Old Jan 04, 2007, 06:54 PM
Madmax1965 is offline
Find More Posts by Madmax1965
Watt me worry?
Madmax1965's Avatar
Florida
Joined Mar 2006
Got it!
Thanks bjpaul.........the taps you used which fit the Hyperion LBA10 6s would be which item #? Are they TP taps or Hyperion? I can do this once I know the taps to use....After this radio conversion below I think I can handle it.
My new(old)radio.
Madmax1965 is offline Find More Posts by Madmax1965
Old Jan 04, 2007, 07:06 PM
bradpaul is offline
Find More Posts by bradpaul
USA, FL, Apopka
Joined Dec 2000
I used Hyperion taps... less then $2.00 each.
http://www.allerc.com/product_info.p...oducts_id=1884
Brad
bradpaul is offline Find More Posts by bradpaul
Reply With Quote  (Disabled)
Old Jan 04, 2007, 07:13 PM
Watt me worry?
Madmax1965's Avatar
Florida
Joined Mar 2006
Thank you.
Old Jan 04, 2007, 07:31 PM
Watt me worry?
Madmax1965's Avatar
Florida
Joined Mar 2006
bjpaul I take it you count cells starting from the left top and go right and then down?
Old Jan 04, 2007, 08:30 PM
bradpaul is offline
USA, FL, Apopka
Joined Dec 2000
Count from the main positive terminal, up or down is relative. Remember the polarity on A123 cells is backwards from regular Nicad and Nimah.
Brad
Old Jan 04, 2007, 09:09 PM
Doubletap is offline
Find More Posts by Doubletap
Si Vis Pacem Para Bellum!
Doubletap's Avatar
United States, CA, El Segundo
Joined Jul 2005
Need 6S Hyperion taps
Does anyone know where I can buy 6S Hyperion male pack side taps for use with the LBA10? Nobody lists them yet as far as I can tell. I have some A123 6S I'd like to wire up for balancing.
Doubletap
Doubletap is offline Find More Posts by Doubletap
Old Jan 05, 2007, 07:41 AM
RC Accessory is offline
Find More Posts by RC Accessory
United States, FL, Tampa
Joined Jan 2004
Doubletap
I have one. NIB. This will plug right into the LBA10. PM me.
RC Accessory is offline Find More Posts by RC Accessory
Site Sponsor
Old Jan 05, 2007, 07:53 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Perhaps I mis interputed this but to me it sounds like he is looking for a 7 lead (for 6S) Hyperion battery tap / pigtail ,as in one which attaches to the LiPoly cells / pack.
I looked around a bit and for whatever reason the 5 lead PQ,Hyperion,E tec pigtails are very common but not the 6 lead ones.
One would think that Hyperion dealers would stock these as they are need to make max. use of the LBA 6 conviently. Kinda reminds me of the early TP Days when you could purchase a TP Balancer but very few TP ProLites with matching connections and no source for pigtails for other brands.
LBA10 to 6S but no 6S battery pigtails here
http://www.allerc.com/product_info.p...oducts_id=2567
just like other places I have checked.
I purchase my PQ /Hyp. connectors(pigtails) here
http://www.cheapbatterypacks.com/mai...ctors&scat=HYP
however they only carry the 5 leads and they are showing only 1 male (battery sie) in stock.
Charles
Old Jan 05, 2007, 08:20 AM
Joined Jan 2004
I have not seen a 6S battery side pigtail from Hyperion. Either Allerc does not carry it or it does not exist.
The 6S wiring harness from the links above are too short to be used as a balance connector. I have these in stock and looked at them.
The pigatil I have is about 7" or so in length. Looks like this, but with the correct JST connector for the LBA10.
Site Sponsor
Old Jan 05, 2007, 09:22 AM
Doubletap's Avatar
Joined Jul 2005
Yes, I am building some 6S A123 packs and would need the 7-lead Hyperion taps that interface with the LBA10's 6S Hyperion harness. I typically buy my Hyperion taps from allerc.com but for some reason they do not carry these. Thanks to RC Accessory, he found a source for these overseas:
http://www.aircraft-world.com/shopexd.asp?id=3606
I'll probably drop allerc.com an email inquiring if they plan to carry these as I'd rather purchase them stateside. Otherwise, I'll order from Aircraft World.
Thanks to everyone for their assistance!
Doubletap
Old Jan 05, 2007, 11:07 AM
Doubletap's Avatar
Joined Jul 2005
Good news...
I just got an email reply from Bob at www.allerc.com concerning the availability of Hyperion LBA 10 6S male pack-side balance taps. They DO have them in stock but have not added them to the website yet. Part number is HP-LB10MCLBA and is actually the same connector that plugs into the LBA10 itself. If you're in a hurry, it can be ordered over the phone or via email.
Doubletap
Old Jun 30, 2007, 08:41 AM
Gustave Flaubert is offline
Find More Posts by Gustave Flaubert
South of France
Joined Nov 2004
Congratulations : very very good thread, very informative.
Thanks for the work being done
Gustave
Gustave Flaubert is offline Find More Posts by Gustave Flaubert
Old Jun 30, 2007, 09:42 AM
Cobra is offline
Find More Posts by Cobra
MaxiR, Sniper
Lansdale, PA, USA
Joined Dec 2004
Yes, I agree, great thread!
I just built an 8S A123 with two of these Bantam taps. I needed to extend four of the wires to get to the far side of the A123s. They worked well. I ran the first charge yesterday and everything looks good.
Cobra is offline Find More Posts by Cobra
Old Jul 06, 2007, 07:18 PM
dutch_anykey is offline
Find More Posts by dutch_anykey
Joined Feb 2006
Hello Guys,
I just bought a eos1210i-A and 2 lba10 balancers. I can read in the manual that i can blanace load 2 packs of the same cell count...but it doesnt say how to charge 7s with the lba's in network mode. Is that even possible?
I want to balance my A123 7S pack. It has one 5s tap and one 2s tap. But there is noway to get this thing starting to balance. What about the battery leads? i only have one deans on that pack. Should i tap a pos. and neg. lead to connect to the balancer for each balancer?
Thanks in advance,
Maurice
dutch_anykey is offline Find More Posts by dutch_anykey
Old Jul 06, 2007, 09:42 PM
JustPlaneChris is offline
Find More Posts by JustPlaneChris
JustPlaneChris's Avatar
Austin, TX
Joined Sep 2005
I also have an A123 balance question:
I've heard rumors of an A123-specific "blinky" from Astro Flight, but cannot find it on their site or any vendor site. Is it true? Or will the regular "blinky" (or the CSRC Ultimate Balancer) work on A123 cells?
-Chris
JustPlaneChris is offline Find More Posts by JustPlaneChris
Discussion How to build a battery pack? caleberx Batteries and Chargers 0 May 28, 2007 08:12 PM
Sold FS DC9360 battery pack new A123 cells 10sp1 andres.c Aircraft - Electric - Batteries & Chargers (FS/W) 2 Apr 18, 2007 05:58 PM
Learn how to build battery packs squelchF18 Beginner Training Area (Aircraft-Electric) 21 Aug 13, 2004 02:58 PM
Can I build a battery pack from these cells? dmelton Batteries and Chargers 8 Aug 14, 2003 09:56 AM
separate battery pack for 10 cells gliderdude Electric Heli Talk 0 Feb 02, 2002 11:57 PM
