Old Nov 26, 2006, 04:41 PM
Belfenson is offline
Find More Posts by Belfenson
Seville San Pablo, Spain
Joined Sep 2004
somebody can tell me how to get more rpm of one Speed 400 6 V Please?????
Hi all
I am using the Graupner Speed 400 6V and QRP 400 6V for F5D and I would like to get more rpm and more power at this motors , someone know how I can modify it???
Thank you
Regards.
Belfenson.
Belfenson is offline Find More Posts by Belfenson
Old Nov 26, 2006, 07:31 PM
himeros is offline
Find More Posts by himeros
O. C. CA
Joined Jan 2005
The only way I know is to apply more voltage to this motor, if you have timed it already. Of course the motor will not last long if you put too much voltage to it. Good luck
Himeros
himeros is offline Find More Posts by himeros
Old Nov 26, 2006, 09:23 PM
Digix is offline
Find More Posts by Digix
Joined Dec 2005
rewind it with less turns, speed is proportional to that.
but on high speed you will get more magnetic loses, for my it was speed limiting factor.
better way is ass suggested before, increase voltage, speed is proportional to voltage too. it is completely safe for motor(if you keep same load) but too much voltage can break motor controller.
Digix is offline Find More Posts by Digix
Old Nov 27, 2006, 05:08 AM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
I've run 6v 400's reliably on 3s LIPO for years. The theoretical best power is up around 70K RPM and 40v....however no one expects the brushes to be able to stay in contact at that RPM.
If F5D allows 4s LIPO, try that with as deep gearing as you can buy.
On 3s LIPO I use 4:1 boxes and 10x7 props. Very good power and efficiency.
On 4s something like an 8x4.5 folder on 4:1 should be in range. Prop for about 7-8A only.
No guarantees. Uncharted territory. But you should be able to get 150W at about 70% efficiency maybe..
Old Nov 27, 2006, 05:38 AM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
I assume this is for S400 6V stock pylon racing.
- Advance the timing by twisting the end cap in the direction of motor rotation.
- Buy lots of motors and test them under load to find the "good" ones. The load should probably be a slightly smaller prop to allow for unloading in the air.
- Use good batteries,a low resistance controller, short wires and low resistance connectors. Get as much power as possible to the motor.
- Use the batteries hot off the charger. Voltage for Nimh is much higher if the cells start the discharge at 140 F/ 60 C. Not quite as dramatic for NiCd but the effect is there.
Any other change to the motor and it will cease to be a 6V S400.
Pat MacKenzie
pmackenzie is offline Find More Posts by pmackenzie
Old Nov 27, 2006, 08:09 AM
beer-man is offline
Find More Posts by beer-man
USA, NY, Syracuse
Joined May 2005
Here my post on this, follow the links and you'll see not all can motors are the same inside.
http://www.rcgroups.com/forums/showthread.php?t=436918
beer-man is offline Find More Posts by beer-man
Old Nov 27, 2006, 08:35 AM
pmpjohn is offline
Find More Posts by pmpjohn
Dr John
pmpjohn's Avatar
Lake Placid, Florida
Joined Dec 2001
pmackenzie
Are you sure about advancing the timing by rotating the endbell in the direction of motor rotation?
John
pmpjohn is offline Find More Posts by pmpjohn
Old Nov 28, 2006, 04:31 PM
BeavrdamElectric is offline
Find More Posts by BeavrdamElectric
Beaverdam Creek, VA
Joined Aug 2005
You need to turn the end plate against the direction of rotation to advance the timing.
Good Luck!
BeavrdamElectric is offline Find More Posts by BeavrdamElectric
Old Nov 28, 2006, 06:47 PM
pmackenzie's Avatar
Joined Dec 2002
Oops!
Obviously been a while since I timed a motor !
I was perhaps thinking of Astro motors where you turn the flux ring in the direction of rotation.
Just to be sure I will break out a buggy motor and double check.
Pat MacKenzie
Can any one tell me how to make a homemade gas powered jet turbine jet engine? Zupo Fuel Jet Talk 44 May 11, 2008 03:10 PM
Help! Anyone can tell me how can I measure the Rm of a brushless? HKAero-Nuts Power Systems 3 Sep 22, 2006 07:55 AM
Discussion Can somebody tell me how to turn? mdennis Thermal 9 Sep 16, 2006 12:18 PM
Can anyone tell me how long there order took to get to them from Nesail? kushal_22 Vendor Talk 23 Jun 20, 2002 06:07 PM
Help!! Can someone please tell me how to hook up a twin in paralell? Joe Elston Power Systems 6 Oct 22, 2001 06:37 PM
