Old Feb 02, 2008, 02:54 PM
martin_gsxr is offline
Find More Posts by martin_gsxr
Montreal
Joined Jan 2007
Originally Posted by skirtz
Go to playmodels\Raptor60-V4 and change in params.txt the lines like this:
breakPart lSkid 1.0 15.0 1.0 8.0 280.0 1.0
where numbers are:
- part type (must be 1)
- horizontal speed in m/s that will break the part
- verstical speed in m/s that will break the part
- model crash speed, that when eceeded the part will break
- force in Newtons that will break the part
- part mass
Does your computer bogs down when the model suffers hard crash or there are many objects on the scene?
Stefan
http://rcflightsim.com
Stefan, I change the four Breakpart skid... double all value exept part type and part mass... does seem to change anything
martin_gsxr is offline Find More Posts by martin_gsxr
Old Feb 02, 2008, 06:32 PM
skirtz is online now
Find More Posts by skirtz
Joined Sep 2002
Thai is strange, in 4.89 that is on the web sitre I strengthen the gear, the params I used there are:
breakPart lSkidB 1.0 10.0 1.4 9.0 260.0 1.0
breakPart lSkidF 1.0 10.0 1.3 10.0 260.0 1.0
breakPart movabledisk 20.0 0.0 0.0 0.0 0.0 1.0
breakPart rSkidB 1.0 10.0 1.2 9.0 260.0 1.0
breakPart rSkidF 1.0 10.0 1.1 10.0 260.0 1.0
breakPart taildisk 10.0 0.0 0.0 0.0 0.0 1.0
breakPart tailfin 1.0 3.0 1.0 5.0 80.0 1.0
and the gear is quite strong.
Stefan
skirtz is online now Find More Posts by skirtz
Old Feb 03, 2008, 03:11 PM
Montreal
Joined Jan 2007
Stefan
You are right, but if I move slowly forward or backward and touch gently the bottle or land in the same time, the landing gears are gone...
Old Feb 03, 2008, 06:41 PM
Joined Sep 2002
Use this values:
breakPart lSkidB 1.0 1000.0 1000 1000.0 1000.0 1.0
and the gear will never break. Another way to do that is to delete the skid entries from advanced settings.
Stefan
Old Feb 03, 2008, 10:02 PM
Montreal
Joined Jan 2007
Use this values:
Stefan
I try those ... no change.
No big deal
Old Feb 03, 2008, 10:10 PM
Joined Sep 2002
No big deal
Are you running on Vista? If so, Vista virtualizes file operation in Program Files.
So, if you a program uses
C:\Program Files\Company Name\Title\config.ini
the file oparation is automatically redirected to:
C:\Users\user name\AppData\Local\VirtualStore\Program Files\Company Name\Title\config.ini
So you will have to edit the "shadow" file for params.txt
I know this is PAINFULL so may be better to copy ClearView folder from "Program Files" to any folder under c: - like in c:\MyGames and run ClearView from there. There will be no file virtualization in that case.
Stefan
Old Feb 04, 2008, 12:31 PM
Montreal
Joined Jan 2007
Stefan
Thanks Stefan, now the skids are perfects...(Vista)
Is there a way do reduce the reset delay after a crash ?
And sometime after a crash instead of normal long-reset, the screen turn black and I have to return to playground menu and sudently the sim is ready again !!
And last small thing, sometime the tinted windscreen desapear for 1/2 second...
Keep up the good work, you have a really good and fun sim..
Old Feb 04, 2008, 05:46 PM
RACER526 is offline
Find More Posts by RACER526
New Jersey
Joined Jun 2006
Martin,
Try hitting the spacebar on your keyboard after a crash, seems to reset faster.
RACER526 is offline Find More Posts by RACER526
Old Feb 07, 2008, 02:52 PM
BowerR64 is offline
Find More Posts by BowerR64
BeeZaur 480
BowerR64's Avatar
Parkville Mo.
Joined Dec 2004
What happens when i install my new video card?
Will i need to reinstall the sim when i put in my new video card? I just got in a new 5500 Geforce video card but before i put it in im wondering whats going to happen? will i need to reregister it? will it know the new card has been installed and up my graphics?
BowerR64 is offline Find More Posts by BowerR64
Old Feb 07, 2008, 03:47 PM
jfail is offline
Find More Posts by jfail
jfail's Avatar
Mesa, Arizona
Joined Sep 2003
I love Clearview. It is my favorite simulator.
The only thing I would like to see improved is the new releases have an install program where it detects the presence of an existing Clearview installation and installs the new version automatically. This would keep the licensee from having to copy models and landscapes before installation and re-copying them back after installation. It would leave all licensee extra models and landscapes without overwriting them.
jfail is offline Find More Posts by jfail
Old Feb 07, 2008, 04:00 PM
simages is offline
Find More Posts by simages
AMA# SIMAGES
simages's Avatar
United States, NY, Cold Spring
Joined Dec 2006
BowerR64,
You should not have to do anything with Clearview registration, but I'd worry about the Microsofts - Plug N PRAY..... I mean plug N play Seriously; NVidia is really good about the drivers and regardless when it was obtained, I would go to their site and download the lastest and greatest driver set and have it on hand if needed to update.
simages is offline Find More Posts by simages
Latest blog entry: Strega MK2 "P-51 Mustang" by...
Old Feb 07, 2008, 04:50 PM
BowerR64 is offline
BeeZaur 480
BowerR64's Avatar
Parkville Mo.
Joined Dec 2004
Originally Posted by simages
BowerR64,
Nvidia is all ill use, ive tried ATI in the past and ill never buy one again because of the trouble ive had. They maybe better now then they were but IMO they do sloppy work and rush all their drivers. Intel and Nvidia are the best. ATI and AMD might be more bang for the buck but you will have to do your home work once you get em.
Old Feb 07, 2008, 07:46 PM
BowerR64 is offline
BeeZaur 480
BowerR64's Avatar
Parkville Mo.
Joined Dec 2004
Man i went from an Nvidia Ti4200 128 meg gainward to an FX5500 256 meg and my FPS got worse.
I was overclocking the old one a little but man i figured this one would smoke the old one.
Old Feb 07, 2008, 10:51 PM
Helos36 is offline
Find More Posts by Helos36
Fernandina Beach, FL
Joined Sep 2002
New system
Just upgraded my system to AMD 64 X2 Dual Core 6000+, 4 gig DDR2 6400 memory, 250 gig Sata Drive, 650 watt Power supply and Geforce 8800 GT 512 meg ram video. this is runnin at 1400 X 1050 resolution....
Check out my FPS...I can hit over 1200 fps in the air
Ken
Helos36 is offline Find More Posts by Helos36
Old Feb 07, 2008, 11:22 PM
simages is offline
AMA# SIMAGES
simages's Avatar
Joined Dec 2006
Ken
GEEEEEEEK........
Just kidding!
I thought 120-170 FPS with my P4-3Ghz-1gb / Radeon X700 video 256mb was nice
Discussion Blade CX on Clearview Flight Sim skorp_ian Simulators 6 Feb 09, 2008 02:46 AM
FMS flight sim Steven9026 Beginner Training Area (Aircraft-Electric) 10 Oct 25, 2001 12:03 PM
Real Flight Sim rckid Electric Heli Talk 0 Jul 30, 2001 10:46 PM
FMS - The free R/C flight sim - Why does it crash on me ! steve lewin Electric Plane Talk 2 Jun 19, 2001 12:52 AM
