Old Nov 17, 2006, 10:18 PM
Thermalin is offline
Find More Posts by Thermalin
I'm a pilot... 100 yrs to late
Thermalin's Avatar
USA, FL, Palm Harbor
Joined Jan 2005
Question
Cleaning "color" off Monokote
I was covering my fuse blue and went to orange for the horizontal stab and didn't realize some blue had gotton on my irons shoe.... Now I have some Blue on my orange (or chocolate in my peanut butter!)
Does anyone know how to get it off or is it better to just lay a strip down over the top.
Thermalin is offline Find More Posts by Thermalin
Old Nov 17, 2006, 10:44 PM
linw is offline
Find More Posts by linw
Wellington, NZ
Joined Aug 2006
My guess, Mike, is that anything that removed the blue would be sure to remove the orange as well. By accident I found that the solvent for F2 contact adhesive removed colour (sorry, color!) from my coating. Good luck!
linw is offline Find More Posts by linw
Old Nov 17, 2006, 11:32 PM
littlewing78 is offline
Find More Posts by littlewing78
I meant to do that
littlewing78's Avatar
Eagle Mountain, Utah
Joined Jul 2004
I have had luck with using the iron itself to get it off. After you clean the iron, rub it on the spot that got the wrong color until it rubs off. It usually works pretty well. Good luck
littlewing78 is offline Find More Posts by littlewing78
Old Nov 18, 2006, 12:02 PM
trab1925 is offline
Find More Posts by trab1925
trab1925's Avatar
Nebraska, Lincoln
Joined Apr 2006
I've used a razor blade carefully to kind of scrape it off. You have to be careful but I would say don't try it. I'm young and my eyes are good enough to look as close as I want them to. Good luck!
trab1925 is offline Find More Posts by trab1925
Old Nov 19, 2006, 03:49 AM
Thermalin's Avatar
Joined Jan 2005
ok.. thanks... think I"ll just lay another thin strip over it... and the fix will be to be sure to use a clean shoe between colors !!
Old Nov 19, 2006, 11:22 AM
indoruwet is offline
Find More Posts by indoruwet
God's gift to mankind for flying anything.
Joined Aug 2004
If you have been getting the "problem" of "transferring colo(u)r" from the covering to your iron, you have the heat setting too high.
Are you using a "sock" on your iron ?
indoruwet is offline Find More Posts by indoruwet
Old Nov 20, 2006, 12:04 PM
Thermalin's Avatar
Joined Jan 2005
no.. no sock... setting is at 3/4... I will lower and see how that does...
Thanks..
Can you clean those socks in the washer??? or cna i use just and "old" sock?
Old Nov 20, 2006, 03:38 PM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
I use ordinary paint thinner/solvent ("white spirit") to clean off the surface of Solarfilm if I get marks on it like you have. It will probably work with Monocote too. Just be sure not to let it run under the seams, otherwise it will probably debond your covering.
abenn is offline Find More Posts by abenn
Old Nov 21, 2006, 02:13 PM
Thermalin's Avatar
Joined Jan 2005
thanks.. i have some of that.. didnt think to use it.. i will apply carefully and see what happens..
Old Nov 21, 2006, 03:19 PM
Rodney is offline
Find More Posts by Rodney
Florida
Joined Aug 2004
The color is in the adhesive so on the lower side of the covering. If you got some smeared on the upper side of the blue covering from the iron, just use a soft tissue or cloth with some acetone and it will wipe right off with no damage to the covering underneith the smear. The acetone will disolve the adhesive quite easily.
Rodney is offline Find More Posts by Rodney
Old Nov 21, 2006, 05:30 PM
The Fonz is offline
Find More Posts by The Fonz
The Fonz's Avatar
Joined Dec 2005
FWIW,
i never use an iron sock. I find it actually is the source of many film scratches. As I was taught, many years ago, to scrub the iron with a sctch brite pad until it is smooth. If it is still rough you can use some ultra fine sand paper or even some wet dry paper to take out the roughness.
If you take care of your iron it will never leave scratches. Don't take my word for it. It is hard to believe but it is better without the sock.Try it on some scrap. If it works for you, you can save some money on socks
The Fonz
The Fonz is offline Find More Posts by The Fonz
Old Nov 22, 2006, 03:21 AM
Thermalin's Avatar
Joined Jan 2005
EHHHHHHHHHHHHHHYYYYYYY I'll try it !
Getting paint off monokote BillH The Builders Workshop 1 Sep 18, 2003 10:31 PM
Cleaning epoxy off wood J Morgan Electric Plane Talk 0 May 21, 2002 07:15 PM
Stipping off monokote DocMac Electric Plane Talk 2 Jun 17, 2001 10:22 PM
Need help cleaning CA off of Ultracote Ken Lapointe Electric Plane Talk 3 May 21, 2001 07:23 AM
