Old Nov 21, 2006, 02:08 PM
GWSLAWNDART is offline
Find More Posts by GWSLAWNDART
Orlando
Joined Jun 2003
Formula for Calculating Battery Runtime?
Hey guys,
I was wondering if there are any online calculators or What the Formula is for Calculating the amount of Runtime for a battery, at a Certain Amp draw, at a certain voltage.
For example, a 3cell Lipo 1500mah capacity, being drawn at 10amps would last how long until the recommended voltage cut-off?
Simple math makes me think that the answer would be 1500mah capacity/10,000mah amp draw= (.15hrs * 60)= 9mins
How wrong am i guys?
Appreciate your info
Luis
GWSLAWNDART is offline Find More Posts by GWSLAWNDART
Old Nov 21, 2006, 02:26 PM
slipstick is offline
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
Simple math is all it takes. You've answered your own question .
BTW voltage doesn't make any difference, it's only current draw and capacity that count.
Steve
slipstick is offline Find More Posts by slipstick
Old Nov 21, 2006, 04:15 PM
Orlando
Joined Jun 2003
Sweet,
GoldStar for me! haha
Old Nov 21, 2006, 05:40 PM
Ohmic is offline
Find More Posts by Ohmic
USA
Joined Jan 2002
Steve
Why is voltage irrelevant?
Ohmic is offline Find More Posts by Ohmic
Old Nov 21, 2006, 05:46 PM
bob2005 is offline
Find More Posts by bob2005
Joined Oct 2005
Flight time calculator
Originally Posted by GWSLAWNDART
Hey guys,
Luis
Try Here:http://www.bphobbies.com/view.asp?id=A0320048&Nav=7
Bob
bob2005 is offline Find More Posts by bob2005
Old Nov 21, 2006, 05:59 PM
Ohmic is offline
USA
Joined Jan 2002
Originally Posted by bob2005
I was looking for the theory behind this, not a link to a web calculator. Somehow I recall Ohm's law as having three variables and I didn't think it was possible to leave one out.
Old Nov 21, 2006, 06:34 PM
Lnagel is offline
Find More Posts by Lnagel
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
Actually, two variables are left out, voltage and resistance, so Ohm's law is not applicable here. The only applicable factors are the current draw and the battery capacity in ampere hours. A 1500 mah battery can be just one cell or made up of several cells in series. Regardless of how many cells there are in the pack it will still deliver only 1.5 amps in one hour or 10 amps in 0.15 hours, or 9 minutes.
Where voltage comes into play, is that as the voltage increases, the load, i.e. prop size, has to decrease to maintain the 10 amp current flow. But, as long as the 10 amp draw is maintained, the time to deplete the battery remains the same regardless of the voltage.
Larry
Lnagel is offline Find More Posts by Lnagel
Old Nov 21, 2006, 07:47 PM
Fast Fly is offline
Find More Posts by Fast Fly
san diego, ca.
Joined Sep 2000
Here ya go Luis, & its FREE! HTTP://brantuas.com/ezcalc/dma1.asp I have used this program many times to calculate; What Motor, What Prop, How many Batteries, and you will get your run time, Amp draw, and amount of Thrust. Fast Fly
Fast Fly is offline Find More Posts by Fast Fly
Old Nov 21, 2006, 08:21 PM
Orlando
Joined Jun 2003
FastFly,
Thanks for the link, i have been using p-calc for a long time, but it doesnt have the newer motors that are out. P-calc is really good, but lacks in motor selection.
Old Apr 12, 2009, 04:04 AM
panzerd18 is offline
Find More Posts by panzerd18
panzerd18's Avatar
Melbourne, Australia
Joined Dec 2005
BP = Battery pack (in amps)
AD = Amp Draw (in amps)
X = time to deplete 1000mah pack
BPX = time to deplete battery pack
60(minutes) / AD = X
X * BP = BPX
panzerd18 is offline Find More Posts by panzerd18
Discussion Formula for determining battery capacity needed byrocat Power Systems 4 Feb 11, 2007 04:45 AM
Need formula for calculating speed for specifi prop lensrc Modeling Science 4 Apr 08, 2004 05:49 PM
What is the formula for calculating RPM at given Amps austinflyer Power Systems 2 Jan 24, 2004 04:13 AM
Battery Runtime for GWS Zero or other 370 models spyder0069 Parkflyers 1 Jul 26, 2002 02:53 PM
Formula for calculating wing area? Slope Nut Power Systems 14 May 09, 2002 02:54 AM
