Old Nov 25, 2006, 07:55 AM
Joined Jul 2006
new ds airfoils for extreme DS speed
Hi guys,
I developed several airfoils whick could be well suited for top ds speeds. The DP-airfoils are made for extreme top speed DS-sessions (Re = 1.000.000 - 2.000.000). They are thick and damm fast. If you will use them for a normal F3B or F3F soarer you will be disappointed. The design has a much longer laminar flow than the DS-19 which is used by Brian McLean's Extreme. This should lead to a remarkable higher top DS-speed. The airfoils can be used by every private person. A commercial use is restricted by the designers copyright. If a commercial use is desired or someone needs a different design for a different task please contact dirk.pflug@bluetrust.de If you have build a soarer with one of these airfoils please contact me to tell me your flying impressions. If you are interested in a substantial support for a complete DS-soarer by my person or if you have any remarks to the airfoils please contact me.
But I just found out that I don´t know how to insert the *.dat files. Does anybody knows how to insert them?
Dirk Pflug
Slopesoarer is offline Find More Posts by Slopesoarer
Old Nov 25, 2006, 11:37 AM
Joined Nov 2002
Welcome to RC Groups, Dirk.
I've been a fan of your DP 1.89/7.83 section for a while now and I'm looking forward to seeing the rest of your airfoils.
For some reason .DAT and .COR files will not upload here but you can drop the coordinates in Notepad and post them as a .txt file.
Tony D.
Tony D. is offline Find More Posts by Tony D.
Old Nov 26, 2006, 05:14 AM
Joined Jul 2006
Hi Tony,
good to here that you have a lot of fun with the DP 1.89/7.83 section. I´ll try to post my DS airfoils in a text file. These airfoils are for realy high DS speed. For F3F, F3B a different design is necessary. So do not use them to "replace" the DP 1.89/7.83.
Dirk
Old Nov 26, 2006, 05:26 AM
Joined Jul 2006
Hi guys,
I just got an email from jo grini. He has posted the new DP-DS airfoils in *.dat format on his webpage http://www.grini.no/ Select DS-site and you will find them there.
Dirk
Old Nov 26, 2006, 10:50 AM
Guest
Oceanside
Joined Nov 2002
The links on http://www.grini.no/ are not yet working. I am unable to file-> Save as.
sl33pdirt is offline Find More Posts by sl33pdirt
Old Nov 26, 2006, 11:18 AM
Flounder
Utahrd's Avatar
Three turns into Eddie’s High Nowhere
Joined Aug 2006
Thanks for making these available.
Utahrd is offline Find More Posts by Utahrd
Old Nov 27, 2006, 12:49 AM
"just one more pass"
marfish's Avatar
Bakersfield, Ca.
Joined Sep 2005
Same here. I am interested in putting them in my Profili program.
Marlan
marfish is offline Find More Posts by marfish
Old Nov 27, 2006, 04:08 AM
Joined Jul 2006
Yeah that´s true,
I checked it: It´s not possible to save the file on my computer. I´ll tell Jo and I hope he will repair the link.
Dirk
Old Nov 28, 2006, 06:18 PM
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Seems like it works now?
target is offline Find More Posts by target
Latest blog entry: Stork 4 Pro X-tail from...
Old Nov 28, 2006, 07:54 PM
Flounder
Utahrd's Avatar
Joined Aug 2006
Yep, works for me too.
Wanted wanted, NIB or new-like sailplane for DS. 2m or bigger. Mike the Snake Aircraft - Sailplanes (FS/W) 0 Jul 02, 2006 06:45 AM
New Sailplane designed for DS by H. Quabeck "DYNAMOD" hkm-usa Dynamic Soaring 21 Dec 02, 2004 01:52 AM
New tiger moth for speed 400 surfer Scale Electric Planes 40 Jul 05, 2003 10:25 AM
Watt-Age's new Extra 300 for Speed 400 chris hinz Sport Planes 54 Aug 07, 2001 05:46 PM
