Old Jan 21, 2009, 01:09 PM
adbradley is offline
Find More Posts by adbradley
adbradley's Avatar
Joined Mar 2007
put some skis on that thing, and get it in the air!
adbradley is offline Find More Posts by adbradley
Old Nov 07, 2009, 08:26 PM
NanoSio2 is offline
Find More Posts by NanoSio2
Remember the 131st TFW MO ANG
NanoSio2's Avatar
USA, MN, Apple Valley
Joined May 2005
Here's mine - just flew the maiden today. The flight went well - can't believe how slow it flies! Also, here's a pic from airliners.net of the full scale plane I intended to model.
Scott
NanoSio2 is offline Find More Posts by NanoSio2
Old Nov 07, 2009, 09:06 PM
csc is offline
csc
Find More Posts by csc
csc
United States, AZ, Phoenix
Joined Apr 2004
Very Nice! I need to pull mine out and get it finished.
csc is offline Find More Posts by csc
Old Nov 08, 2009, 10:12 AM
delsol is offline
Find More Posts by delsol
delsol's Avatar
Merced,Ca.
Joined Jul 2006
Scott,
Looks really nice, flew my 180 last week. Your right it does fly slow but that one of the things I like about it.
Brad
delsol is offline Find More Posts by delsol
Old Nov 08, 2009, 10:55 AM
Mountain Models is offline
Find More Posts by Mountain Models
BYOP - Build Your Own Planes
Mountain Models's Avatar
United States, WI, Appleton
Joined Mar 2001
Scott,
I like how it came out. You did a good job making it look like the real one in the picture.
I need to finish up a new flyable one for myself again. I miss flying the Cessna, it's a real pussycat.
Brian
Mountain Models is offline Find More Posts by Mountain Models
Old Nov 09, 2009, 06:09 PM
NanoSio2 is offline
NanoSio2's Avatar
Joined May 2005
Thanks everyone for the comments! If I get a volunteer for the camera, I'll try to record some flying video.
It's a great kit Brian - I really enjoyed the build. I'm sure I'll build another - maybe a floatplane next time.
This was my third balsa build, my first using Titebond II instead of CA, and my first using a magnetic build board. I didn't realize how much I disliked CA and T-pins.
Scott
Old Nov 22, 2009, 01:04 PM
angelfood is offline
Find More Posts by angelfood
Joined Sep 2009
I'd like to build one of these and start with a brushless outrunner. Does anyone have any suggestions on a motor mount which does NOT use a stick?
angelfood is offline Find More Posts by angelfood
Reply With Quote  (Disabled)
Old Nov 22, 2009, 03:13 PM
portablevcb is offline
Find More Posts by portablevcb
Neophyte hacker
portablevcb's Avatar
Albuquerque, NM USA
Joined Sep 2003
On my old one I did use a CDROM that was not on a stick. I installed another firewall to mount the motor. Very simple.
The only problem is you have to carve out the nose cone to get clearance for the bell.
Might want to try the little Hacker A10. It is small enough that it will fit in the nose cone area.
Each outrunner is different in diameter and depth so you just have to pick one and then make the motor mount.
charlie
portablevcb is offline Find More Posts by portablevcb
Old Dec 11, 2014, 04:14 PM
rchrde is offline
Find More Posts by rchrde
United States, AL, Tuscaloosa
Joined Jan 2014
MM C-180 wing discrepancy - need help
I am building the MM C-180, and while the fuselage went smoothly I got stuck as I started the wing. The balsa for the trailing edge on the left hand side does not match the plan, being about a centimeter short. I've measured the plans from center to tip and the left side measurement is 46 cm as compared to 45 cm on the right.
I don't whether to try to build two wings according to the right hand drawing or even how to attempt that. I've tried unsuccessfully to reach Brian at Mountain Models, with no response to either phone messages or email. Does anyone here have any idea how I can get moving again on this plane?
rchrde is offline Find More Posts by rchrde
Old Dec 11, 2014, 05:27 PM
turbojoe is offline
Find More Posts by turbojoe
M0unt@in M0del$ minion
turbojoe's Avatar
United States, AZ, Mesa
Joined Jul 2002
I built mine a LONG time ago and had no issues that I can recall. To see a part not fit in a Mountain Models kit is something that doesn't happen with any frequency but something obviously went wrong there. I'd just cut and glue a piece of scrap balsa to it and move on. Don't let that slow you down. This thing comes out so light that if you do even a reasonably decent glue job that add on piece will never compromise the wing integrity.
Brian is working hard to finish his degree and can be hard to reach at times. Just post questions here and you'll get all kinds of good help.
Joe
turbojoe is offline Find More Posts by turbojoe
Old Dec 11, 2014, 07:57 PM
DBlum is offline
Find More Posts by DBlum
DBlum's Avatar
Raleigh/Durham Intl, North Carolina, United States
Joined Nov 2001
if the balsa trailing edges are the same length, just glue the last rib to the end of the trailing edge and dont worry about the plans. Just make the ribs parallel to the ribs on the plans. You could even make the spars the same length on both sides and mark the rib locations on both in the same place before pinning them to the plans. This will insure every thing will be the same side to side. If you can see through the plans, you could turn them over and build on the back side also.
DBlum is offline Find More Posts by DBlum
Old Dec 11, 2014, 08:39 PM
turbojoe is offline
turbojoe's Avatar
Joined Jul 2002
Yep, listen to Dave. He's the one that designed this little jewel.
Joe
Old Dec 12, 2014, 08:57 AM
rchrde is offline
Joined Jan 2014
Thanks very much guys. Joe, my first thought was to just add a piece, but then the wings would be different lengths or I was afraid something would be out of whack further along in the build. I think i'm more comfortable with Dblum's (Dave's?) approach, though it may be a bit tricky for a relative novice like myself who is so dependent on following the plans to the letter. I'm going to move forward with it though and may post further questions if I get stuck.
Thanks again,
Richard
Old Dec 12, 2014, 05:28 PM
turbojoe is offline
turbojoe's Avatar
Joined Jul 2002
Man, I gotta pay more attention. I just re-read your first post. Not sure why I thought you were saying the parts were too short when you clearly said the plans were not consistent side to side. Sure glad Dave stepped in and saved you from me.
Joe
Old Dec 12, 2014, 07:38 PM
rchrde is offline
Joined Jan 2014
I'm glad I saved me from you too Joe! I just figured you were a little more relaxed in your tolerances than I'm comfortable with!
Wanted Mountain Models/Laser Arts Cessna 180 BD Flyer Aircraft - Electric - Airplanes (FS/W) 1 Mar 07, 2007 08:13 AM
Winch plans from Laser Arts balsaaddict Thermal 2 Dec 11, 2005 01:31 PM
MM Cessna 180 on floats, pictures from today Martin Hunter Scale Kit/Scratch Built 37 Aug 25, 2002 09:45 PM
