Old Sep 07, 2002, 10:56 AM
rakm is offline
Find More Posts by rakm
rakm's Avatar
Pensacola Regional, Florida, United States
Joined Jan 2002
First time builder glueing question
I'm getting ready to build for the first time and would like to know if I can simply use Titebond II for the entire project? I'm not in any hurry to get it done just want an uncomplicated way to glue up the entire project w/ maximum strength. I'm bulding a GP Spirit sailplane... If this isn't feasible can someone tell me the types of glues to use in different areas of the build. (eg.- wings use titebond, wing holddowns use resin.......)
rakm is offline Find More Posts by rakm
Old Sep 07, 2002, 11:51 AM
davidfee is offline
Find More Posts by davidfee
davidfee's Avatar
San Diego, CA, USA
Joined Mar 2001
Hi there!
Yes, you can use Titebond II to build the entire model. The one place you might want to use epoxy is on the dihedral joints and braces (and maybe the firewall if you're making it e-power). Titebond II is stong enough even for that, but epoxy fills gaps a little better (doesn't shrink much) and is usually a little more shock-resistant. As with any glue, Titebond II works best when your joints are close-fitting. If there are visible gaps, the joint will be weakened. Also, whenever possible, pin or clamp assemblies as they dry.
have fun!
David
davidfee is offline Find More Posts by davidfee
Old Sep 08, 2002, 06:50 AM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Everything he said. I dilute mine with a little water and apply with a disposable kids paintbrush. You need to be a patient builder, but it makes it easy to sand everything later..
..a
Old Sep 18, 2002, 02:06 PM
rakm is offline
rakm's Avatar
Joined Jan 2002
Thanks for the advice. I've been busy building and it seems to work great. It's nice to be able to glue with my daughter around and not have to put up with any fumes and it's easy water cleanup. Seems like very strong/solid bonds.
Now if I could just learn to cut accurate angles and quit cutting pieces "just a tad too short" i'd be alright....
Old Sep 18, 2002, 02:42 PM
Zoom is offline
Find More Posts by Zoom
pushing the extremes
Zoom's Avatar
Joined Oct 2001
Aahhh the secret to that is the miter sander. If you think you might build more planes, this is a great tool. I have the one by Fourmost Products (about $20) and love it.
- Zoom -
Zoom is offline Find More Posts by Zoom
Old Sep 18, 2002, 02:46 PM
Gerald is offline
Find More Posts by Gerald
ὅπερ ἔδει δεῖξαι
Gerald's Avatar
Joined May 2000
Err on the long side and sand the piece to final length for a perfect fit.
Gerald is offline Find More Posts by Gerald
Old Oct 06, 2002, 09:50 PM
Jim Finn is offline
Find More Posts by Jim Finn
Damascus Md
Joined Oct 2002
Yes the mitre sander is a nice tool. I use tite-bond 2 also. Where you need to sand a lot (as on wing tips) I use Sigment glue. It sands just like balsa and dries quicker than tite-bond. Tite-bond will gum up your sander a bit. Sigment is the same glue we used back in the 1950's. Using it from the tube is messy so I put it in a Sig syringe. It won't set up in it and works well for tite-bond too.
Jim Finn is offline Find More Posts by Jim Finn
Another First-Time Builder Attempts the Skimmer 400 Zymurgy Electric Sailplanes 190 Mar 15, 2004 03:01 PM
First time builder takes on the Switchback 2 Martin Hunter Parkflyers 67 May 05, 2003 03:39 AM
First Time Builder Questions - GWS Cub NoVaNewB Parkflyers 11 Feb 23, 2003 02:03 PM
X250 ok for first time builder? Kosh Electric Plane Talk 15 Oct 09, 2001 11:59 AM
