Hong Kong
Joined Jan 2002
Thanks for the nice comments. The plane has been finished for a few years but hasn't flown still !!! It was supposedly able to ROG but flight times are only 2.5 minutes. I think I wired it up wrong since the BEC of the ESC cuts in after 5 seconds of full throttle.
Since then I just left it aside. The plane is from hobbyflite. If any of you guys fancy some scratch building check out www.pjmodelclassics.be/ for the 747 plan. It is about the same size as mine, and if you built it out of foam it'll be light enough to fly with 4 edf 50 fans. ps the plane has no battery in it so it it propped up at the rear. Hobbyflite recommends 7X 500 AR cells. |
