Old Nov 26, 2006, 09:34 AM
BD Flyer is offline
Find More Posts by BD Flyer
BD Flyer's Avatar
United States, NJ, Monroe Township
Joined Aug 2006
Originally Posted by rcfun33
This was my first balsa kit and shrink covering and my 3rd plane to fly. It is a cool little plane. My covering job is not the best, but it still looks great from a small distance and is cool in the air. I don't fly it often, because it requires taking the wing off to change batteries and it is a lightweight delicate plane. I have a little hanger rash from the removal and replacement of the wing.
It still looks and flies nice. Here is a picture from earlier this summer.
-Dave
How do you remove the wing?
BD Flyer is offline Find More Posts by BD Flyer
Old Nov 26, 2006, 09:38 AM
BD Flyer is offline
BD Flyer's Avatar
Joined Aug 2006
Originally Posted by Griffin
Ok, I'll play.
SOLITE: opaque colors: Black, dark blue, green
semi opaque: Cream, red, yellow, white, silver. At a distance, these all look pretty good though.
SOLARFILM: opaque colors: All solids, including White! (White looks just like a new Cessna and will cover anything!). Oddly enough, Red is probably the weakest color, and you can see slightly through it.
On this model, I used solite and would probably do it again. The structure is light and you would need to be carefull with the stronger shrinking solarfilm. But the solarfilm colors are so good, it might be worth it.
Heavier coverings such as monokote would be a disaster weight wise and would squeeze and twist it like crazy.
-Steve
Thanks Steve,
So it would be much easier to cover with solite?
Well if I have trouble covering the plane, my neighbor could help me. He has a lot of experience with building balsa wood planes.
Bill
Old Nov 26, 2006, 01:20 PM
rcfun33 is offline
Find More Posts by rcfun33
Northern Colorado
Joined May 2004
I built to the instructions and they have you use a wing bolt to hold the wing down and "pins" made of wire that poke into the fuselage to hold the wing struts in place. The pins on these wing struts have caused me problems (poking holes in the covering). I've seen tape used to hold the struts to the wing and strong magnets to hold the wing struts to the fuselage. This woud prevent poking the covering with the "pins".
-Dave
rcfun33 is offline Find More Posts by rcfun33
Old Nov 26, 2006, 04:57 PM
BD Flyer is offline
BD Flyer's Avatar
Joined Aug 2006
-Dave
So, every time you have to take the battery pack out, you have to take the pins out and then when you put the battery pack back in, you have to poke a hole in the covering to put the pins back in.
That sucks!
Old Nov 26, 2006, 07:30 PM
rcfun33 is offline
Northern Colorado
Joined May 2004
Normally, you would put the "pins" back in the same hole and wouldn't create new holes. However, when you have something sharp like this around a light film it is easy to accidentally poke the covering or even slice it a little. I've gotten a lot better at it. I now don't completely remove the wing from the plane but just remove the wing struts from the fuselage and let them hang below the fuselage while sliding the wing back.
-Dave
Old Nov 26, 2006, 09:50 PM
portablevcb is offline
Find More Posts by portablevcb
Neophyte hacker
portablevcb's Avatar
Albuquerque, NM USA
Joined Sep 2003
Ok, so I am a bit lazy. So, I left the side windows off the airplane and made the ESC and battery leads long enough to reach out the window. When I wanted to charge the battery I just pulled the lead out through the window and hooked it up. And, yes, I did this with LiPo batteries for many flights (well over 100). Oh, I also left off the struts. This was a working airplane for me. I even used it to teach a couple of people how to fly.
I would recommend Solite or Solarfilm for a first covering. Solite is less likely to cause warping, but, is more difficult to control during covering (static cling is a pain!).
Color. Pick one you can see against the sky. Silver is bad!! White is OK with bright trim colors. Also put a pattern on the plane so you can tell up from down. Big bold pattern on top of wing, plain on the bottom for example.
Have fun with it.
charlie
portablevcb is offline Find More Posts by portablevcb
Old Nov 27, 2006, 02:26 PM
BD Flyer is offline
BD Flyer's Avatar
Joined Aug 2006
Thanks guys. You cleared all of that covering stuff and wing stuff up.
Bill
Old Nov 27, 2006, 10:11 PM
rcfun33 is offline
Northern Colorado
Joined May 2004
Anyway, like I said. I think it is a cool plane. It flies well and I like the scale look in the air. I should take it out more, but since it is one of my favorites I'm afraid of damaging it.
-Dave
Old Nov 27, 2006, 10:25 PM
Neophyte hacker
Albuquerque, NM USA
Joined Sep 2003
Dave,
My flying buddy and I both had them for a long time. We called them our "wind socks" because we'd fly them to see if the wind was calm enough to fly the rest of our 'fleet'.
They are also great for chasing thermals. I followed a hawk in Phoenix one day and stayed in the air for almost an hour before my neck got stiff. Then had to spin down out of the rising air to get it back.
Fun plane.
charlie
Old Nov 30, 2006, 10:00 AM
delsol is offline
Find More Posts by delsol
delsol's Avatar
Merced,Ca.
Joined Jul 2006
Hi guys,
I just received my 180 cessna and have been reading the threads on her. I've read that you need to but some washout
on the wings. I'm sorry but I'm not sure what this is and how to
to do it? Can anyone help me out!!!
Thanks Brad
delsol is offline Find More Posts by delsol
Old Nov 30, 2006, 10:33 AM
TheLost is offline
Find More Posts by TheLost
My Bulldog is my copilot ..
TheLost's Avatar
Joined Feb 2004
Originally Posted by delsol
Hi guys,
Thanks Brad
With one hand grab the wing in the middle... with the other hand grab the end of one of the wings. Twist the wing so that the tail edge is higher then the leading edge.. (now the hard part if you don't have a helper).. use a heat gun to shink the covering... repeat until you get the proper washout to stay.
The MM/LA/DBlum 180 is a great little kit.. Love mine...
~Brian
TheLost is offline Find More Posts by TheLost
Old Nov 30, 2006, 11:17 AM
delsol is offline
delsol's Avatar
Merced,Ca.
Joined Jul 2006
Brian,
What a gorgeous little 180 you built. Hope my plane will come
out looking that good. Would you recommend putting washout
in before flying her & if so how much or wait to see how see
flys without it?
Brad
Old Nov 30, 2006, 11:27 AM
jofrost is offline
Find More Posts by jofrost
It flew once before...
jofrost's Avatar
Northwood , New Hampshire
Joined Jul 2004
Bill ,
You will really love this little plane . I fly mine on a Feigo 12mm BL with a 2s TP 930 mah lipo . Anytime it is perfectly calm I drag it out . Great for low slow flybys . Pretty easy build . I covered mine with "doculam" which shrinks a bit more aggresively than some of the covering mentioned . AUW is about 9oz.
It can take a bit of a breeze , but is much more fun when it is calm .Enjoy !
-John
jofrost is offline Find More Posts by jofrost
Old Nov 30, 2006, 03:47 PM
BD Flyer is offline
BD Flyer's Avatar
Joined Aug 2006
Thanks John!
Wanted Mountain Models/Laser Arts Cessna 180 BD Flyer Aircraft - Electric - Airplanes (FS/W) 1 Mar 07, 2007 08:13 AM
Winch plans from Laser Arts balsaaddict Thermal 2 Dec 11, 2005 01:31 PM
MM Cessna 180 on floats, pictures from today Martin Hunter Scale Kit/Scratch Built 37 Aug 25, 2002 09:45 PM
