Old Sep 04, 2002, 10:20 AM
RD Blakeslee is offline
Find More Posts by RD Blakeslee
Joined Jan 2002
Lithium Polymer Batteries in Foamies
The following posts are from the "Modelling Science" forum, in the "Kokam Lithium Polymer Batteries!" thread.
These batteries are very thin, but wide and long. They offer great power density, but the higher-capacity cells present problems fitting them into airplanes. For example, the Kokam 3270 mah cell is 3.7" x 2.5" x .205" (2.2 ounces).
How we gonna fit'emin (foamies - flying wings, in particular)?
Anybody tried to bend these cell a little, to follow the curve of an airfoil?
Jube T Cornpone - Member
“… you could about cover the wing with paralleled 45 mah cells, they are so thin!” (electroman)
“ …We're going to have to squeeze these cells in the wings of our planes so we will have room for them.” E-sailpilot 86)
That'll be the only way to go with most foamy flying wings - the FMA Razor (now unfortunately discontinured) is the only one I know of with an equipment bay large enough to accomodate LiPolys 1000 mah & up, in their contemporary thin profile.
I plan to use the router attachment on my Dremel to flush mount a pair of Kokam 3270s, one in each wing, on a Zagi
opualuan - www.thebuckshop.com: 1842
make sure to put a ply panel or something to cover them up... don't want to scrape them landing on a rock...
Going to take the last 2 posts to "Foamies', and continue there as new thread: "LiPolys in Foamies".
RD Blakeslee is offline Find More Posts by RD Blakeslee
Old Sep 04, 2002, 11:34 AM
ls77 is offline
Find More Posts by ls77
Former bpp dude
Joined Oct 2001
The 3270's will fit some planes (I stuffed them into my Zero ok) but like you pointed out, they will not fit in to most fuses. I think the real way to go is running a parallel via a Y connector setup. The 1575 cells have a much smaller footprint - 4 cells are a bit smaller than a 8 cell 600ae pack so they will fit most planes & wings no problem. Plus you can always separate the two packs to run a single pack in a even smaller plane that does not need 3000+mah. I am testing the parallel setup now & so far the results look great. I am building an X-bow foamy that will use a speed 400 & 480 motor and the parallel 1575 cell setup for the in-flight tests. Should net 30+ minutes with the stock speed 400 and close to 20 for the 480 setup.
ls77 is offline Find More Posts by ls77
Old Sep 04, 2002, 12:11 PM
kushal_22 is offline
Find More Posts by kushal_22
kushal_22's Avatar
Kamloops
Joined Dec 2001
What about some of these Mininwings? Like say the "Swift" Or acers Minispeed wing? WHich one is it that is already using the Li-on pack? WHat size is it?
I am looking for a pack relitively the same size as a four pack of "AAA" cells(in series of course) WHich one would this be? I sure wish we had some photos of what these packs look like.
Mal
kushal_22 is offline Find More Posts by kushal_22
Old Sep 05, 2002, 08:58 AM
Joined Jan 2002
Mal - I don't know the exact answer to your question - maybe nobody does. These cells are pretty new and still being adapted in all kinds of ways by different flyers. I doubt there is a standard, best way for the small wings yet.
Try >http://www.rcgroups.com/forums/showt...threadid=56590<. There are discussions of several sizes of Kokams with dimensions, weights, and pictures there.
Also. asperkins and others have used Qualcoms, and reported on them in the "Parkflyer" forum.
Old Sep 05, 2002, 11:54 AM
kushal_22's Avatar
Kamloops
Joined Dec 2001
Thanks for the help. I am sure one of these packs if not a couple will be usefull in these wings. I also have a Tinabob that one of these Packs is going to come in usefull! These Planes are just tooo cool. If no one has seen the tinabob go to www.foamfly.com there is some video there and plans will be up there shortly.
Mal
Old Sep 05, 2002, 08:36 PM
Slow Riser is offline
Find More Posts by Slow Riser
Canadian E-Tailer
Slow Riser's Avatar
Calgary
Joined Apr 2002
Mini Wings and Li
Mal,
I use the Qualcomm 830's in the mini wings such as Acer's Mini Speed Wing and my own wing design and get over 20 minutes of full throttle. The Li's don't give as much "punch" as the 300 NiMH but its more than adequate for my uses. The Tinabob also uses the Qualcomm 830's driving a pair of the GWS 50XC.
I have tested the Qualcomms on 2 GWS 50XC and it should give about 10 minutes of flight. I'm in the process of creating a 2 motor version of my "Mini E-Wing".
I'm interested in the new Kokams but I may also try the Ultralifes. I have the latter but haven't tried them yet but from posts, it should perform better than the Qualcomms in a 2 engine config as in the Tinabob and they are also about half an ounce lighter than the Qualcomms albeit slightly less capacity.
Hank
Slow Riser is offline Find More Posts by Slow Riser
Question Lithium Polymer batteries approx. 200 mAh? glockengockel Batteries and Chargers 10 Dec 04, 2009 05:53 PM
Kokam Lithium Polymer Batteries! asperkins Batteries and Chargers 1344 Feb 08, 2003 08:53 AM
Lithium Polymer batteries in scale models? 4 Scale Scale Kit/Scratch Built 50 Jan 24, 2003 06:45 AM
lithium polymer batteries gponder Control Line 2 Dec 04, 2002 11:22 AM
Source of Lithium Ion batteries in the UK ? Tatty Parkflyers 7 Aug 31, 2002 02:47 PM
