Old Mar 13, 2007, 09:59 PM
ElectRick is offline
Find More Posts by ElectRick
Eye Drather Beef Lying
ElectRick's Avatar
Jacksonville, FL
Joined Aug 2002
$99 for three wings instead of $89 for two seems more than reasonable.
Where else could you buy a fully finished wing for $10?
Rick
ElectRick is offline Find More Posts by ElectRick
Old Mar 13, 2007, 10:18 PM
Holtenbacker is offline
Find More Posts by Holtenbacker
Holtenbacker's Avatar
Modesto, California USA
Joined Jan 2004
If you go by square inches, it works out less
Three wings, but shorter wings and cord.
SE5A 34 in 420 sq in
Fok DVII 36 in 360 sq in
Fok DrI 29.5 300 sq in
Holtenbacker is offline Find More Posts by Holtenbacker
Old Mar 14, 2007, 06:42 AM
spinnetti is offline
Find More Posts by spinnetti
SCCA, EAA, M.E.
spinnetti's Avatar
United States, TX, Frisco
Joined Nov 2001
Originally Posted by Holtenbacker
HogCrewChief,
I also use a GP Balancer and my Fokker finnished out at 23.5 oz
I also used the Liquitex, but as a very light coating.
The Fokker in the E Zone Review weighed 22.7 oz.
Something does not add up right
Re Check the balance at 2.125 in
Either the equipment in front of the CG is lighter than what others used..
Or Assembly or equipment past the CG is heavier than what others used.
GP Is releasing the Fokker DrI triplane in late ApriI. It will be $10 more than the SE5A and the Fokker DVII
Cool! This one has been done a bit much, but cool anyway... I'd like to see a DVIII or other less modelled one..
spinnetti is offline Find More Posts by spinnetti
Old Mar 14, 2007, 08:44 AM
pda4you is offline
Find More Posts by pda4you
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
You and me both.....
I want the DVIII in a bad way.....
On CG - mine balanced with no weight. I have my RX all the way forward and have no added weight for CG. I used light duty servo wiring too.
I think you may be adding more with the matte finish than you think...
Old Mar 14, 2007, 09:19 AM
D Johnson is offline
Find More Posts by D Johnson
Just some guy
D Johnson's Avatar
Joined Aug 2006
I have built a couple of these and both balanced with no added lead. The flat finish aft of the CG is probably the culprit. Every gram on the tailk equals 4-5 in the nose. Try scrubbing the monocote with a green Scotch Brite pad as that dulls it down and leaves a nice semi-matt finish.
D Johnson is offline Find More Posts by D Johnson
Old Mar 14, 2007, 02:11 PM
P-40 is offline
Find More Posts by P-40
Love them P-40's!
P-40's Avatar
USA, MO, Kansas City
Joined Feb 2004
Finished mine up with the exception of more scale details on the engine and fuselage. I am not happy with how the gun belt feeds turned out, but will be reworking those to get them to look even soon. I really like the gun kits though. They turned out very nice. I used the Liquitex varnish technique, which also turned out very nice.
Setup:
AXI 2212/26 w/ 10x6 GWS HD prop
Phx 25 ESC
1500 Mah 3S battery
4 - HS-55 servos
Berg 5 Rx
2 - WrightbrothersRC Spandaus
AUW - approx. 23.5 ounces
I have not maidened this one yet as it is to windy here in the early spring. The antenna is wrapped around a plastic straw inside the fuselage. It has always worked well with my Bergs. It's a good way to keep the scale look without the dangling antenna (for those of us that have not converted to 2.4 ghz yet)
Here are a few pictures as it stands right now.
P-40 is offline Find More Posts by P-40
Old Mar 14, 2007, 02:19 PM
pda4you is offline
pda4you's Avatar
Joined May 2002
P-40 - that looks fantastic!
Love the dull coat....great job!
Old Mar 14, 2007, 03:01 PM
P-40 is offline
Love them P-40's!
P-40's Avatar
Joined Feb 2004
Thanks Mike. I am really impressed with this line of planes. I think Great Planes did a fantastic job on them.
I really hope they continue to add to the WWI line. It's a segment that has always fascinated me.
I forgot to add a picture of the fuselage lettering. I'll do that later. Thanks to Kurt at AerodromeRC for resizing it for me to scale of this bird.
Here is a picture of the lettering on the fuse. It was printed on Testors water slide decal paper. I know it is blurry, but hopefully illustrates the point.
Old Mar 14, 2007, 05:34 PM
HogCrewChief is online now
Find More Posts by HogCrewChief
Terryville,CT (USA)
Joined Mar 2006
Thanks for the info. I will try and balance the plane again. Are you guys balancing at the recommended CG or 2 1/4" back from the LE of the top wing? Like I said I installed all the recommended gear, Electrifly rimfire C28-30-950 motor, Electrifly 25 amp ESC, 4 Hitec 55 servos, TP 1320 mah pack, the extensions and y-harness I used were kinda big and I used a JR sport RS600 reciever. Maybe I added a little to much liquitex on the tail. I still think the plane will do just fine at 27oz. Great planes shows the plane at 25.7oz so I am not to far off.
Tony
HogCrewChief is online now Find More Posts by HogCrewChief
Old Mar 14, 2007, 08:19 PM
Joined Jan 2004
A pics of mine.
Old Mar 14, 2007, 10:58 PM
turbonut is offline
Find More Posts by turbonut
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
I was told today at the LHS that a Dr1 is next! any body else know about this?
Scott
Old Mar 14, 2007, 11:19 PM
Joined Jan 2004
Scott
See post 75 -77
Old Mar 15, 2007, 08:30 AM
sanman55 is offline
Find More Posts by sanman55
sanman55's Avatar
powder springs georgia
Joined Nov 2003
fokker
Great pictures... Is there anywhere you can get the instrument decals?
I found that for me I move the cg back as far as I can. It helps to be able to slow down your approach. I too had to add weight to the nose, I am have my cg at 2 3/8 to 2 1/4 back, Be careful and not move it back too far. Its a bear to fly if you do. I am getting better a landings but still working on them. Love this plane .. get a lot of comments at my flying club..
sanman55 is offline Find More Posts by sanman55
Old Mar 15, 2007, 04:11 PM
claybuster is offline
Find More Posts by claybuster
Electricholics Anonymous
claybuster's Avatar
WARREN, MICHIGAN
Joined Jul 2005
P-49,
Could you measure the lettering for me ? Height, length.
claybuster is offline Find More Posts by claybuster
Old Mar 15, 2007, 04:52 PM
P-40 is offline
Love them P-40's!
P-40's Avatar
Joined Feb 2004
Mike,
Sent you a PM.
Article Great Planes, Electrifly Fokker Dr-1 ARF Parkflyer Review Michael Heer Parkflyers 503 Mar 28, 2016 12:17 AM
Found Great Planes ElectriFly Fokker DVII shovelheadfreak Aircraft - Electric - Airplanes (FS/W) 4 Jan 11, 2007 07:24 PM
New Product **NEW** Great Planes ElectriFly Fokker D.VII Park Flyer ARF Mandy Product Announcements 0 Aug 31, 2006 01:30 PM
Discussion **NEW** Great Planes ElectriFly Fokker D.VII Park Flyer ARF Jim T. Graham Product Announcements 4 Aug 18, 2006 09:50 PM
New Product Great Planes ElectriFly Fokker D.VII Park Flyer ARF Mandy Scale Kit/Scratch Built 0 Aug 15, 2006 05:47 PM
