Old Nov 30, 2006, 12:31 PM
Larry3215 is offline
Find More Posts by Larry3215
Permanently Banned
Larry3215's Avatar
Gig Harbor, Washington, United States
Joined Sep 2003
Originally Posted by UAVPilot
OK, one hint................
2 receivers
Does that help?
Actually that helps almost as much as knowing its painted red!
Hmmm..... on second thought.... the only reason you would NEED 2 recievers is if one is mounted on the can portion and one on the spinning motor portion so they could rotate independently from each other and controll seperate things.
One controlls the motor and maybe something else. The second controls some sort of control surface.
You could get by with one battery pack and feed power along the motor support struts to the rx on the can.
On third thought tho you could just reverse mount the outrunner and you wouldnt have to use seperate recievers.
Surely your not using 15 chanells?
OK, the paint color gave more usefull info
Now Im even more intrigued!
Larry
Larry3215 is offline Find More Posts by Larry3215
Old Nov 30, 2006, 12:48 PM
Hepdog is offline
Find More Posts by Hepdog
Registered Plan-a-holic
Hepdog's Avatar
Stonewall, MB, Can
Joined Jul 2004
I'm with Larry, it's red...
Hmmmmm:
2 servos
2 RX's
1 motor
The only conclusion I can draw is (removed)
"Why didn't I think of that...sooner".
Hepdog is offline Find More Posts by Hepdog
Old Nov 30, 2006, 01:02 PM
Permanently Banned
Larry3215's Avatar
Joined Sep 2003
OK, here is a possibility. It would require 2 packs, but the rx pack could be very small - even a single cell with the right Rx.
Larry
Old Nov 30, 2006, 01:07 PM
snakeX2 is offline
Find More Posts by snakeX2
Flap chap
snakeX2's Avatar
Most Southern England, Brighton UK
Joined May 2004
I'd say that if you look closely at the motor angle in proportion to the 'can' body, that it obvious that the motor is angled, meaning that it is possible that it is controlled rather like a helicopter rotor; cyclic control? I bet that the motor is hinged and servo actuated, probably by two servos. He can angle the thrust that way, in relation to the 'can' body.
J,
snakeX2 is offline Find More Posts by snakeX2
Old Nov 30, 2006, 01:28 PM
UAVPilot is offline
Find More Posts by UAVPilot
Foam Floats Better
UAVPilot's Avatar
The Big Country of TX.
Larry
You pretty much got it Larry
The motor is a gear driven Feigao 1208436 and mounted ridged , spinning a 10 x 4 SF prop. The large prop is what gives it the torque to spin the body.
I can't give to much detail, patents are pending
UAVPilot is offline Find More Posts by UAVPilot
Old Nov 30, 2006, 01:36 PM
Hepdog is offline
Hepdog's Avatar
Stonewall, MB, Can
Joined Jul 2004
I knew this would be another one of "those" ideas
I'm good with that - pesky rip off artists. Keep it on the down low.... Now to the Batcave to replicate....muh ha ha
Old Nov 30, 2006, 02:22 PM
Permanently Banned
Larry3215's Avatar
Joined Sep 2003
You ARE a genius!
Larry
edit: actually Hepdog was on the rite track too and his musings dovetailed with mine perfectly and turned on the light bulb
Old Nov 30, 2006, 02:31 PM
Permanently Banned
Larry3215's Avatar
Joined Sep 2003
OK, didnt think about patents and moneys and all that stuff - details edited in my post above. I wont let the cat ALL the way out of the bag
Larry
Old Dec 01, 2006, 10:58 AM
rob mueller is offline
Find More Posts by rob mueller
ok, maybe it is a toy
rob mueller's Avatar
Alberta, Canada
Joined Oct 2002
Cool UAV... very cool.
rob mueller is offline Find More Posts by rob mueller
Old Dec 04, 2006, 05:56 PM
PlaneCrazee is offline
Find More Posts by PlaneCrazee
Burner!!
PlaneCrazee's Avatar
United States, AR, Sherwood
Joined Jun 2005
Didn't Maxx products sell a cube similar to that?
PlaneCrazee is offline Find More Posts by PlaneCrazee
Old Dec 04, 2006, 06:07 PM
UAVPilot is offline
Foam Floats Better
UAVPilot's Avatar
There have been flying cubes for awhile, but none of them spin while they fly.
Old Dec 04, 2006, 08:34 PM
Burner!!
Joined Jun 2005
There was a .60 glow powered saucer looking thing back in the 80's... I can't remember the name right off hand. The rim of that one did spin I believe but the engine did not. If I can find it in an old mag I'll scan it.
Old Dec 08, 2006, 01:10 PM
FASTBEN is offline
Find More Posts by FASTBEN
Cumulus Altimus
FASTBEN's Avatar
United States, TX, Keller
Joined Feb 2002
anything weared and mike shows up.LOL
ben
FASTBEN is offline Find More Posts by FASTBEN
Old Dec 08, 2006, 01:18 PM
Troy is offline
Find More Posts by Troy
Caution:Makes sharp left turns
Troy's Avatar
United States, CA, Lake Forest
Joined Feb 1999
ben
That's a weird way to spell weird.
Troy is offline Find More Posts by Troy
Old Dec 08, 2006, 02:14 PM
howardhughes is offline
Find More Posts by howardhughes
Joined Feb 2005
Flying Gyro...Take a look at this. Human powered
http://www.firebox.com/index.html?di...product&pid=21
howardhughes is offline Find More Posts by howardhughes
Discussion Slow flying, But can handle some wind?? Butch777 Scratchbuilt Indoor and Micro Models 1 Feb 19, 2007 03:43 PM
Video Flying Coke Can UAVPilot Electric Plane Talk 4 Dec 06, 2006 11:19 PM
How much flying time can you get??????? AV8er48 Parkflyers 8 Dec 22, 2004 12:57 AM
since there should be quite a few c47's flying now, can we get a review? Catkicker GWS (Grand Wing Servo) 15 Jul 20, 2004 03:54 AM
