Old Dec 02, 2006, 12:06 PM
Ceeray is offline
Find More Posts by Ceeray
Finland
Joined Jul 2004
Build Log
Fw-190 D9 out of depron
Well, all started when I saw Hans-Joachimīs P-51D here.. I thought that Mustangs arenīt rare anymore and German iron is undervalued...
Didnīt take much to convince H-J to start making plans for fuselage and he did them in record time. We agreed that I supply plans for the wing.
It took longer than I thought. I had used CAD programs 8 years ago and it was Autocad 3.xx something. DOS operated...
Long story short, after some setbacks and misunderstandings we got fuselage plans and wing plans ready for testing. Horizontal/vertical stab and control surfaces are OTW.
Wing halves are joined by making 2 parts of joiners (in the plans) out of 2mm plywood which are laminated into main spar.
H-J has already begun and he can post pics and preliminary plans for the plane. He also made a wing out of 3mm depron which looks pretty good, but I intend to use the wing I made out with profili. I will make a normal wing first and if the plane is a good flier I will desing another wing which has housing for pneumatic retracts and flaps.
H-J, please post the plans here.
About the wing:
Its NACA 2412 profile and has 2 degrees of washout. 2 carbon tubes hold it together and 6mmdepron spar keeps ribs evenly spaced. 22cm long aileron which is 3 cm off the scale (25 would be scale) because rib spacing. Its easy to correct and I intend to do that but these are preliminary plans and I think 3cm is not much...
Rectangle hole is meant for servo wire , one servo/aileron.
Wing is desingned for 3mm depron skin and 6mm balsa leading edge. You also have to shape the skin after making the wing , because otherwise wing profile will suffer and trailing edge is too thick. It has to be sanded to 2-3mm.
Glassing recommended.
Wingspan 122cm (121.5-122, depends how well you make it)
We had to open the thread because some people wanted us to do that Hans-Joachim let me do the honors
We will keep you posted on advancement and tested and corrected versions of the plans will be updated.
Oh, BTW the wing profile is made by using PROFILI 2 program which I recommend!
Ceeray is offline Find More Posts by Ceeray
Old Dec 03, 2006, 07:08 AM
Hans-Joachim is offline
Find More Posts by Hans-Joachim
Living a Dream
Hans-Joachim's Avatar
Winsen (Aller) Germany
Joined Oct 2003
Hi Ceeray,
Thatīs a nice start! Here is what weīve done.
48 inc wingspan is a good size for this kind of warbird
and thatīs ~ scale 1/9, so my son can fly our P-51D
and I can try to follow or get away with the Fw-190 DORA.
Iīm going with a simple 2x3mm depron wing construction and
a vertical 6mm depron V-form with a carbon tube glued on.
Iīve used uhu por for the carbon tube this time and it seems
to work well.
For the motor, I tried to get a typhoon 15/10,
but only got an e-flite park 480.
Glueing the parts together, is like an easy puzzle and itīs fun to do it.
HJ
Hans-Joachim is offline Find More Posts by Hans-Joachim
Old Dec 03, 2006, 07:20 AM
Living a Dream
Joined Oct 2003
Here are the parts Iīve used.
.. Iīve edit the link to her maiden flight video to this post.
My Note: These Fw-190-Doraīs are great airplanes!!
Edit: Link to Scale 1/9 Fw-190-D9 Maiden Flight.
http://www.rcgroups.com/forums/showthread.php?t=625865
Jan-Henrik is flying the 1/9 Dora
http://www.rcgroups.com/forums/showthread.php?t=647943
Scale 1/7 Fw-190-D9 Maiden Flight. (ws:158cm)
http://www.rcgroups.com/forums/showthread.php?t=982097
another 1/7 Fw-190-D9 flight. Iīve just noticed the 2 years difference in size, between video #2 and #4. .. the plane and Jan-Henrik.
[url]http://www.rcgroups.com/forums/showthread.php?t=1016949[url]
75% size tiled plans are here ..
http://www.rcgroups.com/forums/showp...&postcount=201
Old Dec 03, 2006, 07:27 AM
Ceeray is offline
Finland
Joined Jul 2004
****, will be back..
Old Dec 03, 2006, 08:15 AM
Harpye is offline
Find More Posts by Harpye
Build it again, Sam!
Harpye's Avatar
Germany
Nice to get another wingman!! Here is mine
and here is Schorschs from my plans!
Harpye is offline Find More Posts by Harpye
Old Dec 03, 2006, 09:07 AM
Ceeray is offline
Finland
Joined Jul 2004
Wow, nice looking planes! The lower one has really well made panel lines.
Old Dec 03, 2006, 10:09 AM
im-sad is offline
Find More Posts by im-sad
Or am I...
Bournemouth, Dorset, UK
Joined Jan 2005
wow you never stop spitting out new designs do you Hans. .
im-sad is offline Find More Posts by im-sad
Old Dec 03, 2006, 12:32 PM
Harpye is offline
Harpye's Avatar
Germany
Not really - life is boring without!!! in May I celebrated my 50th built -
( 100 constructed - but now I try a ( for me) totally new size!!!
Take a look @ my built " rare beauty!! FW802"
Hansjoerg
Old Dec 03, 2006, 12:36 PM
flying-inspecto is offline
Find More Posts by flying-inspecto
AMA848091
St. Charles, MO.
Joined Apr 2003
Hans-Joachim: Hans, the FW-190-D9 that you and your son is designing and building is just fantastic. Can't wait to see it fly, this will be a good build.
Best of luck.
Cecil
flying-inspecto is offline Find More Posts by flying-inspecto
Old Dec 03, 2006, 02:15 PM
skaterkid65663 is offline
Find More Posts by skaterkid65663
plane builder
Traveres City
Joined Apr 2006
hey. one thing i notice is the tail on the white fomie being done by hons. the back of the fuse near the virticle fin looks a little slim
cant wait to see a video of it fly tho
right now im workin on a 65 in fw190
i timesed the gillow plans up by 4 and im probly going to start the wing today
skaterkid65663 is offline Find More Posts by skaterkid65663
Old Dec 03, 2006, 05:21 PM
sonycrow is offline
Find More Posts by sonycrow
Joined Nov 2006
Nice work and planes!!!
sonycrow is offline Find More Posts by sonycrow
Old Dec 04, 2006, 12:33 PM
Living a Dream
Joined Oct 2003
THX, Adriel and Cecil.
Hansjoerg,
your 802 is looking nice. It will be an interesting build. What size
are your Fw-190īs and whatīs the setup and weight?
.. I love the panel lines, too!
skaterkid65663,
the 3mm skin is missing, thatīs why it looks small in this area.
65 inc is big! What kind of setup do you wana use?
HJ
Old Dec 04, 2006, 03:23 PM
Harpye is offline
Harpye's Avatar
Germany
The 190s are 85cm WS - 350 Gram AUW!!
The FW802 will be 1,62m ws and ~2,2Kg with retracts and CR prop!!
Old Dec 05, 2006, 12:19 PM
Living a Dream
Joined Oct 2003
Hansjoerg,
350g is a PERFECT AUW WEIGHT for your 85cm wingspan warbird!
Are you flying indoor, too?
Your Fw-802 will be HOT!
Have enough space between the two props.
HJ
Old Dec 09, 2006, 05:43 PM
sonycrow is offline
Joined Nov 2006
Hans-Joachim, u have more photos of wings (build and final)?
U can post please?
Thankiu!!!
Discussion Top Flite FW-190 D9 Dora andernamen Fuel Warbirds 5 Apr 09, 2016 10:55 PM
Cool Fw-190 D9 frustrated Fuel Warbirds 8 Mar 26, 2009 09:16 AM
Build Log Nice 'n Nosey Does It! 36" span FW 190 D9 for Fellside. Adrian Britton Scale Kit/Scratch Built 117 Jun 22, 2007 05:44 AM
Found Plans for Top Flite FW 190 D9 .60 Size andernamen Aircraft - Fuel - Airplanes (FS/W) 0 Nov 22, 2006 06:47 PM
Discussion NIB Top Flite Gold Edition FW-190 D9 Kit $130 Shipped dhable Aircraft - Fuel - Airplanes (FS/W) 2 Nov 05, 2004 07:54 PM
