Old Nov 24, 2006, 07:56 PM
BD Flyer is offline
Find More Posts by BD Flyer
BD Flyer's Avatar
United States, NJ, Monroe Township
Joined Aug 2006
Cessna 180 from Laser Arts
Hello everybody, I was thinking about buying the Cessna 180 from Laser arts:http://www.mountainmodels.com/produc...f4959201fb3712
I've heard that Laser Arts plane kits are very good and their planes are very good. This would be my first balsa wood plane so would you reccomend this for a first balsa wood kit? Also, is this kit hard to build? One more question, Can you guys give me a good setup that will give me 15-20 minute flight times? I am deciding wether to get lipo batteries. It scares me a little knowing that they can catch on fire if you don't keep an eye on them when they are charging. Oh, I forgot, I have one more question, This plane is a 3 channel, right? Any help will be appreciated by answering any of my questions!
Bill
BD Flyer is offline Find More Posts by BD Flyer
Old Nov 24, 2006, 08:06 PM
Valid8r is offline
Find More Posts by Valid8r
Valid8r
Valid8r's Avatar
Boston and Belgium
Joined Jul 2004
The Laser Arts Cessna 180 is a great little plane. It was my second balsa kit (first was the MM SmoothE). This was my first kit to cover (the SmoothE does not require shrinkable covering). I still love the 180 and you can find a number of build threads for this plane. It flies very well, but only in very little wind due to it's incredibly light weight. It is a 3 channel (no ailerons) plane.
The kit is easy to build (as I said above, this was my first ever laser cut balsa kit) and it comes with everything you need except the motor and electronics.
Have fun if you decide to get the kit.
Jon
Valid8r is offline Find More Posts by Valid8r
Old Nov 24, 2006, 08:13 PM
BD Flyer is offline
BD Flyer's Avatar
Joined Aug 2006
Jon
Thanks Jon! I might get this to build during the cold days. So, is it hard to cover? Also, How do you add stripes and stuff to it like the one in the picture?
Old Nov 24, 2006, 10:33 PM
BD Flyer is offline
BD Flyer's Avatar
Joined Aug 2006
Also, where are all of the threads about this plane?
Old Nov 24, 2006, 11:18 PM
Griffin is offline
Find More Posts by Griffin
WAA-08 Survivor
Griffin's Avatar
Joined May 2004
Try searching for Mountain Models Cessna 180 instead of laser arts.
To answer some of your questions,
Yes, it's a PERFECT first build. But not first plane. It flies very easy and very slow, but it's light construction is not tolerant of beginner cartwheels and nose ins. It is 3 channel and turns so nice it looks like it has ailerons. Stripes can be cut from covering, or you can buy the adhesive trim. A year or two ago, everyone would tell you to use So-Lite covering, but now many are using the more solid and heavier solarfilm even on small models.
Lipos? Yep, they are so good it's worth taking the safety precautions.
Good choice of plane! It's very popular so you shouldn't hesitate to ask questions as you go. -Steve
Griffin is offline Find More Posts by Griffin
Old Nov 25, 2006, 11:20 AM
BD Flyer is offline
BD Flyer's Avatar
Joined Aug 2006
Thanks, It would be my 3rd 3 channel plane. I probabaly wouldn't maiden it until next July because i'm getting a GWS Beaver and I want to practice on that for a while before I move up to a balsa wood plane. Also, I have another question, I've noticed that some covers, you could see the balsa wood through them, are they all like that?
Old Nov 25, 2006, 02:06 PM
Matthew Binder is offline
Find More Posts by Matthew Binder
The Evil Twin
Garden City, GA
Joined Feb 2004
Most lightweight covering will be very thin so, yes, you'll see thru it. The 180 is a great plane designed by Dave Blum. It's a fairly easy build if you follow the instructions and a great flier.
Matthew Binder is offline Find More Posts by Matthew Binder
Old Nov 25, 2006, 05:48 PM
BD Flyer is offline
BD Flyer's Avatar
Joined Aug 2006
Is there a cover that you can't see through?
Old Nov 25, 2006, 09:09 PM
BD Flyer is offline
BD Flyer's Avatar
Joined Aug 2006
I researched mountain models cessna 180 on here and there isn't one thread dedicated to this exact plane. There is no build threads or nothing.
Old Nov 25, 2006, 09:14 PM
Murocflyer is offline
Find More Posts by Murocflyer
Promoting Model Aviation...
Murocflyer's Avatar
United States, CA, Tehachapi
Joined Nov 2005
Not true. Look here:
http://www.rcgroups.com/forums/searc...archid=8174052
Murocflyer is offline Find More Posts by Murocflyer
Old Nov 25, 2006, 09:18 PM
BD Flyer is offline
BD Flyer's Avatar
Joined Aug 2006
Oh, wow, there is alot!
Nevermind then
Old Nov 25, 2006, 09:46 PM
Murocflyer's Avatar
Joined Nov 2005
Nevermind then
You bet. It's a sweet little plane!
Old Nov 25, 2006, 10:06 PM
rcfun33 is offline
Find More Posts by rcfun33
Northern Colorado
Joined May 2004
This was my first balsa kit and shrink covering and my 3rd plane to fly. It is a cool little plane. My covering job is not the best, but it still looks great from a small distance and is cool in the air. I don't fly it often, because it requires taking the wing off to change batteries and it is a lightweight delicate plane. I have a little hanger rash from the removal and replacement of the wing.
It still looks and flies nice. Here is a picture from earlier this summer.
-Dave
rcfun33 is offline Find More Posts by rcfun33
Old Nov 25, 2006, 10:48 PM
Eric_N57105 is offline
Find More Posts by Eric_N57105
RC Bum
Eric_N57105's Avatar
Riverside, CA
Joined Apr 2006
Normally, unless it says it is transparent, Monokote, Econokote, etc. are opaque.
Eric
www.ke6us.com
Eric_N57105 is offline Find More Posts by Eric_N57105
Old Nov 25, 2006, 11:15 PM
Griffin is offline
WAA-08 Survivor
Griffin's Avatar
Joined May 2004
Ok, I'll play.
SOLITE: opaque colors: Black, dark blue, green
semi opaque: Cream, red, yellow, white, silver. At a distance, these all look pretty good though.
SOLARFILM: opaque colors: All solids, including White! (White looks just like a new Cessna and will cover anything!). Oddly enough, Red is probably the weakest color, and you can see slightly through it.
On this model, I used solite and would probably do it again. The structure is light and you would need to be carefull with the stronger shrinking solarfilm. But the solarfilm colors are so good, it might be worth it.
Heavier coverings such as monokote would be a disaster weight wise and would squeeze and twist it like crazy.
-Steve
Wanted Mountain Models/Laser Arts Cessna 180 BD Flyer Aircraft - Electric - Airplanes (FS/W) 1 Mar 07, 2007 08:13 AM
Winch plans from Laser Arts balsaaddict Thermal 2 Dec 11, 2005 01:31 PM
MM Cessna 180 on floats, pictures from today Martin Hunter Scale Kit/Scratch Built 37 Aug 25, 2002 09:45 PM
