Old Jul 19, 2001, 06:32 PM
ahab is offline
Find More Posts by ahab
manahawkin, NJ
Joined Jan 2000
technique on using heat gun correctly
I read a thread on the use of heat gun/iron and I know the problems I had..
On a 2m skimmer I tacked down the litespan and it looked good.. I sealed the edges and hit it with a heat gun lightly..It ballooned the covering making a mess.. I havn't used it since.
Was advised to make small holes in the ribs and lieve a little un sealed to allow for heated air expansion.. This did not make too much sense to me and I never tried it again.
Am I missing something here.. What is the proper way to shrink open bays with a heat gun?
Jarvis
ahab is offline Find More Posts by ahab
Old Jul 19, 2001, 07:26 PM
Red Baron 47 is offline
Find More Posts by Red Baron 47
Most Exalted Windbag
Newark, DE USA
Joined May 2001
I haven't done one yet, but I read about the air vents and it sounded like a good idea to me.
RB
Red Baron 47 is offline Find More Posts by Red Baron 47
Old Jul 19, 2001, 09:11 PM
Ron Cichowski is offline
Find More Posts by Ron Cichowski
Old Guy
Ron Cichowski's Avatar
Carver, MA USA
Joined Jun 2000
Air expands rapidly when you heat the covered surface. This will stretch the covering and it will not be as tight as possible. The air pressure will also pull the covering away from the balsa where it is tacked down. It is very important that an exhaust air path is established in any covered surface if you wish to get proper surface tension. I find that about a 1/16" diameter hole in each rib leading eventually to the outside atmosphere does the job (the bigger the better). If I'm covering a fin I make the final hole out the bottom in an inconspicuous area. I'll cover the whole fin and leave the area over the vent not tacked down. I then shrink the covering with the heat gun. I finish the job by sealing the last bit of covering over the vent hole. If I'm thinking ahead I'll make the holes before beginning assembly. It makes for a "meant to be that way" appearance of the finished product. A good covered design will have the vent path established by the manufacturer.
Ron
Ron Cichowski is offline Find More Posts by Ron Cichowski
Old Jul 21, 2001, 10:18 PM
ahab is offline
manahawkin, NJ
Joined Jan 2000
hmmmmmmm. So..if you do the holes in the ribs and one or both tips..it should work??
I may have to try it again... can't see wasting the monies spent buying the heat gun.
Espectally if the final product will be better.
Thanks for the suggestion/tip..
Jarvis
Old Jul 22, 2001, 06:54 AM
Sligh is offline
Find More Posts by Sligh
Madison Ms. USA
Joined Jan 2000
There is a good article on covering in the current issue (Sept 2001)of S&E Modeler.
Sligh
Sligh is offline Find More Posts by Sligh
Old Jul 22, 2001, 08:22 PM
ahab is offline
manahawkin, NJ
Joined Jan 2000
thanks..Ill look for it for sure..
Jarvis
Using a heat gun with monocote Jim Connell Beginner Training Area (Aircraft-Electric) 4 Jul 15, 2004 03:18 AM
Heat gun + carelessness= fire on cardboard wolfance Parkflyers 14 May 31, 2003 11:01 AM
FS-Bug Plan, Heat Gun, Sealing Iron. Dandi6065 Aircraft - Electric - Airplanes (FS/W) 1 Jun 02, 2002 05:11 PM
I intend on using 1/4 phone jack on f5b type power, vibration no prob? Gman2 Power Systems 8 Mar 08, 2002 10:25 PM
iron vs heat gun dale331 Electric Plane Talk 10 Jul 18, 2001 09:33 AM
