Go Back   RC Groups > Aircraft - Electric - General > Batteries and Chargers
Old Nov 28, 2006, 03:48 PM   #1
Southern Pride
everydayflyer's Avatar
A123 M1 Charge Graphs
This post will be multi charge graphs in an attempt to show the difference in resting voltage versus charging methods.
My AF-109 has always read a little high and these charges are from 109 throught LiPoDapter ,through Eagle Tree Micro Power Logger.
After the third graph I placed back on AF-109 and while monitoring the cells voltage I ran voltage up to 3.65 per cell and held there until stable. A total of 50 mAh was added. 15 min. after this the pack is holding at 10.81 volts.
Fourth graph charge on stock AF-109 ,charge stop after 45 sec. in stage 3.
12-7-06 Added fifth graph which shows 3S being charged on modified AF-109
12-7-06 Added sixth graph .
The resulting resting voltage after 15 min.was 3.459 / 3.429 / 3.429 (10.317)
I added 40 mAh and after 30 min. cells 3.595 / 3.561 / 3.585 (10.741)
Update: After setting overniht for approx. 10 hour in an unheated room voltage checked at temp. of 58F 10.671
I think it is safe to save that this modification results in a 22:40 charge that should be considered a full charge.
Modification Thread here.
http://www.rcgroups.com/forums/showt...t=602445&pp=15
My Radio Shack did not have correct Resistor so I used 10K + 22K + 47K all 5% 1/2 watt. Total in series was 77.6K.
12-11-06
Added another 2.2K for total of 79.8K and posted resulting graph.
Prior to charging pack was ran flat in my Traxxas Rustler / Mamba Max 5700.
Resting voltage 5 min. after run 8.0.
Higher cell voltage during charge 3.697
At end of charge 3.585 / 3.571 / 3.60
7 min. later 3.483 / 3.468 / 3.483
AF 109 indicated
2,140 added at end of stage 2 ( 17 min. )
2,280 added at end of charge.(21:55)
12-30-06 Added two TP 1010C Rev. 2.0D (Beta) charge graphs. One with and one without amps. ,both are of the same charge.
While ET Micro Power indicated 10.74 V max. TP 1010 and a seperate DVM both displayed 10.95 .
A123 cells quickly settle to the 3.4XX range after charging to 100% capacity.
As noted in TP 1010C Thread I received error [1} Low Voltage and had to add a few mAh to get voltage up a bit before charge would start.
Post here:
http://www.rcgroups.com/forums/showp...postcount=1382
TP 1010C Ver. 2.1A Firmware elinates the low voltage problems and will now charge a 3S at 7.4 volts without issue. It will also do a Recovery mode on a pack with cells down to 1.5 V per cell..
2-12-07 Added a Graph using AF 112PK charger and Dapter (latest version).
Dapter available here.
02-13-07 High speed charge graph added.
Ignore spike at the very beginning.
Charles
  • Name: A123-@8A-Standard.jpg
Description: Standard 11-28-06  Charles Standard 11-28-06 Charles 90.9 KB · Views: 1150
  • Name: A123-@8A-Double-Goose.jpg
Description: Double Goose 11-28-06  Charles Double Goose 11-28-06 Charles 97.2 KB · Views: 816
  • Name: A123-charged-@-8A-then-redu.jpg
Description: A123 charged @8A to 11V then reduced to 1A
Charles 11-28-06 A123 charged @8A to 11V then reduced to 1A Charles 11-28-06 99.9 KB · Views: 844
  • Name: 3S-A123-charge-@-8A.jpg
Description: This graph has been posted before.
  • Name: A123-3S-@8--Mod.-AF-109.gif
Description: A123 3S charged @8A on modified AF-109.
Charles 12-7-06 A123 3S charged @8A on modified AF-109. Charles 12-7-06 29.9 KB · Views: 745
  • Name: A123@8A-mod.-AF109.jpg
Description: Stage 2 and 3 @8A
  • Name: A123--3-cell-@-8A-charge-on.jpg
Description: Much the same as last graph however this one after increasing resistor string by 2.2K and complete charge shown.
Charles 12-11-06  Much the same as last graph however this one after increasing resistor string by 2.2K and complete charge shown. Charles 12-11-06 88.5 KB · Views: 680
  • Name: A123-TP-1010C-with-Amps..jpg
Description: A123 - TP 1010C -Rev.2.0D (Beta)  with amps on graph.   Charles 12-30-06 A123 - TP 1010C -Rev.2.0D (Beta) with amps on graph. Charles 12-30-06 91.8 KB · Views: 700
  • Name: A123-TP-1010-without-amps..jpg
Description: A123  TP-1010C  Rev. 2.0C (Beta)without amps. so volts are clearer.
Charles 12-30-06 A123 TP-1010C Rev. 2.0C (Beta)without amps. so volts are clearer. Charles 12-30-06 93.9 KB · Views: 583
  • Name: AF-112-PK-3S-A123-@-5.5-A-D.gif
Description: This is the latest version of the Dapter.
I used double goose as I have found that a slight overcharge does not effect these cells and they end up a bit fuller.
My Modified  AF-109 was only able to add 60 mAh .
Charles  2-12-07 This is the latest version of the Dapter. I used double goose as I have found that a slight overcharge does not effect these cells and they end up a bit fuller. My Modified AF-109 was only able to add 60 mAh . Charles 2-12-07 29.5 KB · Views: 569
  • Name: 3S-A123-chrged-from-12V-Pb.gif
Description: Not for the faint of heart.3S A123 charged striaght from 12 Pb . Source was 50Ah AGM at 12.92V at  start and 12.85 after charge.
Total of 30" charge leads including AF 101 and BNB DPR 100.
Ignore spike at very beginning.
02-13-07 Charles Not for the faint of heart.3S A123 charged striaght from 12 Pb . Source was 50Ah AGM at 12.92V at start and 12.85 after charge. Total of 30" charge leads including AF 101 and BNB DPR 100. Ignore spike at very beginning. 02-13-07 Charles 29.8 KB · Views: 838
everydayflyer is online now Find More Posts by everydayflyer   Reply With Quote
Old Dec 02, 2006, 09:13 AM   #2
Southern Pride
A123 Charging Data
There is a Support Forum on RCU at
http://www.rcuniverse.com/forum/m_4667864/tm.htm
wherte I posed the following about their Turbo Charger
What is the resting voltage of a 3 cell pack 30 minutes after charging?
No response fro A123 Racing however a member / user posted.
I underlined / bold-ed part of text.
Post #13
I read this and forgot I had a 3s pack on the A123Sonic charger for ~1.5hrs. I took it off and measured 10.98v. 30min later I measured 10.97v. 60min later that pack still reads 10.96v! I had another 3s pack charging during that time and took it off when it was finished. It measured 10.95v and 30min later measured 10.38v. The A123Sonic charger will keep repeaking the pack if you leave it connected.
and in another post (#16)
Update #2: All packs were recharged and left on the Sonic charger for at least 1hr minimum. The voltages are from the 3s1p packs sitting at rest for about 1.5 days. A-10.79v, B- 10.70v, C-10.92v, D-10.89v. The Sonic charger is not a typical Lipo CC/CV charger. It has no CC charge from what my Medusa meter shows. The initial start has the highest amp rate then shortly after that it settles to around 55w-58w for most of the cycle. Once the pack hits ~10.8v the "Charged" light comes on and almost all of the mah have been put back into the pack. The Sonic continues to charge much like a CV from that point until the pack hits 11.1v or 11.2v (the Medusa I have only has 00.0v resolution). Then the charger stops all charging. But when the pack voltage settles to ~10.8v (from resting and/or from powering the Medusa meter) the charger starts charging like a CV cycle again to the 11.1v-11.2v. This cycle of peaking/resting will continue for as long as the pack is connected.
Charles
Old Dec 02, 2006, 09:33 AM   #3
Southern Pride
A123 Charging Data Resting voltage / capacity
Resting voltage versus capacity
Using an AF-109
At a resting of 10.3 volts( 3.43 per cell avg.) I added 40 mAh and voltage reached 11.72 and was 11.30 resting right after charge.(3.766 avg. per cell)
After 15 min. 11.08
After 30 minutes 11.04 volts (3.68 avg. per cell)
Dsicharged 100 mAh and resting voltage after 15 minutes 10.05 (3.35 avg. per cell).
100 mAh is 4-5% nonimal capacity of a full (?) pack.
Toped off a with 110 mAh./ balanced durning top off.
Cells 3.751 / 3.746 / 3.770
After resting for 15 min.
Cells 3.683 / 3.668 / 3.697
Charles
Old Dec 02, 2006, 08:21 PM   #4
Occasional Flyer
New Info!
I just wanted to post new numbers for the A123 Sonic charger as I forced myself to pull up a chair and watch the cycles start to finish. I also took the charger apart to see what it's made of. I discovered I could achieve 14 minute recharges with my A123 3s1p packs simply by providing forced air cooling on the heatsink. They must lower the charging watts to keep things in check heat wise. These are the numbers with active cooling.
For 3s1p packs - 14min charges - stays above 90w charge power for most of the charge - "Charged" light comes on at ~10.9-11.0v - peaks the pack to ~11.1-11.2v - repeaks the pack when voltage drops to ~10.9v.
For 2s1p packs - 13min charges - stays around 75-85w charge power for most of the charge - "Charged" light comes on at ~7.2-7.3v - peaks the pack to ~7.4-7.5v - repeaks the pack when voltage drops to ~7.3v.
-Marv
  • Name: Charger2.jpg
  • Name: Charger3.jpg
Marv829 is offline Find More Posts by Marv829   Reply With Quote
Old Dec 07, 2006, 07:20 PM   #5
Southern Pride
Marv thanks for sharing that with us. Nice to have such numbers from an A123 charger and a number of packs to use as a baseline.
I just did the mod. to my AF-109 today and added another charge graph in post #1 to show the results.
Charles
Old Dec 07, 2006, 08:58 PM   #6
Occasional Flyer
Your welcome Charles. I will be purchasing a data logger in the future. I'm leaning towards the Eagle Tree MICROPOWER E-LOGGER as of today because of their new brushless RPM sensor.
Old Dec 07, 2006, 09:04 PM   #7
Occasional Flyer
Here is my charger now after a fan mod.
Old Dec 11, 2006, 03:39 PM   #8
Southern Pride
I increased the total resistors value to 79.8K and graphed a full charge at 8A.
Graph added to post #1.
Charles
Old Dec 30, 2006, 09:59 AM   #9
Southern Pride
TP 1010C Rev. 2.0D / A123 Charge graph
Two more charge graphs added to post #1.
Both graphs from same charge but slightly different.
Charles
Old Dec 30, 2006, 10:25 AM   #10
If it is not taking this discusson off line, could you share your overall impression of these cells vs. Lipos or Nimh for power, weight, whatever? I am interested in using them in electric planes that are in teh 1-3 pound range flying brushless motors.
Any overall impressions would be of interest.
aeajr is offline Find More Posts by aeajr   Reply With Quote
Old Dec 30, 2006, 10:32 AM   #11
I would also like more info on battery type comparison.
aireze is offline Find More Posts by aireze   Reply With Quote
Old Dec 30, 2006, 10:38 AM   #12
Southern Pride
There are many Thread on A123 cells compaing to LiPoly,NiMH,eMolie etc.
A Search on A123 will return many Threads / post. At 2.5oz. for a single 3.3 nominal voltage cell they are to heavy for most foamies.
I would prefer this remain a charging thread.
Charles
Old Dec 30, 2006, 11:01 AM   #13
Thanks everyday flyer and I respect your desire to keep this about charging.]
I have started a new thread. For anyone wanting to understand A123 technology, I have started a thead here:
http://www.rcgroups.com/forums/showt...71#post6636420
This thread should be focused on charging.
Old Feb 12, 2007, 12:32 PM   #14
Southern Pride
An addational charge graph added to post #1.
That was charge # 162 for that pack and was right after being ran in my Rustler till flat.
These cells continue to amaze me.
Charles
Old Feb 12, 2007, 02:01 PM   #15
It must be a glitch
bjpaul's Avatar
I have a feeling that these posts are counter productive to the A123 early adopters as they are probably driving up the price of DeWalt packs on eBay
Oh well......... now if A123 would just get an intelligent marketing plan for loose cells .
Brad
bjpaul is offline Find More Posts by bjpaul   Reply With Quote
Yippee! A123 / M1 cells now supported by TP 1010C Rev. 2.0D everydayflyer Batteries and Chargers 3 Dec 31, 2006 05:01 PM
Discussion Sources for A123 M1 cells? andy2667 Batteries and Chargers 7 Nov 13, 2006 10:46 AM
Discussion Steve Neu test of a123 M1 in December Quiet Flyer bjpaul Batteries and Chargers 51 Nov 11, 2006 02:43 PM
Discussion A123 M1 HM Charger? AmateurE Batteries and Chargers 2 Oct 06, 2006 02:15 PM
Discussion A123 M1 cells - no more lipos for me cliffo Electric Sailplanes 16 Sep 25, 2006 12:48 PM
Congratulations SimpleM!
