Old Dec 01, 2006, 03:16 PM
green-boat is offline
Find More Posts by green-boat
Boats on the brain!!
green-boat's Avatar
Arnold, Mo.
Joined Jul 2005
The bulbs in my set don't have a lip on the bottom of the LED. Between that and the bulb shape, it would make it easy to chuck th bulb up in a lathe and cut some ridges in the sides.
green-boat is offline Find More Posts by green-boat
Old Dec 01, 2006, 04:06 PM
not_in_houston is offline
Find More Posts by not_in_houston
Houston Area
Joined Oct 2006
I did some looking and found this is probably a "Bethlehem Lighting Indoor/Outdoor 50-Lamp 5mm Wide-Angle LED Lighting Set".
They are also available at Amazon:
Multi-color
http://www.amazon.com/dp/B000F54934
Red:
http://www.amazon.com/dp/B000F54952
Green:
http://www.amazon.com/dp/B000F5494S
They're out of clear:
http://www.amazon.com/dp/B000F50W7G/
Here's the manufacturer's website - they don't have much data:
http://www.bethlehem-lights.com/lights.htm#LED
Looks really cool! Might have to get a set for the tree and another for the boat!
not_in_houston is offline Find More Posts by not_in_houston
Old Dec 07, 2006, 10:52 PM
Umi_Ryuzuki is offline
Find More Posts by Umi_Ryuzuki
Sea Dragon-Lover
Umi_Ryuzuki's Avatar
PDX, OR
Joined Dec 2002
Do some testing before you mount anything to a boat.
The White, Blue, and Green LED are 4volt.
The Yellow, Red, and Orange LED are 3 volt.
I set up a 4.05 volt power supply, and all fo the yellow, red, and green LED failed.
Umi_Ryuzuki is offline Find More Posts by Umi_Ryuzuki
Old Dec 08, 2006, 12:07 AM
green-boat's Avatar
Arnold, Mo.
Joined Jul 2005
Sizzle, sizzle, fry, smoke, oh sheet.
Old Dec 08, 2006, 12:19 AM
MILLERTIME is offline
Find More Posts by MILLERTIME
Taking care of the pond.
MILLERTIME's Avatar
United States, CA, Sanger
Joined Apr 2004
Originally Posted by MILLERTIME
Look here.
LED calculator
http://led.linear1.org/1led.wiz
Don M.
Umi did you miss this?
MILLERTIME is offline Find More Posts by MILLERTIME
Old Dec 08, 2006, 12:22 AM
MILLERTIME's Avatar
Joined Apr 2004
LED basics
http://led.linear1.org/why-do-i-need...r-with-an-led/
Don M.
Old Dec 08, 2006, 12:26 AM
Sea Dragon-Lover
PDX, OR
Joined Dec 2002
Originally Posted by Originally Posted by MILLERTIME
Look here.
LED calculator
Don M.
Yeah, but the instructions say 4volt LED.
So I would have put 4 in for the forward voltage...
Old Dec 09, 2006, 11:29 AM
jerryj98501 is offline
Find More Posts by jerryj98501
Olympia WA
Joined Nov 2004
You might try the following website, sorry but I just found his card again. I met Tim Anderson at a model railroad show and he has lots of information on his site on led's. You can contact him with questions but he has a lot of information on his site also. The site is www.ngineering.com. Jerry J
jerryj98501 is offline Find More Posts by jerryj98501
Old Dec 10, 2006, 12:14 AM
Milesc is offline
Find More Posts by Milesc
milesc
Loveland, Colorado
Joined Nov 2006
Forward voltage will turn on the LED; you can have a reverse voltage in some apps but no greater then 3 to 5 volts. Led should always have a resistor placed in the circuit. Silicon type LEDs need as little as .7 volts and gallium arsenide and gallium phosphide types need 1.6 volts.
+V = supply voltage - Vf = LED forward voltage / If LED forward current
+V-Vf
If
Milesc is offline Find More Posts by Milesc
Old Dec 11, 2006, 08:44 PM
jeepers1940 is offline
Find More Posts by jeepers1940
Madison, MS
I'd appreciate some advice on utilizing LEDs on a model cabin cruiser. I would like to use a Radio Shack 5mm 2.6 VDC 28 mA 10 mcd red LED for the port navigation light, powered by a 1.5 V AAA or AA battery. I would use a Radio Shack 5mm 2.1 VDC 25mA 6.3 mcd green LED for the starboard nav light, powered by another, separate 1.5 V battery. I would have the remaining wiring and electronic components (motor, receiver, switches) completely separate from the above lights.
I know that this is a very unsophisticated, perhaps inefficient setup, but (1) it adheres to the KISS principle and (2) I can understand it and implement it.
Questions: Will it work? Will the LEDs that it lights last a while? (If they're not really bright, that's alright with me; I'd prefer longer LED life to extreme brightness.)
Or, would I be better off trying to find (higher voltage) grain-of-wheat bulbs for the nav lights?
Thanks all.
Bill
jeepers1940 is offline Find More Posts by jeepers1940
Old Dec 11, 2006, 09:03 PM
green-boat's Avatar
Arnold, Mo.
Joined Jul 2005
Trying to drive a 2+ volt LED with a 1.5 volt battery would not work very well, very dim if anything. You would have to start with 3 volts and use a resistor to drop the voltage and limit the current. LED's are very rugged and are designed to last 10,000+ hours at rated levels if they are not overdriven.
(battery voltage- LED's forward voltage) divided by LED's current = resistor value
Old Dec 11, 2006, 09:24 PM
Madison, MS
Hello Green-boat,
Thank you for your advice. Another question that I have is whether any precautions need to be taken when soldering wires to the conducting "legs" of the LED? Will the heat of the soldering iron harm the LED? Will the soldering iron generate a small current that could burn out the LED during soldering?
Thanks again,
Bill
Old Dec 11, 2006, 09:39 PM
patmat2350 is offline
Find More Posts by patmat2350
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
Solder very quickly... but if worried, put an alligator clip or purpose-made heat sink on the leg.
Pat M
patmat2350 is offline Find More Posts by patmat2350
Old Dec 11, 2006, 09:48 PM
green-boat's Avatar
Arnold, Mo.
Joined Jul 2005
Too much heat will destroy an LED. I use a 30 watt iron and have no problem but then I have been soldering stuff together for 30+ years now. Have you soldered anything together before, if not I would suggest some practice. Irons don't generate any currents but there are grounded and ungrounded irons. If you are working with static sensitive components then grounded irons are mandatory. Do keep in mind that LED's are polarity sensitive, meaning that the + and - must be connected correctly if the LED is going to work.
Old Dec 11, 2006, 10:21 PM
Madison, MS
Yes, I have in the past soldered small electrical components successfully - small incandescent light bulbs, wires, small switches, small motors - but have never fooled with LEDs and their idiosyncracies. Yep, I know to use rosin-core solder on electronics; acid core is verboten.
Bill
