Old Dec 01, 2006, 09:50 AM
Joined Jan 2006
TID Tug?
I had been looking for a tug to scratch build and ran across the Tid tug. Traplett has plans @ 1/24 scale which puts it at 35.5" long. This is a little smaller than I would like to make, so is there a common scale that I could use that would make it a little larger (1/18th)? I am thinking about 48" oal.
I plan on putting all the frames in cad so I can get all the parts laser cut. Once it is done, I will post the cutting files.
John
slotracer577 is offline Find More Posts by slotracer577
Old Dec 01, 2006, 10:56 AM
"day ain't over yet-"
der kapitan's Avatar
Western N.Y. winemaking country
Joined Jun 2005
Hi Slotracer,
Three feet long is a respectable size for a tug, and you should be aware that if you make one about 4' long, the displacement weight will increase considerably. Also, if
you go to an orphan scale, (1/18th) there will probably be few fittings available.
der kapitan is offline Find More Posts by der kapitan
Old Jan 07, 2007, 06:12 AM
Waterloo, Ontario
Joined Apr 2005
Look around Kingston Mouldings site for hull and plans:
T.I.D. class 1943 single-screw steam tug 890 x 220mm (35” x 8.7”) - white, grey or black £54.75 D (Scale approx. 1:24)
T.I.D. tug 1070 x 270mm (42.1” x 10.6”), supplied with plan for 890mm version - grey or white £79.50 F (Scale approx. 1:20)
www.KingstonMouldings.com
Kaskazi is offline Find More Posts by Kaskazi
Old Jan 09, 2007, 10:06 AM
Ankara Turkey
Joined Dec 2006
John[/QUOTE]
John
I am planning to make a model of an old Tug Boat, which was manufactured in Belgium,
Year 1910
Length 30.0 m
Beam 6.7 m
Weight 182 t
I have only a picture of it. No frames no plans. May I have access to you AutoCad drawings that may guide me in creating my scratch build model.
Taner Kalkay is offline Find More Posts by Taner Kalkay
