Old Nov 18, 2006, 10:15 PM
Wing-span is offline
Find More Posts by Wing-span
Chuck it and see!
Wing-span's Avatar
UK, Cambridgeshire, Huntingdonshire
Joined Sep 2006
Help!
Rolling Circle?
Help guys,
I have been trying for a while now on the simulator but I can't crack it! How do you do a rolling circle. I think this manouver looks the business and is probably the ticket to other advanced moves. So what is the deal? Can anybody give me a few pointers please?
Wing-span is offline Find More Posts by Wing-span
Old Nov 19, 2006, 12:59 AM
cwojcik is offline
Find More Posts by cwojcik
Extremely Twisted
cwojcik's Avatar
United States, NH, Epping
Joined Oct 2005
Practice slow rolls, giving rudder, down elevator, and then rudder again. Now try adding down elevator and rudder at the same time, then when inverted, give rudder a little early, then a little up elevator during the second knife-edge. Practice this until you can do it consistently, turning ninety degrees, a one-roll ninety degree turn to the outside. After you've got this down, try doing two of them for a two-roll one eighty, then three. The hardest is the last one, as the orientation is weird, and you have to compensate for any screw-ups you made earlier.
So basically, practice slow rolls, and then practice changing the timing of the inputs. After you can do consistent four roll rollers to the outside, try doing it with two. Then try giving the inputs earlier rather than later for a roller to the inside.
These are just guidelines, there's no "trick." Just practice, and eventually it should click for you.
cwojcik is offline Find More Posts by cwojcik
Old Nov 19, 2006, 04:49 AM
Chuck it and see!
Wing-span's Avatar
Joined Sep 2006
Humm? Right, I will give it a go. Thanks cwojcik.
I guess I need more practice.
Old Nov 19, 2006, 10:33 AM
bigdarylg is offline
Find More Posts by bigdarylg
USA, OH, Troy
Joined Jan 2004
one other hint that has helped me is to concentrate on watching the landing gear as you roll instead of the whole plane.
bigdarylg is offline Find More Posts by bigdarylg
Old Nov 19, 2006, 12:57 PM
Chuck it and see!
Wing-span's Avatar
Joined Sep 2006
Landing gear? How does this help?
Old Nov 19, 2006, 02:37 PM
USA, OH, Troy
Joined Jan 2004
makes you focus on when to make elevator inputs ,it's like picking a spot to concentrate on. gives you more focus
Old Nov 19, 2006, 04:01 PM
weedy-burton is offline
Find More Posts by weedy-burton
Joined Dec 2004
Hey,
you dont need to use both elev and rudder to do a rolling circle you can start out just using one or the other, looks a bit messy but once you have that down pat you can start using both surfaces to smooth it out. If you chose to use just elevator for instance all you need to do is roll the plane and input elevator just before the plane gets back to horizontal as you roll,this way the plane will still be a little banked( like in a turn) when you input the elevator and will come around in that direction.like I said it'll look a little messy at first but once you get co-ordinated and start using rudder aswell it'll be smooth as.
Cheers
Weedy
weedy-burton is offline Find More Posts by weedy-burton
Old Nov 20, 2006, 12:02 AM
pallen_2006 is offline
Find More Posts by pallen_2006
Newark ,NY, USA
Joined Jun 2006
I find that watching the tail instead of the gear makes it easier to give the correct rudder and elevator inputs. I also learned rolling harriers this way.
It seems that finding a spot on the plane to "watch" may help for you as it has for others. Good luck
pallen_2006 is offline Find More Posts by pallen_2006
Old Nov 20, 2006, 03:46 AM
ALEX HEWSON is offline
Find More Posts by ALEX HEWSON
Remember... Fly for fun!
ALEX HEWSON's Avatar
Christchurch, New Zealand
Joined Jul 2005
Originally Posted by weedy-burton
Hey,
Cheers
Weedy
Thats how I first started out. I just used elevator. I practised doing consecutive rolls first then moved onto a full circle. Next it was full rolling circuits.
I then tried consecutively rolling with just rudder, and when I had that sorted I put them both together. Now I'm having a ball trying to master the rolling harrier (on mode 2 that is, mode 1 is alot easier )
It takes time so be patient. I don't have a sim and its taken me a good year.
ALEX HEWSON is offline Find More Posts by ALEX HEWSON
Old Nov 20, 2006, 08:45 AM
mexico is offline
Find More Posts by mexico
mexico's Avatar
NJ
Joined Aug 2003
It also seems much easier for some reason to do outside rolling circles. That is rolling right turning left or vice versa. I still do them with ailerons and rudder only. That last 1/4 of the circle - when it is flying straight at you - is the test of whether you trust your skills or not.
mexico is offline Find More Posts by mexico
Old Nov 20, 2006, 11:14 PM
mdavies31 is offline
Find More Posts by mdavies31
Bakersfield Meadow Fld, California, United States
Joined Aug 2004
I found this somewhere, maybe it will help.
mdavies31 is offline Find More Posts by mdavies31
Old Nov 21, 2006, 07:58 AM
Chuck it and see!
Wing-span's Avatar
Joined Sep 2006
Thats good mdavies31.
Kind of what I was looking for. I like the stick movements diagrams.
Are any other moves shown in this way?
Old Nov 21, 2006, 08:22 AM
mexico is offline
mexico's Avatar
NJ
Joined Aug 2003
Scott Stoops wrote an RC Pilot Guide that gives diagrams for all maneuvers. Excellent book. www.rcpilotguide.com
Old Nov 21, 2006, 10:40 AM
Chuck it and see!
Wing-span's Avatar
Joined Sep 2006
That fantastic. Exactly what is needed. God bless Scott Stoops.
Old Sep 10, 2015, 02:45 PM
Chuck it and see!
Wing-span's Avatar
Joined Sep 2006
Still can't do'em ��
Discussion Aileron dual rate for rolling circle? Bruce Estes 3D Flying 2 Mar 04, 2007 01:07 AM
Cool Rolling Circle Wing Video Charger Flying Wings 26 Aug 05, 2006 12:47 AM
Trying to learn rolling circle Al P Competition Aerobatics 4 Feb 16, 2005 10:41 PM
Rolling Circle ldvm 3D Flying 7 Feb 10, 2005 10:05 AM
Cool How do you perform the rolling circle>>>??? kindjordan 3D Flying 9 Nov 07, 2004 12:32 AM
