Old Nov 28, 2006, 01:34 PM
Joined Aug 2005
My Swift II + Question
Hello guys
Just bought a Swift II and equipped it with an AXI 2208/26 and a APC 7x5E and my powepack is a Thunderpower 1320 mha Lipo.
AUW is around 310 g.
Well the model flies great, it has unlimited vertical and VERY long flight times.
Last time i took it out for a flight, I flew for 22 min before I stopped, not because I ran out of power but because my little 6 month old daughter started to cry..
Okay enough of all the tech stuff and now for the question.
The manual states that the CG should be around 18 - 18,5 cm from the nose.
My CG is just around 18 cm from the nose, but it feels like it's a bit tail heavy.
It loops extemely tight, and when I flie it without the motor running it tends to stick the nose in the air.
Have I done something wrong, when I build it, or do I just put lead in the nose to compensate ?
All suggestions are welcome.
highboy is offline Find More Posts by highboy
Old Nov 28, 2006, 10:46 PM
dessertracer's Avatar
Joined May 2006
Unfortunately I don't have experience with that plane, but do know that it’s not unheard of for the optimal CG to be somewhere else that what a manual might say. The best thing to do is try moving it back and forth with lead until you get a feel for it. From my experience a tail heavy wing is seems to constantly get "unbalanced" in the sky and a nose heavy wing hunts for the ground. If the throttle significantly changes the angle of attack, such as moving the nose up or down relative to glide mode, the thrust angle needs to be adjusted.
dessertracer is offline Find More Posts by dessertracer
Old Nov 29, 2006, 11:05 AM
R/C Addicts Anonymous....
minifly's Avatar
Cape Town, South Africa
Joined Jan 2003
A touch of lead in the nose should do it, sounds like tail heavy to me.
minifly is offline Find More Posts by minifly
Need help for my Neiport II ! Warren Jones Power Systems 13 Aug 08, 2002 08:20 PM
Accord II question wsilvio Sport Planes 5 Aug 01, 2002 09:25 AM
A bunch of questions about my Firebird II Sparr Parkflyers 9 Apr 27, 2002 12:50 PM
My Aventura II won't behave tekochip Electric Plane Talk 8 Feb 05, 2002 03:21 PM
Charging my battery??? Embarrasing question :) garyc Beginner Training Area (Aircraft-Electric) 6 Jun 01, 2001 02:39 AM
