This thread is privately moderated by surfimp, who may elect to delete unwanted replies.
Old Dec 01, 2006, 12:37 AM
surfimp is offline
Find More Posts by surfimp
Trader Rating: 17
Piscine Promulgator
surfimp's Avatar
United States, CA, Santa Barbara
Joined Feb 2003
Trader Rating: 17
Sold
Unobtanium Russ Thompson DC-3 / C-47 fuse & cores
Unobtanium Russ Thompson DC-3 / C-47 PSS fuselage and wing cores by Target.
Fuse was laid up by Ray H from Russ's molds. Layup is pretty heavy, Ray builds for Fermin so this ain't no wimp. Molded in hatch and hatch cover included. Big roomy fuse with enough space for just about anything you could ever want to do. The fuse halves are joined but require final seaming (hence the tape in the pictures).
Wing cores cut by Target. They are some of the sweetest wing cores I've ever seen, use the superfast Don Ayers A7515 foil and build out to a 63" span (making the plane build to a perfect 1/16 scale). Wing is three pieces for scale accuracy. I had intended to scratchbuild nacelles, but you could build it without them if you wanted.
Cores are cut with the idea of having 1/4" basswood sub trailing edge and a 1 1/2" balsa trailing edge. I was planning to sheet them with 1/32" ply, but you could use balsa or ply or whatever you like.
Have templates for fin and elevator which need to be created from balsa, ply, basswood or whatever you prefer.
These planes build out to around 80oz. plus (I think Ray flies his at over 100oz.) This is a genuine sled opportunity for anyone who thinks they can handle it. Can you handle it??
Asking $130, buyer pays shipping. Am selling because I don't get to Fermin as much as I'd like. I had this sold earlier this year but the buyer had to back out, am just now getting back around to relisting it.
Steve
surfimp is offline Find More Posts by surfimp
Old Dec 01, 2006, 12:49 AM
TFLG is offline
Find More Posts by TFLG
Trader Rating: 10
TFLG's Avatar
United States, CA, Riverside
Joined Feb 2002
Trader Rating: 10
Stevo
I'm sure you could build that to be in the 50~60oz range without any trouble and if carefull you could probably get it in the low 40s. That would make it able to fly at most decent slopes. It only comes out in the 80~100oz range if you build it like a bricksheet house.
TFLG
TFLG is offline Find More Posts by TFLG
Old Dec 01, 2006, 03:56 AM
1000MPH is offline
Find More Posts by 1000MPH
Trader Rating: 41
Objects in mirror are losing
1000MPH's Avatar
USA, NV, Reno
Joined May 2003
Trader Rating: 41
PM sent.
stu
1000MPH is offline Find More Posts by 1000MPH
Old Dec 01, 2006, 08:43 AM
surfimp is offline
Trader Rating: 17
Piscine Promulgator
surfimp's Avatar
Joined Feb 2003
Trader Rating: 17
C-47 is sold, pending receipt of funds.
Thanks all,
Steve
DC-3/C-47 kits? CAWayne Electric Plane Talk 126 Feb 10, 2012 10:38 AM
Sold Unobtanium Russ Thompson DC-3 / C-47 PSS fuse & cores surfimp Aircraft - Sailplanes (FS/W) 3 Feb 20, 2006 08:38 AM
Cool GB Brushless for the GWS DC-3/C-47? ticketec Power Systems 0 Oct 21, 2004 01:52 AM
DC-3 / C-47 very scale prop-hub set up Splash Parkflyers 47 Aug 10, 2004 08:41 AM
