Yes, I believe that the thrust angle is built in and the hole for the gearbox is a little smaller than a similar sized balsa stick is supposed to be (though I thought that the stick that came with the kit was laser cut and fit the gearbox). I understand the reasoning for this is that balsa is cut to the English measurement system and GWS uses the metric system of measurement. I know that when I used the stick that came in the kit there was some room for movement when it was placed in the holes in the formers but when I replaced it after it had broken the stick fit exactly in the former holes as I only sanded the end that the motor was going fit onto.
Rob |
Thanks for the stick info guys. And as promised a few pictures of the progress so far. I still need to do the landing gear, the vertical stab is done but didn't feel like taping it or pining it on for the pics(lazy).I need to do a few more stripes on the horizontal stab . I will do the windshield and glue the vertical stab last so I don't stick my fat thumbs through them while trying to do other things.
Mike |
Thanks guys,
Did you notice, no real close ups It does have its share of wrinkles. Covering the cowl was a little easier then I thought it would be, I never tried covering anything like a cowl before.I thought I was going to take the easy way out and just paint the cowl(lazy).Mike |
Thanks John for posting the pic's!
The little 180 flew great. With just a little touch of the throttle she was off the ground within 6 ft. and up flying. I had to make a few clicks to trim her out and she was on her way. She has more power than she needs and I flew her under 1/2 throttle most of the flight. I flew her for around 5 mins. then brought her in not knowing how long the 3s 460mah battery would last, when I got home I put the battery on the charger and it showed 76% battery life still left. All I can say is that I'm very happy I built the the Cessna 180. Mike, Your plane looks GREAT!!!!!!!!!!!!!! and your going to love how she fly's. Did you cut out your registration numbers they look a lot better than mine does. Keep up the great job! Brad |
Congrats on the successful maiden! That's a great looking Cessna 180! Bill |
Hi Mike,
The most successful brushed system I have ever used was the IPS-A, 3 cell lithuim, and GWS 8x6. Almost brushless power if you need it, and the cheap little ips motors lasted a surprisingly long time. The general rule is prop down an inch from the recomended 2 cell props and don't pull over 2 amps. I'm a brushless convert now, but the 3 cell/ips combo worked so well I could see using it again someday. -Steve |
| Thread Tools | |
| Wanted Mountain Models/Laser Arts Cessna 180 | BD Flyer | Aircraft - Electric - Airplanes (FS/W) | 1 | Mar 07, 2007 08:13 AM |
| Winch plans from Laser Arts | balsaaddict | Thermal | 2 | Dec 11, 2005 01:31 PM |
| MM Cessna 180 on floats, pictures from today | Martin Hunter | Scale Electric Planes | 37 | Aug 25, 2002 09:45 PM |
