Old Dec 03, 2006, 03:43 PM
rickc is offline
Find More Posts by rickc
rickc's Avatar
United States, IL, East Peoria
Joined Jun 2002
ThunderTigers 9 tooth pinion in the 620 SE kit, sloppy fit on my Z50A-800
I got a Z50A-800 from Gary, I really don't like the fit of the 9 tooth TT pinion that comes in th kit on the Z50A shaft. It's a sloppy fit to me. When you tighten the two set screws down you get run out on the pinion. So when you set the backlash you have to turn the pinion to the tightest spot against the main gear and tighten the motor, then as you rotate the main gear the back lash gets loose in spots and is not a consistent feel, still in the acceptable range I guess but I may just be picky and don't like it. I sent G a PM and asked him how the mod 1 pinions he has for the Z50A and the 620 fits the the Z's shaft. He must be AWOL, he has not replied back. Anyway, is anyone experiencing the same problem I'm having? What motors are you using with the TT pinion? I'll get my caliper out and check the shaft O.D. and the I.D. of the pinion, I just haven't done it yet.
Rick
rickc is offline Find More Posts by rickc
Old Dec 03, 2006, 03:51 PM
ozace is offline
Find More Posts by ozace
Renewed interest
ozace's Avatar
Melbourne , Australia
Joined Jun 2002
When i get home i will check my TT pinions on some shafts
ozace is offline Find More Posts by ozace
Old Dec 03, 2006, 06:40 PM
RC Man is offline
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
Will a Swift pinion work on a E-Raptor?
RC Man is offline Find More Posts by RC Man
Old Dec 03, 2006, 09:01 PM
Stan Carter is offline
Find More Posts by Stan Carter
Conroe, TX
Joined Jan 2006
The TT pinion is obviously not 5mm or it would fit the Z50 motor. If its suppose to be 5mm then you must have gotten a bad pinion. The 5mm pinions that Gary sends with the Z50s fit just fine, with no slop.
Stan
Stan Carter is offline Find More Posts by Stan Carter
Old Dec 03, 2006, 09:26 PM
rickc is offline
rickc's Avatar
Joined Jun 2002
Here are the specs, The Z50A shaft o.d. measures. 4.97mm or 0.196 thousandths, the pinion i.d. measures 5.10mm or 0.201 thousandths. I wish it was just a bit closer in tolerances.
Clearence of .13mm or .005 thousandths.
Rick
Old Dec 04, 2006, 02:46 AM
ozace is offline
Renewed interest
ozace's Avatar
Joined Jun 2002
My TT pinion sucks. I tried it on the Z-power 50's i have laying around and its loose on all of them (too loose for my liking and i wont be using it).
Then i tried it on a few other 5mm shafted motors (ORK and Kontronic) all round too sloppy to be of much use.
I just grabbed a spare pinion i bought from tppacks a little while back and its as expected (great fit)
Old Dec 04, 2006, 05:12 AM
RC Man is offline
United States
Joined Feb 2001
I tried the 10t pinion from a E550 kit and it does not fit any 5mm shaft either. I wonder what size of a shaft TT motors will have? I am using a Logo pinion and fits Z-Power and Neu Motors perfectly.
RC
Old Dec 04, 2006, 09:00 AM
rickc is offline
rickc's Avatar
Joined Jun 2002
I placed an order last evening to Gary for a 9 tooth and a 10 tooth pinion for my Z50A/E620, he said they would go out today. I'll check them when they arrive for fit and change to what ever it better. I think TT will get a grip on the I.D. being over sized. Thanks for the replies...
Rick
Old Dec 04, 2006, 10:41 AM
RC Man is offline
United States
Joined Feb 2001
I got a pinion from Gary last week and itís a good fit to a 5mm shaft. I was a little surprised that it was an aluminum gear and not steel like the Logo gears. Only time will tell whether or not they will hold up in flight.
RC
Old Dec 04, 2006, 11:24 AM
rickc is offline
rickc's Avatar
Joined Jun 2002
RC
I dull tool will cause the bore to run oversize, I would bet the specs are right for the pinion vs. shaft, just poor tooling.
Rick
Old Dec 04, 2006, 11:29 AM
rickc is offline
rickc's Avatar
Joined Jun 2002
RC
If the aluminum starts to wear or wear the main gear I'll place an order with fxaeromodels for a Mikado, if I knew last evening they were aluminum I may have ordered the Mikados right off. Only 2.95 difference in price for the steel.
I believe Gary would not sell something he didn't have faith in or would not use himself. As you said, time will tell.
Rick
Old Dec 04, 2006, 03:58 PM
epc2 is offline
Find More Posts by epc2
Miami Fl/Santo.Dgo.
Joined Jun 2004
I'm going to check the stock one tonight and I hope It fits good cuz the One I got from Gary is Crap and aluminium???
Look at this.
epc2 is offline Find More Posts by epc2
Old Dec 04, 2006, 05:37 PM
rickc is offline
rickc's Avatar
Joined Jun 2002
RC
What is the part number for the Logo pinion, I seen a Mod one 9 tooth #M2509 and a 10 T Mod one #M2510. From the pics I can't tell if the pinion teeth are as tall as the TT main gear to get 100% contact.
What's Module One stand for, is it the pitch of the teeth?
Rick
Old Dec 04, 2006, 06:20 PM
RC Man is offline
United States
Joined Feb 2001
Rick
They make full contact with the new 111t gear. They only make about 95% contact with a Raptor 90 (91, 93, 94, 95t) gears.
Module 1 is the metric tern for teeth spacing. Mod 1 has a 1mm tooth spacing; Mod 0.7 has a 0.7mm tooth spacing.
RC
Old Dec 04, 2006, 07:03 PM
epc2 is offline
Miami Fl/Santo.Dgo.
Joined Jun 2004
Update,
I tried the TT and it's a loose non acceptable fit;The one from Gary doesn't work either cuz you can't make a good contact unless you put some spacers between the plate and motor(pinion needs to be shorter).
I think Gary doesn't know this but his pinions won't work with the TT 111 Main Gear.
I'm going to order the Mikado and be done with it.
epc2.
Where to get a 9 tooth pinion hellaheli Micro Helis 7 Jan 27, 2005 04:28 PM
where to get a 9 tooth pinion for Hacker Philpops Mini Helis 15 Dec 03, 2004 03:04 AM
WTT or WTB 8-9 tooth pinion/ Corona ICRSHLTS Aircraft - Electric - Airplanes (FS/W) 1 Oct 26, 2003 09:10 PM
8 or 9 tooth pinion for Atomic Force motor tocano Electric Heli Talk 21 Sep 19, 2003 01:30 AM
9 tooth pinion ??? AtomHeartMother Micro Helis 4 Jun 15, 2003 09:09 AM
