Old Nov 19, 2006, 02:31 AM
kahloq is offline
Find More Posts by kahloq
kahloq's Avatar
Fort Collins, Colorado, USA
Joined Dec 2005
Thunderbird 18's in GWS P-38
Here is my recently finished GWS38 using two Thunderbird 18amp esc's. The engines are setup for differential thrust mixed to the rudder input. I do have a servo in place for the nose gear, but it is not needed. The engines are also set up counter-rotating and so have pusher 9x7x3 and tractor 9x7x3.
Plane also has two elevator servos, but they are located in separate engine booms which required the use of a servo reversing y-harness.
ESCs: Castle Creations Thunderbird 18(x2)
Motors: Park 370 outrunners(x2)
9x7x3 Master tractor and pusher
Rx: Ar6000
Battery : TP 3s 2100 pro-lite
kahloq is offline Find More Posts by kahloq
Old Apr 24, 2007, 11:24 AM
jrhyne is offline
Find More Posts by jrhyne
baltimore
Joined Apr 2007
P-38 build and flying...
Rx: Ar6000
So, how did this fly? Anyone else have a similar set-up?
jrhyne is offline Find More Posts by jrhyne
Old Apr 26, 2007, 09:17 PM
kahloq is offline
kahloq's Avatar
Joined Dec 2005
It flew well...very scale like. Easy to land and take off. Great for low level passes
For Sale GWS P-38 Silver NPS w/ Motors and ESC's DESIGN ENGNR Aircraft - Electric - Airplanes (FS/W) 3 Aug 22, 2007 06:18 AM
Discussion Proper wiring of two GSESC25A in the GWS P-38 Fly4FunDad Power Systems 1 Feb 04, 2007 12:07 PM
Question 4 Brushless outrunners and 4 Thunderbird 18's in parallel ??? _Pattern_Man Castle Creations 1 Apr 04, 2006 02:59 PM
HS-50s in GWS P-51? E-Pylet Parkflyers 2 Jan 11, 2003 03:22 PM
Li Ion in GWS P-51??? spessx Parkflyers 3 Dec 28, 2002 10:37 PM
