Old Nov 20, 2006, 11:48 PM
kensp is offline
Find More Posts by kensp
kensp's Avatar
Darwin Australia
Joined May 2002
GWS Me-262 Build thread with the GWBLM005A Motor
I have just recieved my Early bird Kit and here are some photos of the way the components are packed in the kit box.
All the small platic bits and things like wheels and undercarriage wires were separated from the foam pieces by a layer of coregated cardboard so there was no repatision of the indents in the foam that mared my GWS-38. Each foam component was inividually placed in its own plastic bag. As Bthree said the nacellel ar huge.
After I finish this post I am going to set up one of the EDF64s with a GWBLM005A 3900kV Motor on my test stand to take some readings.
Ken
kensp is offline Find More Posts by kensp
Old Nov 21, 2006, 12:05 AM
kensp is offline
kensp's Avatar
Darwin Australia
Joined May 2002
I have Test run the EDF-64 with the GWBLM005A 3900kV Motor and got the folowing results using the GWS wiring harness supplied with the Me-262. The battery used was a 3 cell 1800 mAh pack.
One EDF-64 with a GWBLM005A 3900kV Motor
10.25 Volts
10.8 Amps
111 Watts
27510 RPM
Thrust 322 grams (11.5 oz)
These figures roughly agree with the GWS Web Site.
This means 23 oz thrust for a 25 oz aeroplane. 27510 RPM gives an eflux velosity of about 100 MPH so the aeroplane should have good turn of speed.
P.S. Yes! The fan is Black and the shroud is too.
Ken
Old Nov 21, 2006, 12:26 AM
GWS4CEO is offline
Find More Posts by GWS4CEO
Houng-wen Lin
GWS4CEO's Avatar
Shijr, Taiwan. DungGwan, China. City of Industry, California.
Joined Sep 2001
Congrats to you!
Wish you can fly her ASAP!
GWS4CEO is offline Find More Posts by GWS4CEO
Old Nov 21, 2006, 02:27 AM
kensp is offline
kensp's Avatar
Darwin Australia
Joined May 2002
I have completed weighing the foam components in the Kit and they came to 296 Grams. After adding together the weights of all the pieces that will go into the aeroplane I get an estimated flying weight of 717 grams, equal to 25.6 oz, without an undercarriage fitted.
Ken
Old Nov 21, 2006, 03:10 AM
RAY GWS is offline
Find More Posts by RAY GWS
Joined Jul 2004
The photo from Ken with the ducted fan and BL Inrunner is different from mass product.
I was told -- speical service for early birds was done.
Mass production -- without the ext. wire soldered to the inrunner.
Ray
RAY GWS is offline Find More Posts by RAY GWS
Old Nov 21, 2006, 04:01 AM
RAY GWS is offline
Joined Jul 2004
info to help you install GWS-262
Early Birds,
I am still trying to get the manual for you. Still do not have the info.
But the nose cowling is different from requalar GWS kits.
Please see the photo.
1. You open the nose cowling to put battery.
2. To open it, you rotate the nose.
3. There is a spring at the bottom to lock the nose.
I do not have the kits with me to check or see it. Please correct me if I am wrong. I think with the only info here will get your a rough picture of how it works.
will update you.... Welcome to add comment if you have the kit(S)
Old Nov 21, 2006, 06:01 AM
kensp is offline
kensp's Avatar
Darwin Australia
Joined May 2002
Some more photos.
Firstly a comparison of the GWS Me 262 and a GWS Spitfire.
Secondly two photos giving the measurments of the battery comparment.
Tomorrow I will build the wing and nacelles including the motor mounting.
Ken
Old Nov 21, 2006, 02:20 PM
crxmanpat is online now
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
I opted not to EB the 262, but will pick one up as soon as it hits my LHS next month. Looking forward to reading your progress Ken.
Pat
crxmanpat is online now Find More Posts by crxmanpat
Old Nov 21, 2006, 05:24 PM
shschon is offline
Find More Posts by shschon
shschon's Avatar
United States, CA, SF
Joined Aug 2004
10.25 Volts
10.8 Amps
111 Watts
27510 RPM
Ken
Does the kit include the fan you are using? Is it new version 2 fan?
shschon is offline Find More Posts by shschon
Old Nov 21, 2006, 06:10 PM
kensp is offline
kensp's Avatar
Darwin Australia
Joined May 2002
I have joined the wing using 30 minute epoxy. The use of 30 minute epoxy allows some set up time to get the two halves in alignment.
I placed two 1 inch thick balsa blocks under the nacelle mounting points and a piece of 1/4 inch balsa under the center of the wing. the two surfaces of the wing join were then painted with 30 minute epoxy. The bottom surface of the wing join was taped togeter tightly and this stops epoxy from running out the bottom of the join.
Next the wing was carefully aligned by moving the two one inch blocks to get the right dihedral. Then I used my robart Incidence meter to ensure that both wing pannels had the same angle of incidence. When I did this by eye there could be a variation of around 1/4 of a degree in difference.
I am now waiting for the epoxy to harden properly. About 2 hous should do it.
Ken
Old Nov 21, 2006, 07:31 PM
kensp is offline
kensp's Avatar
Darwin Australia
Joined May 2002
My kit came with two EDF-64s assembled and with the leads shown already soldered on. They are the Version II black fans. The EDF tested in post No 2 was the suplied EDF-64/GWBLM005A assembly.
Ken
Old Nov 21, 2006, 08:10 PM
shschon is offline
shschon's Avatar
Joined Aug 2004
Ken
So you got the brushless fans that came with the kit and they are already assembled? Are the fans balanced? Any rubbing?
Getting an assembled fan that is balanced and not rubbing is a very good deal.
Old Nov 21, 2006, 08:28 PM
kensp is offline
kensp's Avatar
Darwin Australia
Joined May 2002
I ran at 27,500 rpm with no problems.
Ken
Old Nov 21, 2006, 08:41 PM
kensp is offline
kensp's Avatar
Darwin Australia
Joined May 2002
Here are some photos of the trial Motor and ESC instalations.
Ken
Old Nov 21, 2006, 08:42 PM
Allelectric is offline
Find More Posts by Allelectric
Allelectric's Avatar
Sedona, Arizona
Joined Nov 2006
[QUOTE=kensp]My kit came with two EDF-64s assembled and with the leads shown already soldered on. They are the Version II black fans. The EDF tested in post No 2 was the suplied EDF-64/GWBLM005A assembly.
I recieved an email today from Joyce that my GWS ME-262 has been dispatched. In preparation, I already purchased the fans and the M005A motors, because the version offered in the early bird email was NPS. Are you saying it comes with fans and motors anyway?
Thanks, John
Allelectric is offline Find More Posts by Allelectric
Discussion GWS ME 262 Build Thread Bigplumbs Foamy EDFs 20 Jan 03, 2014 06:14 AM
Discussion GWS-262 Build Thread rdeis Foamy EDFs 829 Nov 19, 2011 03:24 PM
GWS Spitfire Build thread (with glassing tutorial) David Winter GWS (Grand Wing Servo) 156 Sep 14, 2009 05:42 AM
Discussion Gws Me 262 Modification Thread corsair nut Foamy EDFs 71 Aug 30, 2007 03:33 PM
My Girlfriend's GWS Beaver Build Thread (With Pics) nitroaddict Parkflyers 84 Aug 11, 2007 10:51 AM
