Old Nov 26, 2006, 11:10 AM
AZcrashpro is offline
Find More Posts by AZcrashpro
AZcrashpro's Avatar
Mesa Falcon Fld, Arizona, United States
Joined May 2004
Originally Posted by FoamCrusher
Ken:
If you want to get in the 100+ mph club, you are going to need a higher Kv motor than the 2500.
FC
They have been running this motor at 4s and getting over 100 mph with these wings very easily.
AZcrashpro is offline Find More Posts by AZcrashpro
Old Nov 26, 2006, 01:17 PM
FoamCrusher is online now
Find More Posts by FoamCrusher
If it floats....sail it!
FoamCrusher's Avatar
Elk Grove, CA
Joined Sep 2002
I have never tried the Medusa on 4S1P. The Mega's are well known for their ability to deal with more voltage, but I was unaware that was also true for the Medusa.
I did use 4S with a Mega 16/15/4 once and it was great, but the plane starts to get heavy with the weight of the extra cell (as well as the $$$). Speed costs money....more speed costs cubic money.
FC
FoamCrusher is online now Find More Posts by FoamCrusher
Old Dec 12, 2006, 11:27 AM
EdBall Flies! is offline
Find More Posts by EdBall Flies!
EdBall Flies!'s Avatar
Joined Apr 2004
OK update on status.
I have started building the TL and have finished glassing it (Pacer Resin+Fibercloth 3/4 oz) method. Need some help with weight check.
So far:
Airframe with servos, receiver glassed - 500g - 17.63 oz
Poly RC 4350 4s - 455g - 16oz
All other gears (Motor, prop, mount, ESC, Opto, BEC, 150 mah 2s - 210g - 7.40 oz
Total - 1165gram - 41.1 oz
I supposed with the winglets, elevons, covering and some misc like hinges and whatnot would add a bit more. Airframe felt very sturdy now after the glassing, just hope it is strong enough for the speed I am looking for.
Oh another thing, I bought 150mah lipo for the BEC by mistake, is this good enough to last 2 flight of batts (4s1p)?
EdBall Flies! is offline Find More Posts by EdBall Flies!
Old Dec 12, 2006, 10:26 PM
pumpman is offline
Find More Posts by pumpman
glendora,CA
Joined Dec 2005
edball just wanted to know how far your batterys are set back from the nose? those batterys really do the job. that thing will be fast. insane vertical. set mine too forward cgs at 8" flies exellent.on your 150 mah lipo after 2flights i think it only takes 90 mah or so. hope you have a big area to fly.love those big screaming passes.
pumpman is offline Find More Posts by pumpman
Old Dec 14, 2006, 02:30 AM
Joined Apr 2004
Hi Pumpman,
I believed I have it at 3". Will double check later. I will get my plane covered soon and update on the cg balance. Hopefully I won't need any weights at the back.
Anyhow, may I know what kind of receiver are you guys flying your ritewing with? PPM or PCM?
Old Dec 14, 2006, 09:05 PM
Joined Apr 2004
Anyone?
Old Dec 14, 2006, 09:17 PM
Atom1025 is offline
Find More Posts by Atom1025
Fly me to the moon...
Atom1025's Avatar
Sacramento
Joined Jun 2005
PPM, Electron 6 is a popular reciever.
Atom1025 is offline Find More Posts by Atom1025
Old Dec 14, 2006, 11:53 PM
pumpman is offline
glendora,CA
Joined Dec 2005
eddball, i also use an electon6 hitec.i made aseperate compartment for the reciever away from the speed controller.
Old Dec 16, 2006, 02:44 PM
Joined Apr 2004
Hey guys, I am using a PCM Futaba receiver and the additional weight balance the TL nicely without any weights needed. My experience is that PPM is pretty glitchy and I never met any issues with PCM, is Opto Isolator still needed?
Old Dec 16, 2006, 05:02 PM
Joined Apr 2004
Alright, figure most TL owners must be busy for the Christmas season, anyhow. I opt for the safer route and put in the BEC and opto isolator incase.
Final weight: 47.62 oz (is that build somewhat slightly heavier?)
CG balanced with no weights, I merely shifted the motor in the mount to get it right.
Old Dec 16, 2006, 06:30 PM
punkrockd is offline
Find More Posts by punkrockd
Purples a fruit
punkrockd's Avatar
United States, CA, Walnut Creek
Joined Aug 2006
shes a beaut
punkrockd is offline Find More Posts by punkrockd
Old Dec 16, 2006, 10:25 PM
klique is offline
Find More Posts by klique
Mum is the word!
Joined Jun 2003
Looks awesome
Yo ed hang the oem winglets below the wing so they are 50 50 top and bottom. Those are too small .
They will also act as skids to keep the motor off the deck in a landing.
It will also help on landing to keep the wing from getting a lofty flip landing where a bad landing gets air back under it then it loops out and flips over. make the cg at 8' inches.
Edd verry good build and the weight will be fine.
Ck
klique is offline Find More Posts by klique
Old Dec 16, 2006, 10:42 PM
Joined Apr 2004
Alright, I will take the original piece and cut out some yellow pieces. Thanks for the tip, luckily it rained today, wasn't able to maiden kekeke.
Spent sometime adding a bit more decorative, now looks much better.
Old Dec 16, 2006, 10:53 PM
klique is offline
Mum is the word!
Joined Jun 2003
Edd it looks awesome.
If you use the oem ones just spray paint the outer sides to match the wing that is what dynomike just did and it looks cool.
ck
Old Dec 17, 2006, 12:32 AM
Joined Apr 2004
Ck
Hey CK, about the CG, what is the range I can play with? I am aiming for axial roll and little to no input for inverted flying. I have it currently at 8 1/2
Discussion Newbie Ritewing TL-50 build Abrams Flying Wings 56 Nov 11, 2007 08:15 AM
Rave Ritewing Tl 50 Pilot Tim Nunn Flying Wings 11 Jul 08, 2007 09:32 PM
Discussion Ritewing TL 60 Ordered! (Question Inside) joekoz Flying Wings 11 Jun 10, 2007 04:45 PM
Yippee! Ritewing "TL 50" Build pics, Maiden and 3 Videos post #57 Newest TaSaJaRa Flying Wings 56 Mar 01, 2007 11:42 AM
Tiger Moth "powerplant" question... rlinscheid Parkflyers 11 Sep 07, 2001 10:30 AM
