Old Jul 16, 2001, 10:54 PM
Chris Rust is offline
Find More Posts by Chris Rust
Joined Mar 2000
CHARGER PROJECT FROM OPENING PAGE OF EZONE! HEADS UP!!
Hey,
Anyone building-thinking of building this charger, it works great, BUT.....I had ALOT of trouble getting it to. I hope I can save you the trouble I had!
This is my first real homebrew project, and I very much wanted it to work. I built it like the drawing, and it wouldn't! I tried for 2 days to figure out why this thing wouldn't work.
Finally, this evening, I got it to work! Get this......The LM317, RS part #276-1778 has different pin-outs than most I have seen in the past. When viewed from the back of the case(heatsink side)the left pin is Vin, center pin Vout, and right pin is the adjustable leg!!!!
This has drove me nuts!! I was tring to use the center pin for the adjustable leg! That is the way I have always seen them before, and I really didn't pay an attention to the package till tonight! So, if you are having trouble making it work....CHECK THIS! I think I was getting 430mill output ALL THE TIME when hooked up the other way!
This IS NOT PAUL's FAULT.....Radio Shack has changed the pin out of the IC!!! I didn't LOOK to see what it was, I just went by the pics! Its my fault for missing it!!!
The charger WORKS GREAT! I used it this evening, and am VERY happy NOW! FINALLY! Guess I learned something here, and that was the reason for building this in the first place!
Good luck to all building....Don't give up, it'll work! Chris
Chris Rust is offline Find More Posts by Chris Rust
Old Jul 16, 2001, 11:08 PM
radix2 is offline
Find More Posts by radix2
Radix malorum est cupiditas
radix2's Avatar
Joined Jul 2000
Glad you got it to work,
however, the adjust has always(always) been been pin1 (leftmost pin from front, rightmost pin from heatsink), so anyone using the TO-220 version of the LM317 from RS or anyone else should use the pinout as specified....
radix2 is offline Find More Posts by radix2
Old Jul 16, 2001, 11:10 PM
radix2 is offline
radix2's Avatar
Joined Jul 2000
always easy to verify this stuff online too, just do a search on your PN
for ex: http://www.national.com/ads-cgi/view...s/LM/LM117.pdf
Discussion Heads up on the free shipping from Hobby-Lobby Jeremy Z Electric Plane Talk 0 Mar 14, 2006 12:40 PM
Heads Up to Shulze Charger Owners!! jimmy6819 Batteries and Chargers 0 Sep 13, 2003 08:11 PM
Heads up from AMA tiggs VOA Flyers of West Chester Ohio 0 Mar 15, 2003 03:46 PM
