Old Dec 02, 2006, 04:34 PM
zoohr is offline
Find More Posts by zoohr
starting at RC
Zagreb,Croatia
Joined Aug 2004
Help!
cheap brushless combo ??
Hi!
I am looking for cheap brushless motor and esc max. 40$ combo, maybe from
elemodel or unitedhobbies.
Something for 6x4 prop and 7-8 cells nimh with trust cca 150 - 200 grams.
I am from Croatia so the shipping cost is much smaller from China then from USA :-((
My main concern is quality of this cheap ESC. Can anybody recommend any of this brands and/or types?
Thanks!
zoohr is offline Find More Posts by zoohr
Old Dec 02, 2006, 04:48 PM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
The tower cheapies are not too bad.
A cheap bell motor and a tower pro ESC will not break the bank..BUT te throttle is very non linear, and you need to adjust transmitter endpoints to make the best of it.
It's a bit all or nothing on a non computer transmitter.
Consider UK or German distributors..I got my one from here..
http://www.micronradiocontrol.co.uk/towerpro_esc.html
That's about $28 US for a 10A..or whatever it is in Euros.
It drives a cheapo bell motor allright. Those are about 9 here these days.
Should get you in under $40US altogether.
Old Dec 02, 2006, 09:45 PM
Bigster is online now
Find More Posts by Bigster
Well, now that you know ...
Bigster's Avatar
Grafton, Massachusetts, United States
Joined Sep 2004
ESCs don't get much cheaper than this. Reports are just being posted now elsewhere about the quality of the proiducts being received.
http://www.bidproduct.com/part/Produ...S%20ESC_1.html
Bigster is online now Find More Posts by Bigster
Old Dec 02, 2006, 11:45 PM
Lon Enloe is offline
Find More Posts by Lon Enloe
Colorado Springs, CO
When checking out the budget ESCs it's worth finding out what their low voltage cutoff (most in this price range aren't adjustable) is set to. It's not necessarily a show stopper--I'm still running one l got from BP hobbies and it works fine, but I also know I have to be careful and fly by time rather than trying to get the last bit of "umph" out of the motor. Saving $20 on an ESC isn't much of a bargain if you end up killing a $40+ battery pack.
Lon Enloe is offline Find More Posts by Lon Enloe
Old Dec 03, 2006, 01:31 AM
manuel v is offline
Find More Posts by manuel v
manuel v's Avatar
Mexico, BC, Mexicali
Joined Aug 2004
Check this tread:
http://www.rcgroups.com/forums/showthread.php?t=560144
Manuel V.
manuel v is offline Find More Posts by manuel v
Old Dec 03, 2006, 01:54 AM
3dflier is offline
Find More Posts by 3dflier
Joined Sep 2006
wow...great prices
3dflier is offline Find More Posts by 3dflier
Old Dec 03, 2006, 02:43 AM
tim_mellor is offline
Find More Posts by tim_mellor
Plays with Toys
tim_mellor's Avatar
Port Fairy, Australia
Joined Jun 2005
Just make sure you factor in the frieght which in less they have improved used to suck Frieght depending on the item can double the cost of the item
Tim
tim_mellor is offline Find More Posts by tim_mellor
Old Dec 03, 2006, 08:38 AM
zoohr is offline
starting at RC
Zagreb,Croatia
Joined Aug 2004
Thanks for help guys! What about motor for 6*4 prop and 7-8 cell nimh?
Old Dec 03, 2006, 10:14 AM
zoohr is offline
starting at RC
Zagreb,Croatia
Joined Aug 2004
What about this one:
http://www.aarchobby.com/shop/index....d2d5d718be21c9
Old Dec 03, 2006, 01:18 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
If we call your 7 cells about 8v under load, you'll need about a 1800Kv motor to drive a 6x4 and get your 200g or so thrust. An E-max 2205/22 (1780Kv) [http://www.xushobby.com/servlet/Detail?no=198, <$30] gets you this:
7.9v, 6.10A, 48W, 11040rpm, 41.8mph, 242g, 8.52oz, 5.04g/W
If you go up to 8-cells, you'll still only draw something over 7A:
8.9v, 7.20A, 64W, 12000rpm, 45.5mph, 291g, 10.25oz, 4.55g/W
If this is all the thrust you need you will get away with a 10A ESC.
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Dec 03, 2006, 01:45 PM
zoohr is offline
starting at RC
Zagreb,Croatia
Joined Aug 2004
Bingo!
Thanks!
Discussion Cheap Brushless WAR BIRD combo from Epyaya- how does this setup fly? Smokescreen38 Parkflyers 4 Jun 05, 2007 04:58 PM
Discussion cheap brushless combo cmulder Mini Helis 0 May 08, 2006 06:28 AM
Alert Cheap (60$) brushless combo!!! vikar Foamies (Kits) 3 Mar 11, 2005 08:00 PM
Cheap Brushless System! Kimble_Schmitz Power Systems 43 Dec 24, 2001 06:30 AM
?source of cheap brushless motor? bpu6999 Electric Plane Talk 2 Dec 21, 2001 08:18 AM
