Old Jul 12, 2009, 11:38 AM
IFT3226 is offline
Find More Posts by IFT3226
Sweden
Joined Jul 2009
Arrived!
So, my DVII has arrived! I'm hoping I will find some time tonight to at least open the box and maybe-maybe start building a bit
Still waiting for the motor, ESC and the battery from HK.
I now know where to direct myself in case of any questions that might come during building, excellent forum with expert help.
IFT3226 is offline Find More Posts by IFT3226
Old Dec 01, 2009, 12:53 PM
Rockman201060 is offline
Find More Posts by Rockman201060
Erdweg w. Munich
Joined Sep 2008
Well...
Just have tried to maiden my Fokker, but it went on it`s nose. At the next attempt the motor mount just exploded, hacking the hood into small pieces
Seems as if the motor mount real is a weak part of that plane... I`ve now replaced it by a selfmade one of aluminum, waiting for a new cowling which was ordered from the German importer, Simprop.
It wouldn`t be a bad idea to have that one made of fiberglas, or?
Hope when it flies it`s worth it...
Regards from Munich,
Roman
Rockman201060 is offline Find More Posts by Rockman201060
Old Dec 01, 2009, 01:33 PM
Mark Wolf is offline
Find More Posts by Mark Wolf
Flying electric since 1986
Mark Wolf's Avatar
USA, IN, Brownsburg
Joined Oct 2000
I've been flying mine for a few years now and have yet to have an issue with the motor mount, despite the model nosing over on nearly every landing. You may have just had a bit of bad luck with yours.
Mark Wolf is offline Find More Posts by Mark Wolf
Old Dec 01, 2009, 03:22 PM
Park_Flyer is offline
Find More Posts by Park_Flyer
Very, very, very hugely smart.
Park_Flyer's Avatar
United States, VA, Virginia Beach
Joined Jun 2005
Roman,
That is quite odd. It makes me wonder if you didn't damage the box on the nose over. Combine that with a bent prop adapter you could have had quite a vibe there.
Just a thought.
Ben
Park_Flyer is offline Find More Posts by Park_Flyer
Old Dec 02, 2009, 09:53 AM
Erdweg w. Munich
Joined Sep 2008
Hello Ben,
well, it was not a smash on the nose, just a last dive before it stood still finally.
Therefore I had no concerns in starting a new run.
But it obviously must have been hard enough to brake something at the mount - anyhow, I repaired it and am waiting for the new cowling to make a new attempt.
Mark maybe I didn`t build the mount massive enough, now with 2 layers of 1mm aluminum that shouldn`t be an issue any longer.
I will report if I smashed it in the first flight or if it works fine
Old Dec 03, 2009, 10:28 AM
stacker is offline
Find More Posts by stacker
stacker's Avatar
Salt Lake City Utah
Joined Mar 2004
Originally Posted by Rockman201060 View Post
Well...
Roman
Air Sally here on the forums sells nice fiberglass GP D7 cowls.
http://www.rcgroups.com/forums/member.php?u=95393
Not sure if he ships out of the country or not, but it worked great on my old war torn D7.
Cheers--Stacker
stacker is offline Find More Posts by stacker
Old Dec 03, 2009, 04:24 PM
Erdweg w. Munich
Joined Sep 2008
Hy Stacker,
thank you very much for that link - today I got the cowling, so if weather is alike I will try to maiden it this weekend...
But making that cowling with fiberglass makes sence in my eyes. Especially at temperatures around 0° C the material of the genuine one is like glass...
Regards,
Roman
Old Sep 15, 2010, 04:00 PM
Erdweg w. Munich
Joined Sep 2008
So, long time since, but Sunday afternoon my D VII flew.
Nice one, just a bit quick maybe for a plane of that age but good controlable. Have to take back ailerons a bit, but then it will be fine I guess.
it`s nice looking and even the sound fits to that sort of plane - obviously the fus is resonating so it sounds quite nice.
Regards,
Roman
Old Oct 02, 2010, 03:40 AM
Warbird@home is offline
Find More Posts by Warbird@home
Warbird@home's Avatar
The Netherlands, NB, Hapert
Joined Apr 2002
Well it finally happened...
Wrong program on my Tx so seriously rolled my Fokker into the ground, all the struts we broken and the cowl and hatch were a mess....well out of the fire came the Pheonix....The only thing that bothered me slightly about this great flying/looking aeroplane was the thin cowl and the engine detail (or lack of) so here she is now after a Major refit to the front end including a rebuild cowl (much thicker plastic and wood)....and an cartoon attempt at an engine......I also stiffened up the ply plates inside the fuselage where the struts attach......not a serious job on the engine but a little better than before..
Ray
Warbird@home is offline Find More Posts by Warbird@home
Old Oct 02, 2010, 08:03 AM
Park_Flyer's Avatar
Joined Jun 2005
@ Warbird
Hey, that looks pretty good. Not too shabby at all.
Old Oct 02, 2010, 09:26 AM
Joined Apr 2002
Originally Posted by Park_Flyer View Post
@ Warbird
Thanks P_F, it's just to give an idea of an engine........it looked a bit *bare* as supplied.....but up to the crash I couldn't be bothered to change anything .....Great aeroplane though, flies well and looks great.
R
Old Nov 03, 2010, 09:25 PM
Davey NY is offline
Find More Posts by Davey NY
Ya gotta land eventually...
Davey NY's Avatar
United States, NY, Mahopac
Joined Sep 2010
Guys,
can anyone recommend a less expensive servo for the DVII that is reliable?
i am almost ready to start installing in the wings. Not sure what to buy?
David
Davey NY is offline Find More Posts by Davey NY
Old Nov 05, 2010, 02:41 PM
Park_Flyer's Avatar
Joined Jun 2005
Originally Posted by Davey NY View Post
Guys,
Hey, man. i'm surprised no one has chimed in by now, but it is an old thread - I guess folks have moved on to other airplanes.
Anyways, make sure the servo you select has enough torque (at least 17 oz IAW the manual) - there are good inexpensive ones in the 22 oz range made by Blue Bird and GWS $10-12. Check BP Hobbies - they have 4-servo deals on the Blue Birds. You can use a lower torque servo for each aileron, something like an Hitec HS-55 would do, but make sure you use the higher torque servos for the elevator and rudder.
Have fun.
Old Nov 05, 2010, 09:45 PM
ben199 is offline
Find More Posts by ben199
ben199's Avatar
New Zealand
Joined Jul 2008
Guys,
David
I used 9gram hextronic's from hobbyking and havn't had any problems.
-Reuben
ben199 is offline Find More Posts by ben199
Old Nov 07, 2010, 08:23 PM
Davey NY is offline
Davey NY's Avatar
Joined Sep 2010
Thanks guys. Yes I was starting to despair that this thread was going the way of the dodo bird
thanks guys.
Any of you guys have nay luck with inexpensive 2.4 receivers?
Article Great Planes, Electrifly Fokker Dr-1 ARF Parkflyer Review Michael Heer Parkflyers 505 May 15, 2016 07:55 PM
Found Great Planes ElectriFly Fokker DVII shovelheadfreak Aircraft - Electric - Airplanes (FS/W) 4 Jan 11, 2007 07:24 PM
New Product **NEW** Great Planes ElectriFly Fokker D.VII Park Flyer ARF Mandy Product Announcements 0 Aug 31, 2006 01:30 PM
Discussion **NEW** Great Planes ElectriFly Fokker D.VII Park Flyer ARF Jim T. Graham Product Announcements 4 Aug 18, 2006 09:50 PM
New Product Great Planes ElectriFly Fokker D.VII Park Flyer ARF Mandy Scale Kit/Scratch Built 0 Aug 15, 2006 05:47 PM
