Espritmodel.com Heli Air
Old Jul 21, 2001, 04:30 AM
Richard M's Avatar
Worcestershire, England
Joined Jul 2001
RD6000 TX with Hitec PCM RX?
I bought a Sanwa/Airtronics RD6000 TX ('cos I need to do helis) and I was hoping that it would be compatible with my Hitec PCM RX.
I've tried PCM mode 1 and PCM mode 2 on the RD6000 but my Hitec RX just doesn't want to know (works fine with my Hitec Prism 7 PCM Tx).
Does anyone know which PCM RXs are compatible with the RD6000 (apart from the Sanwa/Airtronics one of course!)?
Richard.
Richard M is offline Find More Posts by Richard M
Old Jul 21, 2001, 06:59 AM
Madison Ms. USA
Joined Jan 2000
Richard,
I believe that Airtronics are "positive shift" like JR.If that is true; you may have a Futaba/Hitec compatible rec, which is negative, shift I believe.
Sligh
Sligh is offline Find More Posts by Sligh
Old Jul 21, 2001, 10:30 AM
Radix malorum est cupiditas
radix2's Avatar
Joined Jul 2000
Actually, the RD6000 can transmit positive or negative shift, so you may give that a whirl.
I do believe, however, that there is no standard for PCM encoding, so you cannot mix and match manufacturers when using PCM.
hopefully some PCM experts can chime in - also check the FAQ...
radix2 is offline Find More Posts by radix2
Discussion JR Tx with Hitec Rx? icmartin Sailplane Talk 2 Apr 07, 2007 10:14 PM
Airtronics RD6000 Tx with 8ch. Rx $150.00 FiremanJoe Aircraft - General - Radio Equipment (FS/W) 1 Sep 28, 2004 10:42 PM
Airtronics TX with Hitec receiver ? Captain Ed Radios 2 Apr 06, 2004 07:22 PM
FS: Hitec NEON 3CH Tx with 6 CH Rx FREE SHIPPING Rudderman98 Aircraft - Electric - Airplanes (FS/W) 4 Jan 04, 2004 03:54 PM
Hitec Laser 4 TX, with Micro 555 RX, ch. 36 ben1000 Aircraft - Electric - Airplanes (FS/W) 1 Mar 09, 2003 06:34 PM
