Old Dec 06, 2006, 06:41 AM
Joe Yap is offline
Find More Posts by Joe Yap
Singapore
Joined Nov 2001
Just for fun. We might need this.
Joe Yap is offline Find More Posts by Joe Yap
Old Dec 06, 2006, 07:51 AM
Joe Yap is offline
Singapore
Joined Nov 2001
In anticipation of tail heaviness, I dug out a little foam away in the noses and installed lead balls in each fuselage.
All 'inside' jobs are considered completed and the next step is to assemble the fuselage halves with epoxy. Plenty of masking tape is necessary for the job. It is crucial at this point to check for the fuselage alignment, or any distortion will be permanent later.
Old Dec 06, 2006, 05:48 PM
samotage is offline
Find More Posts by samotage
find me @samotage
samotage's Avatar
Melbourne Australia
Joined Jul 2005
Hey Albert,
I'd go with a solid joiner, I use 8mm and this is strong enough for frontside antics. Besides it withstands 1000 foot dives easy enough which is a good test IMO When compared it, the tubes were more flexy, the solid steel stiffer (but wouldn't bust in emergencies). 10mm would be hyper stiff, and desirable, but it wouldn't fit the wing camber depth in the vicinity of the subrib.
I use an 11/32 K&H brass joiner tube which the 8mm carbon tube goes into quite nicely with an "acceptable" degree of slop.
I was also thinking about your noses. IMO, the foam won't be adding much useful strength, and will just stove in for the one pointers. I rekon you need to get something substantial up there for the first inch and a half. I use a solid epoxy chop (small glass fibres) jammed up there in mine. For your situation, perhaps you could run a channel from the main gear compartment, and when it's all done just pour some resin in there to fill it up?
Sam.
who marvels at 3 jarts on the go
samotage is offline Find More Posts by samotage
Old Dec 06, 2006, 07:49 PM
Joe Yap is offline
Singapore
Joined Nov 2001
I already have solid carbon rod and brass tubes for joiners. I'll do some experiments to see which one do the job best.
Yes, the foam does not add much strength at all. But they do spread the stresses very well as they make the structure stiff with just a thin layer of glass. Furthermore, as I have mentioned before I'll have carbon longerons along the fuselage. But for the first few inches of the nose, I'll probably leave it as it is. It'll be a weak point for failure in case of bad landings. It'll be easier to repair the nose tip than the centre part of the fuselage. Breaking the tip should not affect the airworthiness of the plane but break the centre part will definitely be. Anyway, it's just my concept waiting to be proven.
Thanks for the input anyway. At least I know I my experiment fails, I will have successful examples to follow.
Old Dec 11, 2006, 01:00 AM
Joe Yap is offline
Singapore
Joined Nov 2001
The fins were temporarily tacked on to the fuselage to blend the fuselage joint with it. After that, the fins were removed and the carbon longerons were installed on both sides of each fuselage. Prior to that, a small groove was sanded to receive the longeron on each side. The dents and gouges on the foam surfaces were filled and sanded. The fuselages are ready for glassing.
Old Dec 11, 2006, 01:04 AM
Joe Yap is offline
Singapore
Joined Nov 2001
The fuselages havd received the first layer of medium weight cloth. Now awaiting for the resin to cure.
Old Mar 05, 2007, 09:02 AM
Joe Yap is offline
Singapore
Joined Nov 2001
After cutting the wing cores a few months ago, I got distracted by other projects. Now they are done, I expedite on the project in order to get at least one model flying before the monsson wind ends. The wing core are cut from pink foam and are covered with 1/64" plywood. The LEs are made of spruce instead of balsa in order to take the bashing of bush landings. Although it sounds heavy, the fuselage and wing assembly weighs at 20 oz at this point, without radio, paint and tailplane.
Old Mar 08, 2007, 12:51 AM
Joe Yap is offline
Singapore
Joined Nov 2001
The fuselage and canopy are painted with a thick coat of primer before rubbing down with wet & dry fine sandpaper. After filling and sanding the dents and pin holes with putty, I coat them with another layer of primer before the white Automotive paint. Some dust managed to get stuck on the wet paint but I'll leave the paint to cure and buff them off later. Anyway, I decided to do the paint scheme after the maiden. For the time being, I'll leave it as it is.
Old Mar 08, 2007, 12:53 AM
Joe Yap is offline
Singapore
Joined Nov 2001
I tried covering the wings with Monokote, but with poor results. It will not stick well at low heat but when I turned up the heat, it starts to bubble. I tore off the monokote and re-do it with Oracover, which turns out to be much better.
Old Mar 08, 2007, 03:13 AM
Joe Yap is offline
Singapore
Joined Nov 2001
I've fully covered the wings and tail. The aileron servos are installed in place with silicon.
Old Mar 08, 2007, 05:03 AM
Adrian B. is offline
Find More Posts by Adrian B.
Adrian B.'s Avatar
Cape Town, South Africa
Joined Sep 2006
Servo's
Hey Joe,
Looks great. Are those Hitec servo's I see in the wing.
I used the HS125MG on my jart and have already stripped 3 of them. I'm now planning on moving to something else, probably JR's
Adrian B. is offline Find More Posts by Adrian B.
Old Mar 08, 2007, 07:14 AM
Joe Yap is offline
Singapore
Joined Nov 2001
Yes, they are. I've heard about that but since I got them sitting on my table for months, I decided to go ahead and use them anyway. If they got stripped, they can still be easiliy replaced.
Old Mar 08, 2007, 07:49 AM
Joe Yap is offline
Singapore
Joined Nov 2001
I dry fitted all the parts and equipment. At this point, it weighs only 30oz. I'll expect to gain another 1 or 2 after completion and balancing.
Old Mar 08, 2007, 07:52 PM
samotage is offline
find me @samotage
samotage's Avatar
Melbourne Australia
Joined Jul 2005
Hey Joe,
FWIW, I've only had one issue with 125's and that was after my Jart landed off the air for a pretty ugly landing. No structural damage, just 2 stripped servos - one aileron, the other elevator.
Sam.
Old Mar 09, 2007, 05:12 AM
Joe Yap is offline
Singapore
Joined Nov 2001
When I was trying to spray some Metallic Purple Lustrekote over the white, the expired spray can give me a shock when it intermittently blurted blotches of paint and destroyed my work. I resort to remove all the paint and primer with thinner and started all over.
After giving the final coat of primer, *my wife told me that it looks much better with the gray primer on instead of the white. I gladly accept the idea thinking that I would not have the time for the white paint anyway if I want to fly it tommorow. For the whole afternoon, I did most of the stuff.
I still have the ailerons to rig and install the wing retention system. I can now estimate that the AUW will be around 36oz or slightly over 1kg.
* Hint : When you wife does contribute to your hobby, you better heed for her advise if you want to stay in this hobby, whether you like it or not.
Rant Why I will now only shop locally (and never again from Tower) Peter Young Vendor Talk 46 May 27, 2005 05:44 PM
HELP From singapore Spy king Beginner Training Area (Aircraft-Electric) 2 Mar 28, 2004 01:21 AM
Discussion Group order from Singapore/Malaysia tkl2001 Micro Helis 4 Dec 19, 2003 02:39 AM
Maiden photos from Singapore.. simingx Aerial Photography 2 Oct 18, 2003 01:22 PM
Great Service - Again - From Sal & NSP! bobandris Vendor Talk 10 May 21, 2002 12:22 AM
