Old Dec 03, 2006, 09:15 AM
F7X is offline
F7X
Find More Posts by F7X
F7X
Faster!
F7X's Avatar
United States, NV, Sparks
My Sixteen Entries!!!
This is our T-6A Texan II. This is a scratch built, our own desgin, sport scale of the new Air Force primary trainer. The model is mostly balsa with a little light ply, and feature a full set of robart retracts. It has unlimited verterical, and is pushing the 100mph mark.
Specs:
45.5 wing span
387 sq wing area
21.86 oz/sq ft wing loading
58.8 oz all up weight
190 watts per pound
Guts:
4s1p 3700 Lipo (14.8v)
CC PH-45
Medusa 3.5 amp BEC
AstroFlight 050 geared 3.3:1
11x8 Zinger wood prop
CC Berg 7ch rx
4 HS-81 for flight controls
2 HS-55s for retracts
Robart #124 1/2A nose retract
Robart #600 Main Retracts
-Joshua
F7X is offline Find More Posts by F7X
Old Dec 03, 2006, 09:26 AM
F7X is offline
F7X
F7X
Faster!
F7X's Avatar
My Second Entry
This is my Multiplex MicroJet. This is my fastest model, yet is controlled by a mere Phoenix-25. Top speed has been clocked at 127mph in level. This is my second MJ, but I'm still using the orignal CC PH-25.
CC PH-25
AstroFlight 020 5t
4s 2100 Mega Power
-Joshua
Old Dec 03, 2006, 09:36 AM
F7X is offline
F7X
F7X
Faster!
F7X's Avatar
My Third Entry
Based on the orginal Hal deBolt Champ, this is our scratch built electric Champ. It has clipped wing, a lighter, narrower fuselage, and instead if the OS .20, its powered by an E-Flite 400 inrunner, and a CC Phoenix-25.
-Joshua
Old Dec 03, 2006, 09:40 AM
F7X is offline
F7X
F7X
Faster!
F7X's Avatar
My Fourth Entry
StevensAero Cap 232 was built by me last winter/summer. It uses a Hacker A30-12XL, Caslte Creation PH-45 and a 4s 3700 EvoPower battery. This combination resulted in 730watts of power in a 3.5lb plane.
-Joshua
Old Dec 03, 2006, 09:45 AM
F7X is offline
F7X
F7X
Faster!
F7X's Avatar
My Fifth Entry
This is our 60" scracth built, own desgin, Turbo Raven. It's all balsa and ply. and uses the awesome AstroFlight 25BL, controlled by a Castle Creations PH-60, and juice is supplied with a 6S2P 2100 Apex. The combo will produce over 1100watts, and really makes this machine move! It also uses a Berg 7ch reciever.
-Joshua
Old Dec 03, 2006, 09:52 AM
F7X is offline
F7X
F7X
Faster!
F7X's Avatar
My Sixth Entry
This is another scratch built, own desgin. The sport scale Cessna 177 Cardinal is powered by an AstroFlight 020, and controlled by a Castle Creations PH-25, and a 3s 2100 Apex. Though it has a light wing loading, and trainer like stall characteristics, this model is capable of some impressive manuevers: knife edge, blender, snaps, hovering, and many other non-cessna like moves.
-Joshua
Old Dec 03, 2006, 09:59 AM
F7X is offline
F7X
F7X
Faster!
F7X's Avatar
My Seventh Entry
Another scratch build, own design, the Bonanza. This little belly lander is a cute, and unique park flyer. Powered by a RimFire 1000kv, a Castle Creations PH-10, and a 3s 830 Apogee. It features V-Tail mixing, and can actually knife edge for almost the entire field.
-Joshua
Old Dec 03, 2006, 10:07 AM
F7X is offline
F7X
F7X
Faster!
F7X's Avatar
My Eighth Entry
Here is our Stoop Suke II. This scratch build model was designed and schemed from photos of Scott Stoops full size SU-26MX. Powered by an Astroflight 050, Castle Creations PH-45, and a 3S2P 2100 Thunderpower. It's all balsa and ply, and is an unlimited aerobat, with a lot of speed to boot. It'll be at the Arizona Electric Fest, so come check it out.
-Joshua
Old Dec 03, 2006, 10:14 AM
F7X is offline
F7X
F7X
Faster!
F7X's Avatar
My Ninth entry
The Fun Fly is a purpose designed and built aircraft for the year round fun fly competitions we have here in Grand Junction, and finished 2nd overall this year. Power comes from an Astroflight 050, Castle Creations PH-45, and a 3S2P 2100 Apex, and has a Berg 4L rx. This model has even won some races at our club, going up again Rossi .46 powered World Model Sky Raiders!
-Joshua
Old Dec 03, 2006, 10:20 AM
F7X is offline
F7X
F7X
Faster!
F7X's Avatar
My Tenth Enty
"Snoop" is a scratch built, own design, sport scale of a Sopwith Pup. Its all balsa and ply, and covered in MonoKote. It s really fun aircraft, and I've posted an inflight video:
Pup right wing in flight (5 min 23 sec)
The model is powered by an Astroflight 010 Planetary, Castle Creations PH-10 and a 3S 830 Apogee. The rx is a Berg 4L.
-Joshua
Old Dec 03, 2006, 10:22 AM
F7X is offline
F7X
F7X
Faster!
F7X's Avatar
My Eleventh Entry
The little Turbo Raven is an older design of ours, and uses a Astroflight 020, and a Castle Creations PH-25 on 3S. She's been with us a while, and has been dubbed "Old Faithful".
-Joshua
Old Dec 03, 2006, 10:29 AM
F7X is offline
F7X
F7X
Faster!
F7X's Avatar
My Twelfth Entry
The Twin Spin is a concept aircraft to test how twins need to be set up electronically, and how they would fly. This is our first twin, and performance was surprisingly good. Even though the props are almost 50% of the wing span, the twin spin doesn't have uncontrollable torque and P-Factor issues.
Power comes from two AstroFlight 010 3.3:1s, 2 Castle Creations PH-10s and a single 3S 1580 to 2100 lipo. Gear is removable for grass landings.
-Joshua
Old Dec 03, 2006, 10:33 AM
F7X is offline
F7X
F7X
Faster!
F7X's Avatar
My Thirteenth Entry
This is my GWS Dragonfly Heli. Mods incude: Like90 Blades, Astroflight 010 Heli motor, Castle Creations PH-10, and direct drive tail. Power comes from a 1570 3S pack, which provides serious punch out power (enough for loops... this thing is fixed pitch!) and 20 minute flights.
-Joshua
Old Dec 03, 2006, 10:48 AM
F7X is offline
F7X
F7X
Faster!
F7X's Avatar
My Fourteenth Entry
Here is my StevensAero Adrenalin Rush. This is a fun, cheap, and fast model. Power comes from a Fiegao IPS BL 4100kv, Castle Creations Thunderbird 9, and a 3s 450 Etec. The rx is a Berg 4L with an Azarr antenna. This thing is capable of 65+ mph, and makes a great club racer.
-Joshua
Old Dec 03, 2006, 10:54 AM
F7X is offline
F7X
F7X
Faster!
F7X's Avatar
My Fifteenth Entry
Here is a scratch built, own design Pitts Model 12 "Pitts Monster". This thing is all Castle!! Power comes from a CM-2068 geared through a Brute gear box, a Castle Creations PH-25, and the rx is a Berg 4L. She's cute in the air, and has the usual biplane habbits.
-Joshua
