tom
skymind is offline Find More Posts by skymind
Old Dec 03, 2006, 09:12 PM
Photoship One is offline
Find More Posts by Photoship One
by Alary Design
Photoship One's Avatar
United States, AZ, Mesa
Joined May 2002
$6K for that thing is beyond ridiculous. it's rape.
I designed and built a tandem wing plane about 14 years ago. It flew great and had tons of lift. If designed properly where the forward wing stalls just slightly before the aft wing it becomes nearly impossible to spin and when it does stall it's very gentle.
Photoship One is offline Find More Posts by Photoship One
Old Dec 03, 2006, 10:00 PM
patrickegan is offline
Find More Posts by patrickegan
SlowStick Test Pilot
patrickegan's Avatar
Yumastan RCAPA.NET
Joined Feb 2003
Yeah, what did it look like?
patrickegan is offline Find More Posts by patrickegan
Old Dec 03, 2006, 10:22 PM
California Condor is offline
Find More Posts by California Condor
Old Timer
California Condor's Avatar
CARMICHAEL, CALIFORNIA USA
Joined Apr 2001
Tileston Tern
This is a full scale tandem airplane I designed, inspired by the Flea. A model was built and flown and I started the full size one but did not finish it (the hull is hanging in my garge now). The marks on the hull in the photo are the CG limits.
California Condor is offline Find More Posts by California Condor
Old Dec 03, 2006, 11:21 PM
Yumastan RCAPA.NET
Joined Feb 2003
Interesting!
Old Dec 04, 2006, 11:43 AM
ghoti is offline
Find More Posts by ghoti
Studies the wind
ghoti's Avatar
United States, CA, Yountville
Joined Nov 2004
Best label for the flying flea is a "flying slot". A fascinating concept. Bill
ghoti is offline Find More Posts by ghoti
Old Dec 04, 2006, 11:56 AM
Old Timer
Joined Apr 2001
I did not classify the flea as a tandem, I said it was the insperation. The Tern uses the front wing for pitch control. the ailerons are on the rear wing.
Old Dec 04, 2006, 06:02 PM
Gwelan is offline
Find More Posts by Gwelan
Peakaboo!
Gwelan's Avatar
Sakinee, Canada
Joined Sep 2004
I think Tom Harper's Creosote Cruiser could be turned into a tandem wing plane rather easily. It's a tough plane designed for rough terrain.
http://www.rcgroups.com/forums/showt...eosote+cruiser
Gwelan is offline Find More Posts by Gwelan
Old Dec 04, 2006, 06:33 PM
N8fromVA is offline
Joined Nov 2005
Thanks for all the replies. Sounds like figuring out the aerodynamics is a bear.
I really like the design of the Creosote Cruiser, so thanks for sharing. I'd never come across that one.
Old Dec 04, 2006, 06:43 PM
Gwelan is offline
Peakaboo!
Gwelan's Avatar
Sakinee, Canada
Joined Sep 2004
My pleasure.
BTW
I think Mr Harper has a build thread or a webpage where he explains how to build a plane with foam board.
Old Dec 04, 2006, 06:50 PM
Gwelan is offline
Peakaboo!
Gwelan's Avatar
Sakinee, Canada
Joined Sep 2004
I got it.
http://www.rcgroups.com/forums/showt...hp?t=364973&pp
Old Dec 05, 2006, 06:16 AM
Tony65x55 is offline
Find More Posts by Tony65x55
I'm not flying backwards!
Tony65x55's Avatar
Oshawa, Canada
Joined Sep 2004
N8, don't give up on this one, the aerodynamics are not all that rough. Put together a rough sketch of what you're looking for and lots of us will be willing to help fine tune it.
Tony
Tony65x55 is offline Find More Posts by Tony65x55
Old Dec 05, 2006, 07:14 AM
N8fromVA is offline
Joined Nov 2005
Tony,
I appreciate your offer to help, and may take you up on it at a later time. With what I've found so far, I've decided to go ahead with what I had originally planned and save the tandem design for later. Thanks again.
Nate
Old Mar 03, 2007, 12:02 PM
Taran is offline
Find More Posts by Taran
Joined Feb 2007
I'd love to build this as a foam model, with maybe 32" wingspan. Should there be any difference in the angle of attack of the wings? It`s said in this thread the forward wing should stall before the aft wing, so should it have a higher angle of attack?
Is there a difference/advantage in putting the wings behind each other as in this beautiful indoor model, rather than on different levels as in the model in the picture?
Any hints/advice would be appreciated!
Taran is offline Find More Posts by Taran
Wing design for slow flyers gaduron Parkflyers 6 Jul 12, 2009 08:46 PM
Wing design for small EDF Mikey_Flies Electric Ducted Fan Jet Talk 1 Jul 10, 2001 02:42 AM
undercamber wing design Taube Parkflyers 5 Jul 01, 2001 07:23 AM
pico stick balsa wing design Taube Parkflyers 1 Jun 26, 2001 03:49 PM
Wing Design 101 Greg Covey Power Systems 5 May 08, 2001 11:53 AM
