Old Jul 06, 2007, 10:53 PM
VictorN is offline
Find More Posts by VictorN
Hawaiian Shores, Big Island, HI
Joined Jul 2006
Big E RC has the "A123 Blinky" on their web site.
VictorN is offline Find More Posts by VictorN
Old Jul 06, 2007, 11:11 PM
JustPlaneChris is offline
Find More Posts by JustPlaneChris
JustPlaneChris's Avatar
Austin, TX
Joined Sep 2005
Thanks!
I wonder why Astro doesn't have it on their own site?
-Chris
JustPlaneChris is offline Find More Posts by JustPlaneChris
Old Jul 07, 2007, 04:11 AM
dutch_anykey is offline
Find More Posts by dutch_anykey
Joined Feb 2006
Oke,
In a rush and panic i just mailed my first post into this forum last night ;-)
Been a member for quite a while but never posted anything.
Anyway i figured out the problem myself.
The lba10 balancer shut down because for some unknown reason one cell had a way too high cell voltage (new A123 pack). After discharging the pack a little everything was working fine with the balancers.
Maurice
dutch_anykey is offline Find More Posts by dutch_anykey
Old Jul 07, 2007, 05:27 AM
whizzard is offline
Find More Posts by whizzard
whizzard's Avatar
Barboursville, West Virginia, WV-OH-KY Tri State Area
Joined Aug 2003
Save a little width with packs offset
So far I have built a 5s2p, 4s2p and a 3s2p battery pack from DeWalt A123 cells.
To save a little room in my Telemaster Electro's battery tray, I off-set the parallel packs of 4 cells so they are 1/2 cell from each other and fit into the "groves" of the other parallel pack.
This allowed easy insertion into the battery tray where putting the cells in a full "rectangle" was spreading the sides of the tray.
I do tape wrap the cells just like the normal "rectangle" packs and it takes just a little more tape.
I could also do this with series packs by cutting the cells apart and using a wire jumper between the end cells insterd of using the existing metal tabs.
Bill
whizzard is offline Find More Posts by whizzard
Old Jul 07, 2007, 05:37 AM
Bayward is offline
Find More Posts by Bayward
Pasco County Florida
Joined Dec 2006
Bill, how about showing us a picture of what you did ? I would like to have a visual.
Bob
Bayward is offline Find More Posts by Bayward
Old Jul 30, 2007, 03:16 PM
waltj2k is offline
Find More Posts by waltj2k
3DHobbyShop disciple
waltj2k's Avatar
Dallas Intl, Texas, United States
Joined Aug 2004
1st a huge thanks on the 2 "How to" threads. Great info in both.
I'd like to build 4S packs in a 2x2 stick configuration. Has anyone done this with the A123 cells. I've looked at the SLKElectronics website and that is great info on build NIMH packs.
Is this process the same with the A123's?
waltj2k is offline Find More Posts by waltj2k
Old Jul 30, 2007, 04:47 PM
chucker four is offline
Find More Posts by chucker four
Joined Dec 2004
madmax 123cells
first cells cleaned off steel pcs. soldered silver buss bars + to - made up two 4 cell packs one 2 cell packs. due to illness only used once all cells show 3.2 volts same as first charge. de souldered all cells now use power tubs.cells are fitted into plastic shower rod covers then with shrink covering provided. this feels more rigid then just with shrink covering provided votage still 3.2
chucker
chucker four is offline Find More Posts by chucker four
Old Jul 30, 2007, 06:11 PM
arx_n_sparx is offline
Find More Posts by arx_n_sparx
Dismembered Member...
arx_n_sparx's Avatar
Niagara Falls/Toronto area
Joined Dec 2003
chucker
Great idea! Thanx, chucker
Brad
arx_n_sparx is offline Find More Posts by arx_n_sparx
Old Jul 30, 2007, 06:47 PM
retiredVTT is offline
Find More Posts by retiredVTT
Canada's East Coast, "An Ocean Playground"
Joined Apr 2002
Bob
These are my 4S packs with balance connectors..
Bill
retiredVTT is offline Find More Posts by retiredVTT
Old Jul 30, 2007, 10:02 PM
waltj2k is offline
waltj2k's Avatar
Joined Aug 2004
Bill
Yes yes yes,
Would really love a little walk through on how you built those packs. This is exactly what I would like.
Old Jul 30, 2007, 11:54 PM
Joined Apr 2002
Well, the way the 10 cells are assembled with tabs you can litterly get 2 4S packs by carefully separating and bending the cells into the two stick configuration. It's quite easy to see once you have the 10 cell pack in front of you. I believe I did have to add a bottom "bus" across the two cells. Just keep in mind that your final configuration is to have 4 cells in a series connection. Of course you will have two cells left over so that after doing a second pack, you will have four individual cells left over and they get soldered together negative to positive as well using either the tabs on them or a #12 wire. No different then those little 1/2 A Nimh cells that we used to use back in the dark ages, about three years ago...just bigger cells now.
Keep a meter close by to verify which end is pos and which is neg..!
Bill
Old Aug 04, 2007, 05:19 PM
feathermerchant is offline
Find More Posts by feathermerchant
Use the 4S Luke
feathermerchant's Avatar
USA, TX, Euless
Joined Aug 2003
Man this is a great thread. Some of you may have hear of Modelelectronicscorp.com but if not they pioneered the solderless power tube technology. Basically you put the cells into tubes and clamp them down. No soldering required and you can disassemble them for replacement of individual cells. They also sell ready made packs which are on sale right now.
http://www.modelelectronicscorp.com/...uct.php?pid=12
feathermerchant is offline Find More Posts by feathermerchant
Old Aug 04, 2007, 07:31 PM
gwh is offline
gwh
Find More Posts by gwh
gwh
Fort Worth, Texas
Joined Dec 1996
Thanks for the tutorial theads on how to disassemble and build the cells from a Dewalt pack. These have really been useful to me.
Has anyone used these A123 battery bars from Hyperion?
http://aircraft-world.com/shopexd.asp?id=5085
Feather, What are you doing looking around in here?
gwh is offline Find More Posts by gwh
Old Aug 04, 2007, 08:30 PM
Carlyle Harper is offline
Find More Posts by Carlyle Harper
Carlyle Harper's Avatar
Joined Feb 2007
Man, I wished I'd found those before I got the battery bones. They look like they will fit a perfect semicircle on the ends of the A123 cells.
I've made 12s packs using the battery bones soldered to the tabs. I wish now that I had removed the tabs and soldered directly to the cell because in another pack I had the steel tab come off especially on the positive end.
I've made 5s packs by bending two pairs of cells end to end with a cell on the end connected with wet noodle for my electristar. I ran down a deep cycle battery the other day doing consecutive flights and charges.
I believe the trick to soldering directly to the cell is to first remove the oxide on the surface using either sandpaper or lightly with the dremel tool and immediately coat the surface with some flux paste so it doesn't have time to re-oxide and then tin the cell. The aluminum really sucks away the heat so you will need a very hot iron. Let the cell cool before trying to solder your wire to it.
Carlyle Harper is offline Find More Posts by Carlyle Harper
Old Aug 04, 2007, 11:50 PM
waltj2k is offline
waltj2k's Avatar
Joined Aug 2004
Tonight I was able to put my packs together. After reading this thread and discussion with GWH and Feathermerchant. I decided to try to build a 4S 2x2 stick. RetiredVTT displayed his packs and that helped me understand what to do.
Hopefully these additional pics will further expain for those who would like to build stick packs.
Discussion How to build a battery pack? caleberx Batteries and Chargers 0 May 28, 2007 08:12 PM
Sold FS DC9360 battery pack new A123 cells 10sp1 andres.c Aircraft - Electric - Batteries & Chargers (FS/W) 2 Apr 18, 2007 05:58 PM
Learn how to build battery packs squelchF18 Beginner Training Area (Aircraft-Electric) 21 Aug 13, 2004 02:58 PM
Can I build a battery pack from these cells? dmelton Batteries and Chargers 8 Aug 14, 2003 09:56 AM
separate battery pack for 10 cells gliderdude Electric Heli Talk 0 Feb 02, 2002 11:57 PM
